查看: 2344|回复: 0
The Second Announcement for ICDVC-2018
发表于 2018-1-15 10:13 | 显示全部楼层 |阅读模式
该信息已经过期
会议简介:
  ICDVC-2018, the 5th International Conference on Dynamics, Vibration and Control, will be held on July 28-30, 2018 in Shijiazhuang, China.
  Dynamics, vibration and control compose of an active sub-discipline of mechanics, and ICDVC-2018 is devoted to the significant research field.
  The aim of ICDVC-2018 is to bring together the international leading scientists of dynamics, vibration and control communities, both theoreticians and experimentalists, and to present their original research work of very high quality. The themes of the conference are intended to be broad enough so as to cover most of the directions in dynamics, vibration and control, promoting wide interactions among different academic disciplines. Mathematical theory, numerical simulation, physical experiments, engineering design, information technique, biological and financial studies, and other various applications are included in the main program of the conference. The conference also provides an excellent opportunity to researchers from different fields of science and engineering, both experts and new comers, for sharing ideas, experience and progress, and exploring new directions and problems among specialists in these fascinating subjects.
征稿主题:
  1. Nonlinear Dynamics
  Stability and Bifurcation
  Chaotic Dynamics
  Fractals in Dynamics
  Control and Synchronization of Complex Systems
  2. Vibration and Control
  Vibration Analysis of Discrete and/or Continuous Systems
  Passive and Active Vibration Control
  Signal Processing, Monitoring and Diagnostics
  Electromechanial Systems, Rotor Systems, and Other Engineering Application
  3. Multi-body Systems
  Modeling and Control of Multi-body Systems
  Contact and Impact Problems
  Numerical Simulations
  Experimental Investigations
  Engineering Applications
  4. Analytical Mechanics
  Systems with Constraints
  Symmetry and Conservation
  Birkhoffian Dynamics
  Mathematical Methods in Analytical Dynamics
  5. Stochastic Dynamics
  Theory and Methods of Nonlinear Stochastic Dynamics
  Response and Stability of Stochastic System
  Stochastic Bifurcation and Chaos
  Stochastic Nonsmooth System Dynamics
  Fractional-order Dynamics and Control
  6. Interdisciplinary Topics
  Neurodynamics
  Dynamics in Ecology, Epidemic and Environmental Sciences
  Dynamics of Biological Systems
  Economy and Finance Dynamics
  Micro-Systems, Micro-Structures and Nano-Systems
  Dynamics of Railroad Vehicles and Transportation Systems
  Spacecraft Dynamics and Control
  Fault Diagnosis and Condition Monitoring
GMT+8, 2025-8-1 05:03 , Processed in 0.076959 second(s), 20 queries , Gzip On.
