查看: 1008|回复: 0
[转帖]ANSYS SOLID65环向布置钢筋的例子
发表于 2006-5-22 05:15 | 显示全部楼层 |阅读模式
! ANSYS SOLID65环向布置钢筋的例子<BR>! 一个管道,环向配筋率为1%,纵向配筋率为0.5%,径向配筋率为0.1%! <BR>FINISH<BR>/CLEAR<BR>/PREP7 <BR>!* <BR>! 单元属性<BR>ET,1,SOLID65<BR>!* <BR>KEYOPT,1,1,0<BR>KEYOPT,1,5,0<BR>KEYOPT,1,6,0<BR>KEYOPT,1,7,1<BR>!* <BR>!实参数1:不同方向配筋<BR>R,1,2,.001, , ,2, .01, <BR>RMORE, 90, ,2,.005 ,90 ,90 , <BR>!材料属性<BR>!混凝土基本材料属性<BR>MPTEMP,,,,,,,, <BR>MPTEMP,1,0 <BR>MPDATA,EX,1,,30E2<BR>MPDATA,PRXY,1,,.2 <BR>!屈服准则 <BR>TB,MISO,1,1,5, <BR>TBTEMP,0<BR>TBPT,,0.0005,15<BR>TBPT,,0.001,21<BR>TBPT,,0.0015,24 <BR>TBPT,,0.002,27<BR>TBPT,,0.003,24<BR>!破坏准则 <BR>TB,CONC,1,1,9, <BR>TBTEMP,0<BR>TBDATA,,.5,.9,3,30,,<BR>TBDATA,,,,1,,, <BR>MPTEMP,,,,,,,, <BR>MPTEMP,1,0 <BR>!钢材基本属性<BR>MPDATA,EX,2,,200E3<BR>MPDATA,PRXY,2,,.27 <BR>!屈服准则<BR>TB,BISO,2,1,2, <BR>TBTEMP,0<BR>TBDATA,,310,2E3,,,, <BR>! 管道内径和外径<BR>CYL4,0,0,3000, , , ,10000 <BR>CYL4,0,0,2000, , , ,10000 <BR>VSBV, 1, 2 <BR>! 定义局部柱坐标<BR>CSWPLA,11,1,1,1,<BR>KWPAVE, 11 <BR>WPRO,,-90.000000, <BR>VSBW, 3 <BR>WPCSYS,-1,0 <BR>KWPAVE, 1 <BR>WPRO,,,-90.000000 <BR>VSBW,ALL<BR>ESIZE,500,0,<BR>! 注意:设定单元局部坐标<BR>VATT, 1, 1, 1, 11<BR>!* <BR>VSWEEP,ALL<BR>/DEVICE,VECTOR,1<BR>/ESHAPE,1.0<BR>/REPLO <BR>! 注意:红色代表最大配筋方向,绿色代表其次,蓝色表示最小配筋方向
GMT+8, 2025-1-16 14:10 , Processed in 0.074750 second(s), 17 queries , Gzip On.
