查看: 2437|回复: 0
[综合讨论] matlab编译器相关问题
发表于 2016-5-16 13:08 | 显示全部楼层 |阅读模式
解决办法:
1、确认安装有VC
2、如果安装有VC,在出现
Please choose your compiler for building external interface (MEX) files:
Would you like mex to locate installed compilers [y]/n?
的时候输入n
3、此时会列出matlab支持的编译器
[1] Intel C++ 9.1 (with Microsoft Visual C++ 2005 SP1 linker)
[2] Intel Visual Fortran 10.1 (with Microsoft Visual C++ 2005 SP1 linker)
[3] Intel Visual Fortran 9.1 (with Microsoft Visual C++ 2005 SP1 linker)
[4] Lcc-win32 C 2.4.1
[5] Microsoft Visual C++ 6.0
[6] Microsoft Visual C++ .NET 2003
[7] Microsoft Visual C++ 2005 SP1
[8] Microsoft Visual C++ 2008 Express
[9] Microsoft Visual C++ 2008 SP1
[10] Open WATCOM C++
[0] None
选择安装的VC版本(我装的是VS2005)
5、选择完成之后,会要求指定VC的安装目录
The default location for Microsoft Visual C++ 2005 SP1 compilers is C:\Program Files\Microsoft Visual Studio 8,
but that directory does not exist on this machine.
Use C:\Program Files\Microsoft Visual Studio 8 anyway [y]/n?
如果安装目录是自动搜索到的目录C:\Program Files\Microsoft Visual Studio 8 anyway,则输入y,否则输入n,然后手动输入VC安装目录
转自:http://blog.sina.com.cn/s/blog_64b046c701018dtk.html
GMT+8, 2025-7-29 15:15 , Processed in 0.092408 second(s), 25 queries , Gzip On.
