查看: 1664|回复: 1
[其他软件] 基于有限单元法的轮胎噪声计算实例分享
发表于 2018-7-11 16:15 | 显示全部楼层 |阅读模式
编者按:轮胎噪声属于学术难点之一,本文是一个基于有限单元法的轮胎噪声计算实例,其采用的是sysnoise软件,虽然sysnoise已经改版为Virtual.Lab,但是其内核没有变化,设置上有所调整,功能上有所增强,但是本文的基本分析思路仍然值得借鉴。
Step 1:Create a FEM fluid model
Start LMS Sysnoise
File->New.
  • Name: Tire
  • File: tire_ifem.sdb
Model->Option.
  • Select ‘FEM Frequency Fluid’
Step 2:Import the mesh
File->Import.
  • Set the Data Type to Mesh, Format to Free, click the FileBoxbutton to browse the CAR3DFEM.fre file.
Geometry->Check Mesh.
Step 3:Definition of face sets
Change the environment variable FEATRUEANGLE to 30
Geometry →Sets →Faces Selections
  • Click the button to select an element of tire profile
Repeat to create fem-ifeminterface set
Step 4:Definition of the infinite properties
Model →Infinite
Order:3
Envelope Type:Ellipsoidal
Orignin:(-0.318,0,0)
Vector 1(0.4,0,0)
Vector 2(0,0,-0.4)
Vector 3(0,0.1,0)
Model->Fluid Properties.
Accept the default values.
Step 5:Definition of the boundary condition
Model →Vibrating Panels →FEA.
  • First select the interface set, second set the frequency range to 20 to 400 linstep20 and the filename with displ.fre,thirdselect Use other file and tire_mesh.frefile
Step 6:Compute the acoustic field
Inquire → Fmaximum
Analysis → Parameters
Analysis → Solve
  • set the frequency range to 20 to 400 linstep20
Step 7:Import and process the field points
File →Import .
  • Set the Data Type to Point and Format to Free, Select the file ‘fp.fre’
Analysis →Process Fields Points
Step 8:Visualization of the results
PostProcess→ColorMap
本文根据LMS公司Li Zenggang的PPT整理而成
发表于 2018-7-16 10:47 | 显示全部楼层
谢谢分享,这个是比较老的sysnoise教程了,可以用同样的流程在Virtual.Lab里面计算。
GMT+8, 2024-11-17 17:55 , Processed in 0.098989 second(s), 21 queries , Gzip On.
