查看: 4255|回复: 7
[前后处理] 在钢结构中钢结点用什么单元模拟?
发表于 2006-7-29 15:49 | 显示全部楼层 |阅读模式
在钢管用solid45可以吗,但是在划分结点集中的地方好像划分单元不理想
总是出现好多警告?望高手告知
发表于 2006-7-29 16:53 | 显示全部楼层
二位用beam3,三维用beam4,建模时先画出node,再画element,这样就不用划分网格,直接加载载荷。
由于beam3节点有3个自由度,beam4节点有6个自由度,因此节点就是刚接的。
发表于 2006-7-29 17:51 | 显示全部楼层
同意楼上的观点
 楼主| 发表于 2006-7-30 10:20 | 显示全部楼层
对不起,我没有说明白,我说的是钢结构中的相贯节点分析,
中间加密部分总是出现很多警告,我分别用solid45,和solid95试过
(如图)出现如下警告,怎么解决??,我用的 是smart,7自由划分网格形式,出现这些警告对结果没影响吧????
*** WARNING ***                         CP=     84.702   TIME= 09:54:43
Shape testing revealed that 40 of the 13517 new or modified elements
violate shape warning limits.  To review test results, please see the
output file or issue the CHECK command.
*** WARNING ***                         CP=     78.763   TIME= 09:54:36
Mid-nodes of some elements have been modified to lie on straight edges
because of distortion with the original mid-nodes.  This condition is
sometimes eliminated by tetrahedron element improvement when enabled.
Issue ESEL,,STRAIGHTENED to select such elements for listing or
plotting.
发表于 2006-7-30 11:16 | 显示全部楼层
第一个警告没有什么问题,第二个没有遇到过,应该也是没有问题的
你求解一下看看
 楼主| 发表于 2006-7-31 16:14 | 显示全部楼层
*** ERROR ***                           CP=    431.741   TIME= 15:24:44
Sparse Matrix Solver failure.  Please check the error file (file.err)
for possible causes.
*** ERROR ***                           CP=    433.273   TIME= 15:34:49
Bisection may be activated if it is a nonlinear analysis.
0***** process error reported by subroutine   xdslvf
       see    xdslvf abstract (ier =  -410)
*** ERROR ***                           CP=    642.894   TIME= 16:07:06
*** ERROR ***     SUPPRESSED MESSAGE    CP=    643.696   TIME= 16:08:05
*** WARNING ***   SUPPRESSED MESSAGE    CP=    645.118   TIME= 16:09:30
At this abort point, the single-frame restart file may not be complete.
  Use multi-frame restart from the last successfully converged substep.
*** WARNING ***   SUPPRESSED MESSAGE    CP=    645.128   TIME= 16:09:31
The unconverged solution (identified as time 1 substep 999999) is
output for analysis debug purposes.  Results should not be used for
any other purpose.
计算出现这个问题怎么解决啊
 楼主| 发表于 2006-8-2 12:41 | 显示全部楼层
怎么没人回答啊
发表于 2006-8-2 20:49 | 显示全部楼层
求解方法选择不对,你用的是稀疏矩阵求解方法,建议你让程序自己选择,就是在设置求解控制选项时!
GMT+8, 2025-1-16 08:47 , Processed in 0.133109 second(s), 21 queries , Gzip On.
