查看: 2296|回复: 0
[Fortran] 将模拟滤波器转变为数字滤波器
发表于 2006-8-6 07:16 | 显示全部楼层 |阅读模式
  1.         subroutine aftodf(d,c,ln,iband,fln,fhn,b,a,ierror)
  2. c----------------------------------------------------------------------
  3. c Routine AFTODF: To convert normalized LP analog H(s) to digital H(z).
  4. c   H(s)=D(s)/C(s),H(z)=B(z)/A(z).Filter order l is computed internally.
  5. c   LN specifies coefficient array size. WORK(0:LN,0:LN) is a work array.
  6. c   IF   IBAND=1:    lowpass   fln=normalized cutoff frequency
  7. c             =2:    highpass  fln=normalized cutoff frequency
  8. c             =3:    bandpass  fln=low  cutoff frequency
  9. c                              fhn=high cutoff frequency
  10. c             =4:    bandstop  fln=low  cutoff frequency
  11. c                              fhn=high cutoff frequency
  12. c   IF  IERROR=0:    no errors detected
  13. c              1:    all zero transfer function
  14. c              2:    biline: invalid transfer function
  15. c              3:    filter order exceeds array size
  16. c              4:    invalid filter type parameter (IBAND)
  17. c              5:    invalid cutoff frequency
  18. c       From Ref. [5] of Chapter 2 .      in chapter 7
  19. c-----------------------------------------------------------------------
  20.         dimension work(0:4,0:4),d(0:4),c(0:4),b(0:4),a(0:4)
  21.         pi=4.*atan(1.)
  22.         ierror=0
  23.         if(iband.lt.1.or.iband.gt.4) ierror=4
  24.         if(fln.le.0..or.fln.gt.0.5) ierror=5
  25.         if(iband.ge.3.and.fln.ge.fhn) ierror=5
  26.         if(iband.ge.3.and.fhn.gt.0.5) ierror=5
  27.         if(ierror.ne.0) return
  28.         do 1 i=ln,0,-1
  29.            if(c(i).ne.0..or.d(i).ne.0.) go to 2
  30. 1       continue
  31.         ierror=1
  32.         return
  33. 2       m=i
  34.         w1=tan(pi*fln)
  35.         l=m
  36.         if(iband.le.2) go to 3
  37.         l=2*m
  38.         w2=tan(pi*fhn)
  39.         w=w2-w1
  40.         w02=w1*w2
  41. 3       continue
  42.         ierror=3
  43.         if(l.gt.ln) return
  44.         go to (30,20,40,20) iband
  45. c-------- substitution of 1/s to generate highpass (hp,bs) ------------
  46. 20      continue
  47.         do 25 mm=0,m/2
  48.            tmp=d(mm)
  49.            d(mm)=d(m-mm)
  50.            d(m-mm)=tmp
  51.            tmp=c(mm)
  52.            c(mm)=c(m-mm)
  53.            c(m-mm)=tmp
  54. 25      continue
  55.         if(iband.eq.4) go to 40
  56. c-------- scaling s/w1 for lowpass,highpass ---------------------------
  57. 30      continue
  58.         do 35 mm=0,m
  59.            d(mm)=d(mm)/(w1**mm)
  60.            c(mm)=c(mm)/(w1**mm)
  61. 35      continue
  62.         go to 100
  63. c-------- substitution of (s**2+w0**2)/(w*s)  bandpass,bandstop -------
  64. 40      continue
  65.         do 45 ll=1,l+1
  66.            work(ll,1)=0.
  67.            work(ll,2)=0.
  68. 45      continue
  69.         do 52 mm=0,m
  70.            tmpd=d(mm)*(w**(m-mm))
  71.            tmpc=c(mm)*(w**(m-mm))
  72.            do 50 k=0,mm
  73.               ls=m+mm-2*k
  74.               tmp=spbfct(mm,mm)/(spbfct(k,k)*spbfct(mm-k,mm-k))
  75.               work(ls+1,1)=work(ls+1,1)+tmpd*(w02**k)*tmp
  76.               work(ls+1,2)=work(ls+1,2)+tmpc*(w02**k)*tmp
  77. 50         continue
  78. 52      continue
  79.         do 55 ll=0,l
  80.            d(ll)=work(ll+1,1)
  81.            c(ll)=work(ll+1,2)
  82. 55      continue
  83. c---------- substitute (z-1)/(z+1) ------------------------------------
  84. 100     continue
  85.         call biline(work,d,c,ln,b,a,ierror)
  86.         if(ierror.eq.0) return
  87.         write(*,*)'   stop at routine biline,ierror=',ierror
  88.         return
  89.         end
  90. c
  91.         function spbfct(i1,i2)
  92. c-------- generates (i1)!/(i1-i2)!=i1*(i1-1)*...*(i1-i2+1). -----------
  93. c-------- note: 0!=1 and spbfct(i,i)=spbfct(i,i-1)=i!.      -----------
  94.         spbfct=0.
  95.         if(i1.lt.0.or.i2.lt.0.or.i2.gt.i1) return
  96.         spbfct=1.
  97.         if(i2.eq.0) return
  98.         do 31 i=i1,i1-i2+1,-1
  99.            spbfct=spbfct*i
  100. 31      continue
  101.         return
  102.         end
[ 本帖最后由 VibInfo 于 2006-8-6 07:27 编辑 ]
GMT+8, 2024-9-30 03:27 , Processed in 0.055444 second(s), 17 queries , Gzip On.
