查看: 1615|回复: 0
[综合讨论] matlab中所有特殊字符的涵义及用途
发表于 2015-10-1 22:42 | 显示全部楼层 |阅读模式
  1. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">:        Create vectors, subscript arrays, specify for-loop iterations</span>
  2. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">( )        Pass function arguments, prioritize operators</span>
  3. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">[ ]        Construct array, concatenate elements, specify multiple outputs from function</span>
  4. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">{ }        Construct cell array, index into cell array</span>
  5. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">.        Insert decimal point, define structure field, reference methods of object</span>
  6. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">.( )        Reference dynamic field of structure</span>
  7. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">..        Reference parent directory</span>
  8. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">...        Continue statement to next line</span>
  9. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">,        Separate rows of array, separate function input/output arguments, separate commands</span>
  10. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">;        Separate columns of array, suppress output from current command</span>
  11. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">%        Insert comment line into code</span>
  12. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">%{ %}        Insert block of comments into code</span>
  13. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">!        Issue command to operating system</span>
  14. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">' '        Construct character array</span>
  15. <span style="font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 22.3999996185303px;">[url=home.php?mod=space&uid=156850]@[/url]        Construct function handle, reference class directory</span>
GMT+8, 2025-1-27 10:50 , Processed in 0.206959 second(s), 27 queries , Gzip On.
