查看: 1548|回复: 0
带螺栓的支架结构分析时出现错误
发表于 2015-11-6 15:58 | 显示全部楼层 |阅读模式
The volume of 16 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
这个错误是怎么回事?
GMT+8, 2025-7-29 13:24 , Processed in 0.078767 second(s), 21 queries , Gzip On.
