查看: 1746|回复: 2
[求助]寻求流体分析中的动态边界实例
发表于 2006-6-23 15:22 | 显示全部楼层 |阅读模式
大家好!我现在要做一个齿轮泵方面的流固单向耦合分析(也就是只要求出油液产生的对齿轮泵轮齿上的压力),请问:怎样处理齿轮旋转时的动态边界啊 ?也就是ALE技术,如果有熟悉的朋友,麻烦帮忙提供几个ALE实例!我的email:<a href="mailtnieyibiao@163.com" target="_blank" >nieyibiao@163.com</A>谢谢!
发表于 2006-6-24 07:46 | 显示全部楼层
回复:(nieyibiao)[求助]寻求流体分析中的动态边界实...
Ansys帮助文档里有一个ALE分析的例子,如下<BR><BR>/batch,list<BR>/verify,dv-1101c<BR>/title, dv-1101c, Flotran Remeshing: Cylinder pass through a channel<BR>/COM,****************************************************<BR>/COM,* Cylinder pass through a channel (pure fluid flow)<BR>/COM,* Verify partial domain re-meshing<BR>/COM,****************************************************<BR>r1 = 2.5<BR>l1 = 5.0<BR>l2= 20.0<BR>l3=60.0<BR>h = 10.0<BR>rx0= l1+(l2-l1)/2.0<BR>ry0 = h/2.0<BR>nl1 = 5<BR>nl3 = 10<BR>nr=8<BR>nc=8<BR>/PREP7 <BR><BR>*DEL,_FNCNAME   <BR>*DEL,_FNCMTID   <BR>*DEL,_FNC_C1<BR>*SET,_FNCNAME,'DIS'<BR>*DIM,_FNC_C1,,1 <BR>*SET,_FNC_C1(1),1.0<BR>! /INPUT,force.func <BR>*DIM,%_FNCNAME%,TABLE,6,3,1 <BR>!   <BR>! Begin of equation: a*{TIME}   <BR>*SET,%_FNCNAME%(0,0,1), 0.0, -999   <BR>*SET,%_FNCNAME%(2,0,1), 0.0 <BR>*SET,%_FNCNAME%(3,0,1), %_FNC_C1(1)%<BR>*SET,%_FNCNAME%(4,0,1), 0.0 <BR>*SET,%_FNCNAME%(5,0,1), 0.0 <BR>*SET,%_FNCNAME%(6,0,1), 0.0 <BR>*SET,%_FNCNAME%(0,1,1), 1.0, -1, 0, 1, 17, 3, 1 <BR>*SET,%_FNCNAME%(0,2,1), 0.0, 99, 0, 1, -1, 0, 0 <BR>*SET,%_FNCNAME%(0,3,1),   0 <BR>! End of equation: a*{TIME} <BR>!--&amp;gt;<BR><BR>RECTNG,0,l1,0,h,  <BR>RECTNG,l1,l2,0,h,  <BR>RECTNG,l2,l3,0,h,  <BR>aglue,all   <BR><BR>CYl4,rx0,ry0,0,45,r1,135   <BR>CYl4,rx0,ry0,0,135,r1,225   <BR>CYl4,rx0,ry0,0,225,r1,315   <BR>CYl4,rx0,ry0,0,315,r1,405   <BR>asel,s,,,2<BR>asel,a,,,3<BR>asel,a,,,6<BR>asel,a,,,7<BR>allsel,below,area<BR>aglue,all <BR>allsel<BR>FLST,3,4,5,ORDE,3   <BR>FITEM,3,2   <BR>FITEM,3,8   <BR>FITEM,3,-10 <BR>A***A,       4,P51X<BR>aplot<BR><BR>et,1,141<BR>KEYOPT,1,4,1<BR>type,1<BR>mat,1<BR>asel,s,,,1<BR>esize,.5<BR>mshape,1,2d<BR>mshkey,0<BR>amesh,all<BR><BR>et,2,141<BR>KEYOPT,2,4,1<BR>type,2<BR>mat,1<BR>asel,s,,,3<BR>esize,.5<BR>mshape,1,2d<BR>mshkey,0<BR>amesh,all<BR><BR>et,3,141<BR>KEYOPT,3,4,1<BR>type,3<BR>mat,1<BR>asel,s,,,5<BR>esize,2.0<BR>mshape,1,2d<BR>mshkey,0<BR>amesh,all<BR>nsel,s,loc,x,0<BR>D,ALL,VX,0.0, <BR>D,ALL,VY, 0.0<BR>D,ALL,UX,0.0, <BR>D,ALL,UY, 0.0<BR>nsel,s,loc,x,l3<BR>D,ALL,pres,0.0<BR>D,ALL,UX,0.0, <BR>D,ALL,UY, 0.0<BR>nsel,s,loc,y,0<BR>D,ALL,vy,0.0<BR>D,ALL,UX,0.0, <BR>D,ALL,UY, 0.0<BR>nsel,s,loc,y,h<BR>D,ALL,vy,0.0<BR>D,ALL,UX,0.0, <BR>D,ALL,UY,0.0,<BR>lsel,s,,,5<BR>lsel,a,,,23<BR>lsel,a,,,25<BR>lsel,a,,,27<BR>nsll,s,1<BR>d,all,UX,%DIS%<BR>d,all,UY,0.0<BR>d,all,VX,1.0<BR>d,all,VY,0.0<BR>allsel<BR>cdwrite,db,fluid,cdb,<BR>fini<BR>! Flotran Setup<BR>/solu<BR>FLDATA30,QUAD,MOMD,2,   <BR>FLDATA30,QUAD,MOMS,2,   <BR>FLDATA30,QUAD,PRSD,2,   <BR>FLDATA30,QUAD,PRSS,2,   <BR>FLDATA30,QUAD,THRD,0,   <BR>FLDATA30,QUAD,THRS,0,   <BR>FLDATA30,QUAD,TRBD,0,   <BR>FLDATA30,QUAD,TRBS,2,   <BR>/solu<BR>FLDATA4,TIME,NUMB,100000,   <BR>FLDATA4,TIME,TEND,44.0,<BR><BR>FLDA,SOLU,ALE,T                ! <U><B><FONT color=#ff0000>ALE</FONT></B></U> solution<BR>FLDATA1,SOLU,FLOW,1<BR>FLDATA1,SOLU,TRAN,1<BR>!FLDATA1,SOLU,TURB,1<BR>FLDATA2,TIME,GLOB,5<BR><BR>FLDATA7,PROT,DENS,CONSTANT<BR>FLDATA8,NOMI,DENS,1.0<BR>FLDATA7,PROT,VISC,CONSTANT<BR>FLDATA8,NOMI,VISC,1.0<BR>!FLDA,BULK,BETA,1.0e5<BR>FLDA,TIME,STEP, 2.0<BR>!<BR>!!! Newmark method<BR>!<BR>FLDATA,OUTP,TAUW,T<BR>FLDATA,TIME,METH,NEWM<BR>FLDATA,TIME,DELT,0.5<BR>!<BR>!! Set ANSYS-STRUCTURE commands<BR>SAVE<BR>/COM <BR>/COM  Re-meshing Commands<BR>/COM <BR>FLDATA,REMESH,ELEM,ALL        ! all defined element re-meshing<BR>FLDATA,REMESH,ARMA,10.0       ! maximum aspect ratio<BR>FLDATA,REMESH,VOCH,5.0        ! maximum volume change<BR>FLDATA,REMESH,ARCH,5.0        ! maximum aspect ratio change<BR>SOLVE<BR>SAVE<BR>finish
 楼主| 发表于 2006-6-25 16:14 | 显示全部楼层
<P>谢谢!</P>
GMT+8, 2025-1-29 10:06 , Processed in 0.092164 second(s), 17 queries , Gzip On.
