查看: 4478|回复: 3
[Virtual.Lab] 计算acoustic response case 时,报错job execution failed ;
发表于 2020-12-10 16:09 | 显示全部楼层 |阅读模式
在确保前部操作没问题的前提下,计算acoustic response case ,提示报错job execution failed;failed to started sysnoise process. 具体报错信息如下,希望大神能给热锅上的蚂蚁我指点一下
 楼主| 发表于 2020-12-10 22:32 | 显示全部楼层
XPR VERSION 13.3
Requested task is SYSNOISE sequential computation.
Working directory on server is E:\VL_Temp
Checking that the SYSNOISE launch script (E:\Program Files\LMS\LMS Virtual.Lab 13.3\VirtualLab\Sysnoise\5.6\bin\sysnoise_nogui.bat) exists on server...
OK
SYSNOISE log file on server is E:\VL_Temp\Lixueyuan2-994470-sysnoise.log.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxx  JOB EXECUTION START
                System for Computational Vibro-Acoustics
SYSNOISE 13.3  Windows_x86_64             DATE: 10-DEC-2020 22:26:11
  Build Date: 25-FEB-2015
READING THE SET-UP FILE: E:\Program Files\LMS\LMS Virtual.Lab 13.3\VirtualLab\Sysnoise\5.6\bin\\..\res\SYSNOISE.STP
THE SYSNOISE PROFILE FILE NAME HAS NOT BEEN DEFINED.
STANDARD GRAPHIC DEVICE SET TO DEFAULT
PLOTTING GRAPHIC DEVICE SET TO SCREENDUMP
MEMORY IN USE    =              800000 (   0.003 Gb )
AVAILABLE MEMORY =          1021500000 (   3.805 Gb )
FREE MEMORY      =          1020700000 (   3.802 Gb )
CREATING DEFAULT SYSNOISE MODEL FILE default.sdb
SYSNOISE ANALYSIS OPTION :
      BEM INDIRECT VARIATIONAL UNBAFFLED FREQUENCY FLUID
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP USRDIR 'E:\VL_Temp\' RETURN
SYSNOISE>  SCL> ENVIRONMENT SECTION SETUP TMPDIR 'E:\VL_Temp\' RETURN
SYSNOISE>  SCL> Open Model 1 File Lixueyuan2-994470-Acoustic.sdb Original Return
OPENING SYSNOISE MODEL FILE Lixueyuan2-994470-Acoustic.sdb
LOADING MODEL Exported VLModel
  ERROR - Normal cannot be calculated
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
  Please check element:     334725 (internal number)
  Please check element:     337169 (internal number)
SYSNOISE>  SCL> Extract Summary Return
SYSNOISE SUMMARY INFORMATION
Title...Exported VLModel
Date....10-DEC-2020 22:26:18
Number of dimensions......................      3
Number of nodes........................... 405730
Number of elements........................ 405726
Number of material characteristics........      1
Number of load cases......................      1
Number of elements with velocity B.C.'s... 405726
Number of field points....................   1350
SYSNOISE>  SCL> Environment Section SETUP BELL 'on' Return
SYSNOISE>  SCL> Environment Section SETUP GEO_TOLERANCE '1E-006' Return
SYSNOISE>  SCL> Parameter Model 1
PARAMETER>  SCL>   Physical
PARAMETER>
PARAMETER>  SCL>   Save Potentials Step 1
PARAMETER>  SCL>   Save Results Step 1
PARAMETER>  SCL>   Store Results none
STORE RESULTS>  SCL>    Return
PARAMETER>  SCL>   Near 2
PARAMETER>  SCL>   Far 5
PARAMETER>  SCL>   Quadrature 2  2  1
PARAMETER>  SCL>   Positive
PARAMETER>  SCL>   Return
Updating Model Parameters
SYSNOISE>  SCL> Solve
SOLVE>  SCL> Frequency 20 To 5000 LinStep 20
SOLVE>  SCL> Return
发表于 2022-1-5 15:26 | 显示全部楼层
同问 请问解决了么?
发表于 2022-5-15 10:48 | 显示全部楼层
这不是提示你有两个单元有问题吗?你检查一下那两个单元的几何结构,可能需要修改一下
GMT+8, 2025-6-3 20:44 , Processed in 0.112100 second(s), 22 queries , Gzip On.
