查看: 3477|回复: 0
[Virtual.Lab] 这样的LOG文件表示什么意思
发表于 2006-6-3 22:00 | 显示全部楼层 |阅读模式
<P><FONT face=宋体>我做了个结构和声场耦合分析的例子,现在分析不出结果,LOG文件中提示如下,不知道什么意思,有人知道请帮忙看看<BR>Computing projected COUPLING matrix <BR> Verification of projected COUPLING matrix <BR> FLUID ROW     1 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW     2 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW     3 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW     4 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW     5 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW     6 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW     7 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW     8 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW     9 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> FLUID ROW    10 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     1 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     2 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     3 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     4 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     5 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     6 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     7 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     8 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL     9 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> STRUCTURE COL    10 OF PROJECTED COUPLING MATRIX IS ZERO ! <BR> Check for rigid body modes in modal basis ! <BR> CPU Stats --- Delta:  0:00:00 (      0.00)  Total:  0:05:53 (    352.95) <BR> <BR> Occupied space:   2341837 words  ( 23.42 %) </FONT></P>
GMT+8, 2025-1-30 05:05 , Processed in 0.059001 second(s), 17 queries , Gzip On.
