查看: 3840|回复: 0
ABAQUS运行出错问题
发表于 2016-5-7 16:48 | 显示全部楼层 |阅读模式
作为一个新手,实在是不知道怎么做了!附件是CAE文件,哪位大神帮我看下要怎么修改!!感激不尽!!!在运行之后老是出现
The sum of initial pressure and elastic tensile strength for the porous elastic material in element 201 instance soil-1 must be positive.
200 elements have been defined with zero hour glass stiffness. You may use *hourglass stiffness or change the element type. The elements have been identified in element set ErrElemZeroHourGlassStiffness.
When used with cam clay, porous elasticity must have a tensile limit of zero
Analysis Input File Processor exited with an error.
zhuang2.zip
85.94 KB, 下载次数: 1
GMT+8, 2025-7-26 15:39 , Processed in 0.089265 second(s), 22 queries , Gzip On.
