查看: 1521|回复: 2
[Virtual.Lab] VL这个错误怎么解决
发表于 2018-7-23 15:31 | 显示全部楼层 |阅读模式
求助大神,virtual。ERROR : GRAPH FILE JBB-1113131-Structure_samcef.u60  DOES NOT EXIST !
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
  !!! Please check the *_samcef.log or *_samcef_dy.res file for errors !!!
这是怎么了
发表于 2018-7-31 14:16 | 显示全部楼层
这个日志没法判断原因,还需要提供更多的模型信息。
GMT+8, 2024-11-17 17:37 , Processed in 0.067943 second(s), 18 queries , Gzip On.
