返回列表 发新帖
楼主: xlc
[Virtual.Lab] fluent计算后导出CGNS文件进行声学计算
发表于 2018-3-17 16:51 | 显示全部楼层
xlc 发表于 2018-3-14 16:00
设置过许多遍,电脑也换过,都报这个错误,但是先计算结构模态然后基于模态的声振耦合计算流致噪声是可以 ...
还是要看一下具体的计算日志。
xlc
SOLVE PARAMETERS MODEL: 1 - Exported VLModel ------------------------------------------------------------------------ PHYSICAL Coordinates Saving DISPLACEMENTS every 1 steps  详情 回复 发表于 2018-3-18 13:36
 楼主| 发表于 2018-3-18 13:36 | 显示全部楼层
lengxuef 发表于 2018-3-17 16:51
还是要看一下具体的计算日志。
SOLVE PARAMETERS
    Energy Calculation Enabled
    Surface post-processing on positive side
SOLVE PARALLEL OPTIONS
    Single Process with  4 Threads
LAUNCHING UNCOUPLED STRUCTURAL FEM (Physical Coords - Freq) ANALYSIS
CPU Stats --- Delta:  0:00:01 (      1.42)  Total:  0:00:01 (      1.42)
Performing Model Checks...
CPU Stats --- Delta:  0:00:00 (      0.00)  Total:  0:00:01 (      1.42)
  Running Bacon and Dynam ...
CPU Stats --- Delta:  0:00:57 (     57.28)  Total:  0:00:59 (     58.70)
Reading Graph File ...
CPU Stats --- Delta:  0:00:05 (      5.17)  Total:  0:01:04 (     63.87)
CPU Stats --- Delta:  0:00:00 (      0.11)  Total:  0:01:04 (     63.98)
SPARSITY PATTERN: MAX NUMBER OF NON-ZEROS       17404807
SPARSITY PATTERN: EFFECTIVE NUMBER OF NON-ZEROS        4033743
CPU Stats --- Delta:  0:00:01 (      0.90)  Total:  0:01:05 (     64.88)
Computing structural pressure field element matrices
CPU Stats --- Delta:  0:00:02 (      2.46)  Total:  0:01:07 (     67.34)
Performing prefrequency model calculations ...
CPU Stats --- Delta:  0:00:00 (      0.01)  Total:  0:01:07 (     67.35)
Performing constraints calculations ...
CPU Stats --- Delta:  0:00:03 (      2.66)  Total:  0:01:10 (     70.01)
This node (PC-20170912PDTC) has number 0
CPU Stats --- Delta:  0:00:01 (      1.19)  Total:  0:01:11 (     71.20)
COMPUTATION PROGRESS :       0 /    198                     (   0.00 % )
ANALYSIS NUMBER      1 /    198                FREQUENCY =     50.000 Hz
CPU Stats --- Delta:  0:00:00 (      0.00)  Total:  0:01:11 (     71.20)
Building sparse matrix of coefficients
CPU Stats --- Delta:  0:00:02 (      1.89)  Total:  0:01:13 (     73.09)
CPU Stats --- Delta:  0:00:00 (      0.00)  Total:  0:01:13 (     73.09)
Keeping  201021 degrees of freedom and    3973755 terms in profile
Analysis Phase ...
   Used Memory              =        0.200 Gb
   Available Memory         =        0.548 Gb
   Required Memory          =        1.364 Gb
        ( Including  20% safety margin )
   Not Enough Memory Available for IN-CORE solver
          Selecting OUT-OF-CORE Solver (OOC)
   Required Memory (OOC)    =        0.179 Gb
** Not Enough Memory to Run IN-CORE Solver **
**      Selecting OUT-OF-CORE solver       **
CPU Stats --- Delta:  0:00:01 (      1.34)  Total:  0:01:14 (     74.43)
Factorization Phase ...
   Effectively Used Memory  =        0.179 Gb
Assembling Structural Right-Hand-Side vector
Assembling structural pressure field RHS
A FATAL ERROR OCCURRED.  PROGRAM STOPPED
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
xlc
日志文件如上面所示,还有一个问题日志中的内存(如下图)部分指的是运行内存吗?电脑没运行多少程序可用内存应该很多的呀,怎么只有零点几  详情 回复 发表于 2018-3-18 13:44
 楼主| 发表于 2018-3-18 13:44 | 显示全部楼层
xlc 发表于 2018-3-18 13:36
SOLVE PARAMETERS
发表于 2018-3-19 20:46 | 显示全部楼层
SOLVE PARAMETERS
这个日志看可能是载荷方面的问题。重新检查下载荷吧。
另外,你电脑本身内存就不大,再并行,每个核心计算的时候,可以使用的内存更少了。
xlc
是在计算流致振动噪声,载荷没办法检查,  详情 回复 发表于 2018-3-21 20:25
 楼主| 发表于 2018-3-21 20:25 | 显示全部楼层
另外,你电脑本身内存就不大,再并行,每个核心计 ...
是在计算流致振动噪声,载荷没办法检查,设置并行的话会在工作站上计算,我只是试验一下--
发表于 2018-4-11 11:05 | 显示全部楼层
请问楼主,cgns导出后的声学计算,频率分析范围和分辨率跟什么有关??跟fluent输出频率和时间步有关系吗?
xlc
有的,根据采样定理,2倍时间步长分之一即分析范围,1/(时间步长*时间步数)即分辨率  详情 回复 发表于 2018-4-26 18:19
 楼主| 发表于 2018-4-26 18:19 | 显示全部楼层
发表于 2018-5-5 09:34 | 显示全部楼层
在VL的Help里搜一下FFT,按照那个公式计算一下你的时域步长,总时间就行了.
发表于 2019-3-2 13:03 | 显示全部楼层
主任请教一下,fluent导出cgns文件坐标系跟CFD网格坐标系发生了偏移,不是重合的,请问怎么解决
回复 支持 1 反对 0
发表于 2019-9-13 18:12 | 显示全部楼层
CFD里面设置局部坐标系了?
发表于 2020-2-14 21:40 | 显示全部楼层
lengxuef 发表于 2018-1-29 20:11
静止壁面的部分,设置成运动壁面,速度为0。试一下。
你好,麻烦问一下fluent计算的偶极子数据导入vl中一直出错不知道为什么,希望指点一下?是fluent版本问题吗
发表于 2020-8-18 15:54 | 显示全部楼层
请问您后来是怎么解决“fluent导出cgns文件坐标系跟CFD网格坐标系发生了偏移不重合”这个问题的?我现在也遇到了同样的问题。。
GMT+8, 2025-7-15 20:49 , Processed in 0.097200 second(s), 20 queries , Gzip On.
