查看: 2281|回复: 3
[综合讨论] [求助]求取频响函数并分析的问题!!
发表于 2006-5-27 20:12 | 显示全部楼层 |阅读模式
简单的说就是把采集到的信号经过FFT后(得到Xi,Fi),
再进行自谱和互谱计算(GFX=Xi*Fi',GFF=Fi*Fi')
频响函数=GFX/GFF
最后的步骤是截取频响函数的前半部分
请问怎样编程才能实现截取前半部分?下面是上面说的简单的编城,有不少错误哈,高手忍一下,下面要怎样才能实现----截取前半部分????
  1. clc
  2. N=1000;
  3. n=0:N-1;
  4. Xk=fft(xn); %xn是采集到的响应信号
  5. Fk=fft(fn); %fn是采集到的激励信号
  6. GFX=(Fk').'*Xk;
  7. FK=(Fk').'
  8. GFX=Xk.*FK;
  9. GFF=Fk.*FK;
  10. TXF=GFX./GFF;
  11. plot(,); %画这个幅频曲线要怎么画?
谢谢各位了
[ 本帖最后由 happy 于 2006-11-6 18:10 编辑 ]
发表于 2006-11-6 17:48 | 显示全部楼层
  1. clc
  2. close
  3. Fs = 1000;          % Sampling frequency
  4. T = 1/Fs;             % Sampling time
  5. x;                         % x is excitation signal
  6. y;                         % y is response signal
  7. L = Fs*t_time;     % Length of signal
  8. NFFT = 2^nextpow2(L);     % Next power of 2 from length of signal
  9. X = fft(x,NFFT)/FsL;           % fft translation of x
  10. Y = fft(y,NFFT)/FsL;          % fft translation of y
  11. H = (Y.*conj(X))./(X.*conj(X));     % FRF
  12. f = Fs/2*linspace(0,1,NFFT/2);     % x axis
  13. plot(f,abs(H(1:NFFT/2)));              % plot FRF
如有错误,或更好的方法,欢迎讨论
skynew2005@gmail.com
发表于 2006-11-7 12:30 | 显示全部楼层
如果有多组数据
% 如果要处理很多数据,就要把数据分段,分别作变换后,平均。
% 比如,要做400Hz内的频响,分辨率为1600线,即需要800Hz的采样频率,4分钟的测量数据,共3200个测量点。
% 用函数来实现作频响。
clc
close
clear
t_time = 10;
Fs = 800;
[t,x_state,y_out] = sim('tt_1',[0,t_time]);
x = y_out(:,1);      % excitation data
y = y_out(:,2);      % response data
span = Fs/2;        % span of fft
lines = 6400;       % lines of fft
L_data = lines*2;   % 每一段的数据长度
L_n = round(length(y)/L_data); % 总数据共分段数
for kk = 1:L_n
    x_s = x(L_data*(kk-1)+1:min(L_data*kk,length(x)));
    y_s = y(L_data*(kk-1)+1:min(L_data*kk,length(y)));
    [f,H_s(kk,:)] = cal_data_FRF(x_s,y_s,span,lines);
for kk = 1:length(H_s(1,:))
    H(kk) = mean(H_s(:,kk));
plot(f,H)
function [f,H] = cal_data_FRF(x,y,span,lines)
% calculate the frequency response function of the experiment data
% x, is the excitation signal
% y, is the response signal
% span, is the span of frequency of FFT ,for exzample 400,800,1600...
% lines, is the resolving of the FFT
Fs = span*2;          % Sampling frequency
L = lines*2;        % Length of signal
X = fft(x,NFFT)/L;          % fft translation of x
Y = fft(y,NFFT)/L;          % fft translation of y
HH = (Y.*conj(X))./(X.*conj(X));    % FRF
H = abs(HH(1:NFFT/2));              % y axis
有时候做出的曲线不光滑,大家一般怎么处理的?
欢迎讨论
发表于 2006-11-10 14:45 | 显示全部楼层
现在找到一种更好的方法
老版本的命令是tfe
新版本的命令是tfestimate
直接得出频响
计算效果很好
GMT+8, 2024-10-3 23:31 , Processed in 0.055032 second(s), 18 queries , Gzip On.
