查看: 2799|回复: 2
[其他相关] [求助]关于疲劳分析
发表于 2005-7-30 10:34 | 显示全部楼层 |阅读模式
在设置事件的对话框中,那个Scale factor for stresses是什么含义?应该怎么确定?
发表于 2005-8-14 16:33 | 显示全部楼层
回复:(bany)[求助]关于疲劳分析
The user may also specify a scale factor that will scale all stresses, both alternating and mean by the specified value. This value may be parameterized. Applying a scale factor is useful to avoid having to solve the static model again to see the effects of changing the magnitude of the FEM loads. In addition, this factor may be useful to convert a non-constant amplitude load history data into the appropriate values
 楼主| 发表于 2005-8-14 19:23 | 显示全部楼层
回复:(cora)回复:(bany)[求助]关于疲劳分析
<DIV class=quote><B>以下是引用<I>cora</I>在2005-8-14 16:33:22的发言:</B><BR>The user may also specify a scale factor that will scale all stresses, both alternating and mean by the specified value. This value may be parameterized. Applying a scale factor is useful to avoid having to solve the static model again to see the effects of changing the magnitude of the FEM loads. In addition, this factor may be useful to convert a non-constant amplitude load history data into the appropriate values</DIV>
<P>非常感谢!</P>
GMT+8, 2024-10-3 23:34 , Processed in 0.066421 second(s), 18 queries , Gzip On.
