查看: 1350|回复: 3
[求助]求解出错问题
发表于 2006-6-25 16:21 | 显示全部楼层 |阅读模式
计算未完出现“One or more elements have become highly distorted.  Excessive<br>distortion of elements is usually a symptom indicating the need for<br>corrective action elsewhere.  Try incrementing the load more slowly<br>(increase the number of substeps or decrease the time step size).  You<br>may need to improve your mesh to obtain elements with better aspect<br>ratios.  Also consider the behavior of materials, contact pairs,<br>and/or constraint equations.  If this message appears in the first<br>iteration of first substep, be sure to perform element shape checking.”出错信息,如何解决?<br>
[此贴子已经被xiven2008于2006-6-28 9:02:12编辑过]
发表于 2006-6-26 08:19 | 显示全部楼层
网格有问题
发表于 2006-6-26 09:13 | 显示全部楼层
<P>这个问题我也遇到过,当时我用的是四面体网格,在变形过程中由于方向问题使网格形状发生变化,出现distorted的情况。如果你也用的四面体网格建议划分成规则的六面体网格再试一下。</P>
发表于 2006-6-26 22:38 | 显示全部楼层
"One or more elements have become highly distorted"<BR>对应于你的所用的单元而言, 网格划分的不好.导致过度的扭曲.
GMT+8, 2025-1-16 12:29 , Processed in 0.071401 second(s), 18 queries , Gzip On.
