查看: 1496|回复: 0
第五届移动,适应性和快速组装结构国际会议
发表于 2016-5-31 09:51 | 显示全部楼层 |阅读模式
学术会议
会议名称: 5th International Conference on Mobile, Adaptable and Rapidly Assembled Structures
所属学科: 一般力学与力学基础,固体力学,土木工程,工程力学
会议类型: 国际会议
论文是否检索: 不详
开始时间: 2016-09-21
结束时间: 2016-09-24
会议地点: Siena, Italy
主办单位: Wessex Institute of Technology, UK Vrije Universiteit Brussels, Belgium
承办单位:
摘要截稿时间:
全文截稿时间:
联系人: Priscilla Cook
联系电话: 4402380293223
电子邮件: pcook@wessex.ac.uk
通讯地址:
邮编: -
网址: http://www.wessex.ac.uk/conferences/2016/maras-2016
会议介绍:
      Structures that move in the course of normal use, or which have to be assembled or erected rapidly on a relatively umprepared site, offer a particular challenge to the designer. The interaction between the structure and the mechanism by which it moves is essential in these caser.The speed of assembly, and what this means in therms of logistics,materials and cost, is a major factor in many such structures.
      Mobile and rapidly assembled structures play a major role in disaster mitigation and temporary accommodation. They are of primary importance in many military as well as civilian applications and are widely uesd for rescue and maintenance services. Their importance continues to grow in contemporary society where speed of response is of primary importance. Also, in many cases, their reversible deployment and potential reuse can lead to a lower economical and ecological impact,providing a more sustainable solution. There are common problems such as the efficient design of assembly joints, the resistance to damage of the membrane and metal cladding, crashworthiness and the limits of serviceability. Some areas of the subject are already well documented, but knowledge is fragmented and there is little design guidance available in the form of textbooks, data sheets or codes of practice.
      The interaction between morphology, kinematic behaviour and structural performance--typical of these structures--poses real challenges in terms of design and successful realisation. The interaction of ideas and experience during the conference may lead to new mobile structural forms and an increased awareness of the problems of rapid assembly and mobility of structures. This multi-disciplinary meeting will bring together engineers,architects and researchers concerned with the design, analysis,manufacturing and erection of rapidly assembled strucyures. This fifth edition follows the success of the previous conferences in this series, first organised in Southampton, followed by Seville, Madrid and Ostend.
征文范围:
      Rapidly assembled and mobile bridges
      Disaster mitigation structures
      Temporary structures and dwellings
      Deployable systems and structural mechanisms
      Tensegrity and reciprocal frames
      Origami-based folding structures
      Inflated and air-supported structures and membrane shelters
      Rapidly assembled kit-of-parts systems
      Leisure structuresm,demountable grandstands and scaffolding systems
      Mobile inspection platforms
      Folding and telescopic masts and gangways
      Tower cranes and mobile lifting apparatus
      Trackways and prefabricated paving for roads and airfields
      Protective structures
      Zero gravity structures
      Construction and repair
      Optimisation of transformable structures
      Kinetic structures
      Dedign for re-use
      Adaptive building envelopes
      Parametric analysis and design
      Innovative approaches
      Engineering transformation
GMT+8, 2025-7-10 10:12 , Processed in 0.089964 second(s), 24 queries , Gzip On.
