查看: 3190|回复: 1
[Python] 贴一个Python的GUI程序,大家一起分享
发表于 2014-11-25 11:39 | 显示全部楼层 |阅读模式
import numpy as np
import wx
import matplotlib
matplotlib.interactive(False)
matplotlib.use('WXAgg')
from matplotlib.backends.backend_wxagg import FigureCanvasWxAgg
from matplotlib.figure import Figure
from matplotlib.pyplot import gcf, setp
class Knob:
    Knob - simple class with a "setKnob" method.
    A Knob instance is attached to a Param instance, e.g. param.attach(knob)
    Base class is for documentation purposes.
    def setKnob(self, value):
        pass
class Param:
    The idea of the "Param" class is that some parameter in the GUI may have
    several knobs that both control it and reflect the parameter's state, e.g.
    a slider, text, and dragging can all change the value of the frequency in
    the waveform of this example.
    The class allows a cleaner way to update/"feedback" to the other knobs when
    one is being changed.  Also, this class handles min/max constraints for all
    the knobs.
    Idea - knob list - in "set" method, knob object is passed as well
      - the other knobs in the knob list have a "set" method which gets
        called for the others.
    def __init__(self, initialValue=None, minimum=0., maximum=1.):
        self.minimum = minimum
        self.maximum = maximum
        if initialValue != self.constrain(initialValue):
            raise ValueError('illegal initial value')
        self.value = initialValue
        self.knobs = []
    def attach(self, knob):
        self.knobs += [knob]
    def set(self, value, knob=None):
        self.value = value
        self.value = self.constrain(value)
        for feedbackKnob in self.knobs:
            if feedbackKnob != knob:
                feedbackKnob.setKnob(self.value)
        return self.value
    def constrain(self, value):
        if value <= self.minimum:
            value = self.minimum
        if value >= self.maximum:
            value = self.maximum
        return value
class SliderGroup(Knob):
    def __init__(self, parent, label, param):
        self.sliderLabel = wx.StaticText(parent, label=label)
        self.sliderText = wx.TextCtrl(parent, -1, style=wx.TE_PROCESS_ENTER)
        self.slider = wx.Slider(parent, -1)
        self.slider.SetMax(param.maximum*1000)
        self.setKnob(param.value)
        sizer = wx.BoxSizer(wx.HORIZONTAL)
        sizer.Add(self.sliderLabel, 0, wx.EXPAND | wx.ALIGN_CENTER | wx.ALL, border=2)
        sizer.Add(self.sliderText, 0, wx.EXPAND | wx.ALIGN_CENTER | wx.ALL, border=2)
        sizer.Add(self.slider, 1, wx.EXPAND)
        self.sizer = sizer
        self.slider.Bind(wx.EVT_SLIDER, self.sliderHandler)
        self.sliderText.Bind(wx.EVT_TEXT_ENTER, self.sliderTextHandler)
        self.param = param
        self.param.attach(self)
    def sliderHandler(self, evt):
        value = evt.GetInt() / 1000.
        self.param.set(value)
    def sliderTextHandler(self, evt):
        value = float(self.sliderText.GetValue())
        self.sliderText.SetValue('%g'%value)
        self.slider.SetValue(value*1000)
class FourierDemoFrame(wx.Frame):
    def __init__(self, *args, **kwargs):
        wx.Frame.__init__(self, *args, **kwargs)
        self.fourierDemoWindow = FourierDemoWindow(self)
        self.frequencySliderGroup = SliderGroup(self, label='Frequency f0:', \
            param=self.fourierDemoWindow.f0)
        self.amplitudeSliderGroup = SliderGroup(self, label=' Amplitude a:', \
            param=self.fourierDemoWindow.A)
        sizer = wx.BoxSizer(wx.VERTICAL)
        sizer.Add(self.fourierDemoWindow, 1, wx.EXPAND)
        sizer.Add(self.frequencySliderGroup.sizer, 0, \
            wx.EXPAND | wx.ALIGN_CENTER | wx.ALL, border=5)
        sizer.Add(self.amplitudeSliderGroup.sizer, 0, \
        self.SetSizer(sizer)
class FourierDemoWindow(wx.Window, Knob):
        wx.Window.__init__(self, *args, **kwargs)
        self.lines = []
        self.figure = Figure()
        self.canvas = FigureCanvasWxAgg(self, -1, self.figure)
        self.canvas.callbacks.connect('button_press_event', self.mouseDown)
        self.canvas.callbacks.connect('motion_notify_event', self.mouseMotion)
        self.canvas.callbacks.connect('button_release_event', self.mouseUp)
        self.state = ''
        self.mouseInfo = (None, None, None, None)
        self.f0 = Param(2., minimum=0., maximum=6.)
        self.A = Param(1., minimum=0.01, maximum=2.)
        self.draw()
        # Not sure I like having two params attached to the same Knob,
        # but that is what we have here... it works but feels kludgy -
        # although maybe it's not too bad since the knob changes both params
        # at the same time (both f0 and A are affected during a drag)
        self.f0.attach(self)
        self.A.attach(self)
        self.Bind(wx.EVT_SIZE, self.sizeHandler)
    def sizeHandler(self, *args, **kwargs):
        self.canvas.SetSize(self.GetSize())
    def mouseDown(self, evt):
        if self.lines[0] in self.figure.hitlist(evt):
            self.state = 'frequency'
        elif self.lines[1] in self.figure.hitlist(evt):
            self.state = 'time'
        else:
            self.state = ''
        self.mouseInfo = (evt.xdata, evt.ydata, max(self.f0.value, .1), self.A.value)
    def mouseMotion(self, evt):
        if self.state == '':
            return
        x, y = evt.xdata, evt.ydata
        if x is None:  # outside the axes
            return
        x0, y0, f0Init, AInit = self.mouseInfo
        self.A.set(AInit+(AInit*(y-y0)/y0), self)
        if self.state == 'frequency':
            self.f0.set(f0Init+(f0Init*(x-x0)/x0))
        elif self.state == 'time':
            if (x-x0)/x0 != -1.:
                self.f0.set(1./(1./f0Init+(1./f0Init*(x-x0)/x0)))
    def mouseUp(self, evt):
        self.state = ''
    def draw(self):
        if not hasattr(self, 'subplot1'):
            self.subplot1 = self.figure.add_subplot(211)
            self.subplot2 = self.figure.add_subplot(212)
        x1, y1, x2, y2 = self.compute(self.f0.value, self.A.value)
        color = (1., 0., 0.)
        self.lines += self.subplot1.plot(x1, y1, color=color, linewidth=2)
        self.lines += self.subplot2.plot(x2, y2, color=color, linewidth=2)
        #Set some plot attributes
        self.subplot1.set_title("Click and drag waveforms to change frequency and amplitude", fontsize=12)
        self.subplot1.set_ylabel("Frequency Domain Waveform X(f)", fontsize = 8)
        self.subplot1.set_xlabel("frequency f", fontsize = 8)
        self.subplot2.set_ylabel("Time Domain Waveform x(t)", fontsize = 8)
        self.subplot2.set_xlabel("time t", fontsize = 8)
        self.subplot1.set_xlim([-6, 6])
        self.subplot1.set_ylim([0, 1])
        self.subplot2.set_xlim([-2, 2])
        self.subplot2.set_ylim([-2, 2])
        self.subplot1.text(0.05, .95, r'X(f)=F{x(t)}', \
            verticalalignment='top', transform = self.subplot1.transAxes)
        self.subplot2.text(0.05, .95, r'x(t)=acos(2πf0t)eπt2', \
            verticalalignment='top', transform = self.subplot2.transAxes)
    def compute(self, f0, A):
        f = np.arange(-6., 6., 0.02)
        t = np.arange(-2., 2., 0.01)
        x = A*np.cos(2*np.pi*f0*t)*np.exp(-np.pi*t**2)
        X = A/2*(np.exp(-np.pi*(f-f0)**2) + np.exp(-np.pi*(f+f0)**2))
        return f, X, t, x
    def repaint(self):
        self.canvas.draw()
        # Note, we ignore value arg here and just go by state of the params
        setp(self.lines[0], xdata=x1, ydata=y1)
        setp(self.lines[1], xdata=x2, ydata=y2)
        self.repaint()
class App(wx.App):
    def OnInit(self):
        self.frame1 = FourierDemoFrame(parent=None, title="Fourier Demo", size=(640, 480))
        self.frame1.Show()
        return True
app = App()
app.MainLoop()
发表于 2015-3-28 12:52 | 显示全部楼层
直接 pyGui ...
GMT+8, 2025-6-4 08:46 , Processed in 0.075236 second(s), 18 queries , Gzip On.
