查看: 2695|回复: 0
[编程技巧] matlab如何写一个类
发表于 2016-5-13 10:26 | 显示全部楼层 |阅读模式
  1. <font face="Times New Roman">classdef TensileData
  2.    properties
  3.       Material = 'carbon steel';
  4.       SampleNumber = 0;
  5.       Stress
  6.       Strain
  7.    end
  8.    properties (Dependent)
  9.       Modulus
  10.    end
  11.
  12.    methods
  13.       function td = TensileData(material,samplenum,stress,strain)
  14.          if nargin > 0
  15.             td.Material = material;
  16.             td.SampleNumber = samplenum;
  17.             td.Stress = stress;
  18.             td.Strain = strain;
  19.          end
  20.       end % TensileData
  21.    end
  22.
  23.    methods
  24.       function obj = set.Material(obj,material)
  25.          if ~(strcmpi(material,'aluminum') ||...
  26.                strcmpi(material,'stainless steel') ||...
  27.                strcmpi(material,'carbon steel'))
  28.             error('Material must be aluminum, stainless steel, or carbon steel')
  29.          end
  30.          obj.Material = material;
  31.       end % Material set function
  32.
  33.       function modulus = get.Modulus(obj)
  34.          ind = find(obj.Strain > 0); % Find nonzero strain
  35.          modulus = mean(obj.Stress(ind)./obj.Strain(ind));
  36.       end % Modulus get function
  37.
  38.       function obj = set.Modulus(obj,~)
  39.          fprintf('%s%d\n','Modulus is: ',obj.Modulus)
  40.          error('You cannot set Modulus explicitly');
  41.       end
  42.
  43.       function disp(td)
  44.          fprintf(1,'Material: %s\nSample Number: %g\nModulus: %1.5g\n',...
  45.             td.Material,td.SampleNumber,td.Modulus);
  46.       end % disp
  47.
  48.       function plot(td,varargin)
  49.          plot(td.Strain,td.Stress,varargin{:})
  50.          title(['Stress/Strain plot for Sample ',num2str(td.SampleNumber)])
  51.          xlabel('Strain %')
  52.          ylabel('Stress (psi)')
  53.       end % plot
  54.    end
  55.
  56.    methods (Access = 'private') % Access by class members only
  57.       function m = CalcModulus(td)
  58.          % Over-simplified calculation of Elastic Modulus
  59.          ind = find(td.Strain > 0); % Find nonzero strain
  60.          m = mean(td.Stress(ind)./td.Strain(ind));
  61.       end % CalcModulus
  62.    end
  63. end % classdef
  64. 在上述代码中,
  65. classdef TensileData
  66.   ...
  67. end
  68. 是定义一个TensileData类。代码:
  69. properties
  70.       Material = 'carbon steel';
  71.       SampleNumber = 0;
  72.       Stress
  73.       Strain
  74.    end
  75. 是定义这个类的属性,也就是C++中类的成员变量。但是和C++不同的是,matlab中的类定义还有一个比较特别的地方的,就是定义依赖属性,如下述代码:
  76. properties (Dependent)
  77.       Modulus
  78.    end
  79. 这表示Modulus这个属性是个依赖属性,它的值是通过其他属性计算得到的,其中Dependent的默认属性值为True。
  80. 它的值是通过下面函数实现的:
  81. % Modulus get function
  82. function modulus = get.Modulus(obj)
  83.          ind = find(obj.Strain > 0); % Find nonzero strain
  84.          modulus = mean(obj.Stress(ind)./obj.Strain(ind));
  85. end
  86. 类的方法(函数)的定义是以methods ... end的的形式出现的。如下面的类方法的定义:
  87. methods
  88.       function td = TensileData(material,samplenum,stress,strain)
  89.          if nargin > 0
  90.             td.Material = material;
  91.             td.SampleNumber = samplenum;
  92.             td.Stress = stress;
  93.             td.Strain = strain;
  94.          end
  95.       end
  96. end
  97. 该函数块定义了TensileData构造函数方法。上述代码中的最后一个方法 methods (Access = 'private')
  98. 中的Access = 'private'表示该方法仅能被类本身访问和修改,是个私有成员方法。其中属性Access又可分为
  99. SetAccess和GetAccess,属性值和Access相同。
  100. 在disp函数语句中出现“...”表示下一行和当前行是连接在一起的。如:
  101. function disp(td)
  102.          fprintf(1,'Material: %s\nSample Number: %g\nModulus: %1.5g\n',...
  103.             td.Material,td.SampleNumber,td.Modulus);
  104. end
  105. 就表示第二行和第三行是连在一起的。 </font>
转自:http://blog.sina.com.cn/s/blog_64b046c70101c315.html
GMT+8, 2025-7-28 09:05 , Processed in 0.098634 second(s), 21 queries , Gzip On.
