查看: 1527|回复: 1
[原创]我做的压电陶瓷圆环谐响应分析
发表于 2006-5-26 16:37 | 显示全部楼层 |阅读模式
我试着做了一个压电陶瓷圆环的谐响应分析,结果出来没有曲线,大家帮忙看看哪里出问题了?<BR><BR>/BATCH  <BR>/COM,ANSYS RELEASE  9.0    UP20041104       15:33:11    05/26/2006<BR>/input,menust,tmp,'',,,,,,,,,,,,,,,,1   <BR>/GRA,POWER<BR>/GST,ON<BR>/PLO,INFO,3<BR>/GRO,CURL,ON<BR>/CPLANE,1   <BR>/REPLOT,RESIZE  <BR>WPSTYLE,,,,,,,,0<BR>/TITLE,harmonic <BR>/PREP7  <BR>!*  <BR>ET,1,SOLID5       :定义单元类型<BR>!*  <BR>KEYOPT,1,1,3<BR>KEYOPT,1,3,0<BR>KEYOPT,1,5,0<BR>!*  <BR>!*  <BR>MPTEMP,1,0          :定义材料属性<BR>MPDATA,DENS,2,,7500 <BR>TB,ANEL,2,1,21,0<BR>TBTEMP,0<BR>TBDATA,,1.39e+11,7.78e+10,7.43e+10,,,   <BR>TBDATA,,1.39e+11,7.43e+10,,,,1.15e+11   <BR>TBDATA,,,,,3.06e+10,,   <BR>TBDATA,,2.56e+10,,2.56e+10,,,   <BR>MPTEMP,,,,,,,,  <BR>MPTEMP,1,0  <BR>MPDATA,PERX,2,,6.4605e-09   <BR>MPDATA,PERY,2,,6.4605e-09   <BR>MPDATA,PERZ,2,,5.6198e-09   <BR>TB,PIEZ,2,,,0   <BR>TBMODIF,1,1,<BR>TBMODIF,1,2,<BR>TBMODIF,1,3,-5.20279<BR>TBMODIF,2,1,<BR>TBMODIF,2,2,<BR>TBMODIF,2,3,-5.20279<BR>TBMODIF,3,1,<BR>TBMODIF,3,2,<BR>TBMODIF,3,3,15.08041<BR>TBMODIF,4,1,<BR>TBMODIF,4,2,<BR>TBMODIF,4,3,<BR>TBMODIF,5,1,<BR>TBMODIF,5,2,12.71795<BR>TBMODIF,5,3,<BR>TBMODIF,6,1,12.71795<BR>TBMODIF,6,2,<BR>TBMODIF,6,3,<BR>!*  <BR>!*  <BR>K,1,,,, <BR>/VIEW,1,,,-1<BR>/ANG,1  <BR>/REP,FAST   <BR>/VIEW,1,,-1 <BR>/ANG,1  <BR>/REP,FAST   <BR>/VIEW,1,-1  <BR>/ANG,1  <BR>/REP,FAST   <BR>/VIEW,1,,-1 <BR>/ANG,1  <BR>/REP,FAST   <BR>K,2,0.01,,,          :建立实体模型<BR>K,3,0.028,,,<BR>K,4,0.028,,0.003,   <BR>K,5,0.01,,0.003,<BR>K,6,0,,0.003,   <BR>LSTR,       1,       2  <BR>LSTR,       2,       5  <BR>LSTR,       2,       3  <BR>LSTR,       3,       4  <BR>LSTR,       4,       5  <BR>LSTR,       5,       2  <BR>FLST,2,2,4,ORDE,2   <BR>FITEM,2,1   <BR>FITEM,2,-2  <BR>LDELE,P51X  <BR>LSTR,       5,       2  <BR>LSTR,       1,       6  <BR>FLST,2,4,4  <BR>FITEM,2,5   <BR>FITEM,2,1   <BR>FITEM,2,3   <BR>FITEM,2,4   <BR>AL,P51X <BR>FLST,2,1,5,ORDE,1   <BR>FITEM,2,1   <BR>FLST,8,2,3  <BR>FITEM,8,6   <BR>FITEM,8,1   <BR>VROTAT,P51X, , , , , ,P51X, ,360, , <BR>/VIEW,1,1,2,3   <BR>/ANG,1  <BR>/REP,FAST   <BR>SAVE<BR>FLST,5,4,6,ORDE,2   <BR>FITEM,5,1   <BR>FITEM,5,-4  <BR>CM,_Y,VOLU             :划分网格<BR>VSEL, , , ,P51X <BR>CM,_Y1,VOLU <BR>CHKMSH,'VOLU'   <BR>CMSEL,S,_Y  <BR>!*  <BR>VSWEEP,_Y1  <BR>!*  <BR>CMDELE,_Y   <BR>CMDELE,_Y1  <BR>CMDELE,_Y2  <BR>!*  <BR>SAVE<BR>FINISH  <BR>/SOL<BR>!*  <BR>ANTYPE,3<BR>!*  <BR>!*  <BR>HROPT,FULL        :选择分析类型<BR>HROUT,OFF   <BR>LUMPM,0 <BR>!*  <BR>EQSLV,FRONT,1e-008, <BR>PSTRES,0<BR>!*  <BR>APLOT   <BR>SAVE<BR>SAVE<BR>FINISH  <BR>! /EXIT,ALL <BR>/BATCH  <BR>/COM,ANSYS RELEASE  9.0    UP20041104       15:45:40    05/26/2006<BR>/input,menust,tmp,'',,,,,,,,,,,,,,,,1   <BR>/GRA,POWER<BR>/GST,ON<BR>/PLO,INFO,3<BR>/GRO,CURL,ON<BR>/CPLANE,1   <BR>/REPLOT,RESIZE  <BR>WPSTYLE,,,,,,,,0<BR>RESUME,'file','db','C:\DOCUME~1\林\',0,0<BR>/COM,ANSYS RELEASE  9.0    UP20041104       15:45:49    05/26/2006<BR>/SOLU   <BR>!*  <BR>ANTYPE,3<BR>!*  <BR>!*  <BR>HROPT,FULL  <BR>HROUT,OFF   <BR>LUMPM,0 <BR>!*  <BR>EQSLV,FRONT,1e-008, <BR>PSTRES,0<BR>!*  <BR>APLOT   <BR>/VIEW,1,,,-1<BR>/ANG,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/VIEW,1,,,1 <BR>/ANG,1  <BR>/REP,FAST   <BR>FLST,2,4,5,ORDE,4   <BR>FITEM,2,2   <BR>FITEM,2,7   <BR>FITEM,2,12  <BR>FITEM,2,17  <BR>/GO <BR>!*  <BR>DA,P51X,VOLT,1,      :正极加电压1v<BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>/ANG,1,30,YS,1  <BR>/REP,FAST   <BR>FLST,2,4,5,ORDE,4   <BR>FITEM,2,2   <BR>FITEM,2,9   <BR>FITEM,2,14  <BR>FITEM,2,19  <BR>/GO <BR>!*  <BR>DA,P51X,VOLT, ,         :负极加电压0v<BR>HARFRQ,58000,61000,     :设置扫频范围<BR>NSUBST,40,              :设置40个子步<BR>KBC,1   <BR>!*  <BR>/STATUS,SOLU           :求解<BR>SOLVE   <BR>FINISH  <BR>/POST26 <BR>FILE,'file','rst','.'   <BR>/UI,COLL,1  <BR>NUMVAR,200  <BR>SOLU,191,NCMIT  <BR>STORE,MERGE <BR>PLCPLX,0<BR>PRCPLX,1<BR>FILLDATA,191,,,,1,1 <BR>REALVAR,191,191 <BR>!*  <BR>!*  <BR>!*  <BR>NSOL,2,1494,U,X,<BR>!*  <BR>PLVAR,2, , , , , , , , , ,  <BR>PLVAR,2, , , , , , , , , ,  <BR>/DIST,1,0.924021086472,1<BR>/REP,FAST   <BR>/DIST,1,0.924021086472,1<BR>/REP,FAST   <BR>SAVE<BR>FINISH  <BR>! /EXIT,NOSAV   <BR>
发表于 2006-5-27 07:11 | 显示全部楼层
回复:(米兰之光)[原创]我做的压电陶瓷圆环谐响应分...
log中有什么提示信息吗?
GMT+8, 2025-1-16 11:12 , Processed in 0.081277 second(s), 17 queries , Gzip On.
