查看: 1323|回复: 0
2016国际管道会议
发表于 2016-6-15 10:00 | 显示全部楼层 |阅读模式
学术会议
会议名称: The International Pipeline Conference 2016
所属学科: 一般力学与力学基础,机械学,石油与天然气工程及钻采工程
会议类型: 国际会议
论文是否检索: 不详
开始时间: 2016-09-26
结束时间: 2016-09-30
会议地点: The Hyatt Regency Hotel & The TELUS Convention Centre, Calgary, Alberta, Canada
主办单位: Canadian Energy Pipeline Association (CEPA)
承办单位:
摘要截稿时间:
全文截稿时间:
联系人: Christi Marcine
联系电话: 4036514364
电子邮件: cmarcine@ipcyyc.com
通讯地址:
邮编: -
网址: http://www.ipcyyc.com/
背景介绍:
      In September 2016, members of the pipeline industry from around the world will gather in Calgary for the 11th International Pipeline Conference (IPC 2016). Organized by volunteers representing international energy corporations, energy and pipeline associations and regulatory agencies, the IPC has become internationally renowned as the world's premier pipeline conference. This is a not-for-profit conference and proceeds continue to support educational initiatives and research in the pipeline industry.
      The conference will begin on Monday, September 26, with tutorial offerings in key areas of interest. Technical Track sessions will begin the morning of Tuesday, September 27, and run through to Friday, September 30.
      The International Pipeline Conference is designed to inform, enlighten and motivate, therefore we encourage you to actively participaye in IPC 2016-five days of exceptional value, which you won't want to miss!
征文范围:
      Track 1:Pipelines Safety Management Systems
      Safety and Loss Management, Safety Culture, Leadership Accountability and Policy, Management Review and Audits, Training and Competency, Regulatory Lifecycle, Quality Management, Risk Management Framwork, Management of Change, Process and Personal Safety, Incident Investigation and Lessons Learned, Stakeholder Engagement, Comparsion of Regulations and Standards, Integrating Safety, Environment and Emergency Management Programs, Industry Practices.
      Track 2:Project Management, Design, Construction & Environmental Issues
      Team Leadership, Effective Communication, Collaboration, Joint Ventures, High Value Engineering, System Planning (Hydraulics), Design, Routing, Survey, Logistics, Construction, Geotechnical, Quality Control and Quality Assurance, Testing, Commissioning, Coatings, Compressor and Pump Stations, Termianls, Pigging Facilities, Valves, Piping Stress Analysis, Change of Service, Abandonment, Satelling Imaging and Remote Sensing, Field and Inspection Data Management, Geomatics, Global Positioning System Applications, Environmental Case Studies, Socioeconomic Studies, Community Involvement, Permitting Strategies, Reclamation, Mitigation, Abandonment, Land Issues, Emissions, Hydrotesting Fluids, Remediation, Environmental Impact Assessments, Cumulative Effects Assessment, Route Selecting, Monitoring
      Track 3:Pipelines & Facilities Integrity
      Hazard and Treat Identification, Engineering Assessments, Mitigation, Inline Inspection Technology, External Corrosion and Control, Cathodic Protection, Internal Corrosion and Control, Coatings, Environmental Stress Corrosion and Fatigue Cracking, Mechanical Damage, Tanks, Pumps, Compressor Stations, Station Piping, Field and Inspection Data Management, Geographical Information Systems, Defect Detection and Assessment, Tethered and Robotic Inspection Tools, Inspection Data Management, Inspection Intervals and Scheduling, Measuring Corrosion Growth Rates, Reliability, Field NDE for ILI Data Validation
      Track 4:Operations Monitoring & Maintenance
      Applications of Technology, Operating Experience, Preventative-Maintenance Techniques, Lifecycle Engineering, Operating Equipment Optimization, Useful Life Extensions, Operating Cost Reductions, Vendor Alliances, Geohazard Management, SCADA, Communications, Automations,Control Devices, Instrumentation, Sensor Technology, Measurement and Matering, Hydraulic Simulations, Leak Detection, Operations, Simulation and Trainers, Field and Inspection Data and Records Management, Hydrostatic Testing, Geohazard Management (incl. geotechnical, hydrotechnical, and seismmic ground movements/forces), Characterization, Monitoring, Mitigation
      Track 5:Materials & Joining
      Materials Design, High Strength Steels, Fracture Toughness Requirements, Welding, Properties of Girth Welds, Weld Flaw Acceptance Criteria, Hot Tapping, Machanical Joining, Joining Alternative Materials, Quality Control and Quality Assurance, Pipe Manufacture, Fittings, Nondestructive Examination
      Track 6:Strain Based Design
      Strain Demand, Charaterization of Hazards, Methods for Estimating Strain Demand (in-situ, ILI, pipe-soil interaction), High performance pipi and fittings for high strain demand, Welding and Inspection for High Strain Applications, Tensile Strain Capacity, Compressive Strain Capacity, Small and Large Sacle Tests for Material Characterization and Strain Capacity Determination, Project Experience and Lessons Learned in Strain Based Design, Regulatory Needs and Gaps
      Track 7:Risk & Reliability
      Risk Assessment, Qualitative and Quantitative Risk Modelling, Risk Based Maintenance Planning, Reliability Based Design and Assessment, Failure Date Analysis and Failure Rate Estimation, Failure Consequence Modelling, Risk Tolerance Criteria and Reliability Targets, Pipeline Security, Database Design
      Track 8:Northern, Offshore & Production Pipelines
      Emerging Technologies, Working in Permafrost, Stability of Frozen Slopes, Frost Heave, Thaw Settlement, Thermal Modelling, Logistics, Engineering in Cold Regions, Rapid Lake Drainage, Satellite Imaging and Remote Sensing, GPS Applications, Effects of Climate Change on Northern Pipelines to Offshore Pipelines, Flexible Pipeline Applications, Ice Scour, Infrastructure and Logistics Issues
GMT+8, 2025-7-10 08:44 , Processed in 0.101730 second(s), 24 queries , Gzip On.
