查看: 1786|回复: 3
[编程技巧] matlab代码中特殊字符~的含义
发表于 2015-10-17 10:02 | 显示全部楼层 |阅读模式
下面程序中~符号代表什么意思?
  1. function [loss] = nneval(nn, loss, train_x, train_y, val_x, val_y)
  2. %NNEVAL evaluates performance of neural network
  3. % Returns a updated loss struct
  4. assert(nargin == 4 || nargin == 6, 'Wrong number of arguments');
  5. % training performance
  6. nn                    = nnff(nn, train_x, train_y);
  7. loss.train.e(end + 1) = nn.L;
  8. % validation performance
  9. if nargin == 6
  10.     nn                    = nnff(nn, val_x, val_y);
  11.     loss.val.e(end + 1)   = nn.L;
  12. end
  13. %calc misclassification rate if softmax
  14. if strcmp(nn.output,'softmax')
  15.     [er_train, ~]               = nntest(nn, train_x, train_y);
  16.     loss.train.e_frac(end+1)    = er_train;
  17.     if nargin == 6
  18.         [er_val, ~]             = nntest(nn, val_x, val_y);
  19.         loss.val.e_frac(end+1)  = er_val;
  20.     end
  21. end
  22. end
发表于 2015-10-19 09:45 | 显示全部楼层
这里这个~表示未使用的输入参数,它也可以用来表示一个被忽略的输出参数。
punct      - Ignore function argument or output ~
  ~   The tilde character can be used in function definitions to
      represent an input argument that is unused within the function.
      It can also be used to indicate that an output argument of a
      function call is to ignored.  In this case, it must appear
      within [ ] and separated by commas from any other arguments.
 楼主| 发表于 2015-10-20 10:01 | 显示全部楼层
原来如此,一直以为这个符号只有逻辑非的意思,谢谢
发表于 2015-11-9 13:37 | 显示全部楼层
較新版本的功能
GMT+8, 2025-8-11 11:36 , Processed in 0.068187 second(s), 21 queries , Gzip On.
