查看: 1020|回复: 1
这是vibinfo的一个程序,运行有一个错误,望指出,谢谢
发表于 2006-5-15 14:55 | 显示全部楼层 |阅读模式
这是vibinfo的一个程序,运行有一个错误,望指出,谢谢!<BR>!这是一个金属容器装满水,用桐木做保护包装,由1.2米处摔下的接触碰撞计算,水被分配到容器壁上,为减少计算时间,从木包装接触地面计算开始,到容器反弹时结束。 <BR><BR>!金属容器木质包装的撞击 <BR>KEYW,LSDYNA,1 <BR>/PREP7 <BR>/view,,1,2,3 <BR>/plopts,info,1 <BR>/pbc,all,1 <BR>/pnum,mat,1 <BR>/num,1 <BR>ET,1,SHELL163 <BR>KEYOPT,1,1,6 <BR>KEYOPT,1,2,0 <BR>KEYOPT,1,3,0 <BR>KEYOPT,1,4,0, <BR>ET,2,SOLID164 <BR><BR>! --- 输入金属容器材料参数 <BR>mp,ex,1,1.86e11 <BR>mp,nuxy,1,0.29 <BR>mp,dens,1,45435 <BR>r,1 <BR>rmodif,1,1,,,0.006,,,, <BR><BR>! --- 输入木材材料参数 <BR>MP,DENS,2,500 <BR>MP,EX,2,1.5e8 <BR>MP,NUXY,2,0.2 <BR>TB,BISO,2,,,, <BR>TBDAT,1,2.5e6 <BR>TBDAT,2, <BR><BR>! --- 生成并划分容器(1/8)网格 <BR>CSWPLA,11,1,297/597,1, <BR>CSYS,11, <BR>K,,0.597,,, <BR>K,,0.597,-45,, <BR>K,,0.597,-90,, <BR>L,1,2 <BR>L,2,3 <BR>CSYS,0, <BR>k,,0.597,0.45, <BR>k,5000,0,0.1, <BR>k,6000,0,-0.1, <BR>l,5000,6000 <BR>l,1,4 <BR>FLST,2,3,4,ORDE,3 <BR>FITEM,2,1 <BR>FITEM,2,-2 <BR>FITEM,2,4 <BR>FLST,8,2,3 <BR>FITEM,8,6000 <BR>FITEM,8,5000 <BR>AROTAT,P51X,,,,,,P51X,,90,, <BR>LESIZE,1,,,6,,,,,1 <BR>LESIZE,2,,,10,,,,,1 <BR>LESIZE,4,,,10,,,,,1 <BR>LESIZE,5,,,10,,,,,1 <BR>LESIZE,6,,,6,,,,,1 <BR>LESIZE,7,,,10,,,,,1 <BR>LESIZE,8,,,10,,,,,1 <BR>LESIZE,9,,,10,,,,,1 <BR>LESIZE,10,,,10,,,,,1 <BR>amesh,1,3,1 <BR><BR>! --- 生成并划分木盒(1/8)网格 <BR>block,0,1,-0.7,0.18,-1,0 <BR>CSWPLA,11,1,0.5,1, <BR>CSYS,11, <BR>K,,0.6,,, <BR>K,,0.6,-45,, <BR>K,,0.6,-90,, <BR>L,16,17 <BR>L,17,18 <BR>CSYS,0 <BR>k,,0.6,0.45, <BR>l,16,19 <BR>FLST,2,3,4,ORDE,2 <BR>FITEM,2,23 <BR>FITEM,2,-25 <BR>FLST,8,2,3 <BR>FITEM,8,6000 <BR>FITEM,8,5000 <BR>AROTAT,P51X,,,,,,P51X,,90,, <BR>FLST,3,3,5,ORDE,2 <BR>FITEM,3,10 <BR>FITEM,3,-12 <BR>VSBA,1,P51X !-------布尔操作的警告信息 <BR>VDELE,2,,,1 <BR>! ----为网格划分分割体 <BR>K,7000,0.5,-0.8,, <BR>K,7001,1.5,-0.25,, <BR>!-------创建两条分割线 <BR>FLST,2,2,3 <BR>FITEM,2,17 <BR>FITEM,2,7000 <BR>FLST,3,1,8 <BR>FITEM,3,0.42,-0.4,0 <BR>BSPLIN,P51X,P51X <BR>FLST,2,2,3 <BR>FITEM,2,17 <BR>FITEM,2,7001 <BR>FLST,3,1,8 <BR>FITEM,3,0.6,-0.28,0 <BR>BSPLIN,P51X,P51X <BR>! ----分割体 <BR>ADRAG,17,,,,,,29 <BR>ADRAG,18,,,,,,29 <BR>VSBA,3,5 <BR>VSBA,2,7 <BR>wprot,,-90 <BR>VSBW,4 <BR>! ---- 网格划分 <BR>TYPE,2 <BR>MAT,2 <BR>LESIZE,24,,,10,,,,,1 <BR>LESIZE,26,,,10,,,,,1 <BR>LESIZE,29,,,10,,,,,1 <BR>LESIZE,40,,,10,,,,,1 <BR>AMESH,10 <BR>VSWEEP,1 <BR>ACLEAR,10 <BR>LESIZE,28,,,6,,,,,1 <BR>LESIZE,47,,,6,,,,,1 <BR>LESIZE,23,,,6,,,,,1 <BR>LESIZE,35,,,4,,,,,1 <BR>VSWEEP,3 <BR>VSWEEP,2 <BR>VSWEEP,5 <BR>LDELE,3,,,1 <BR>ALLSEL,ALL <BR>NUMMRG,ALL,,,,LOW <BR>NUMCMP,ALL <BR>APLOT <BR><BR>! --- A正撞---复制单元(还有计算其它的撞法.....) <BR>wpoff,,,0.45 <BR>CSWPLA,11,0,1,1, <BR>CSYS,11, <BR>ASEL,S,MAT,,1 <BR>ARSYM,X,all,,,,0,0 <BR>ARSYM,y,all,,,,0,0 <BR>ARSYM,z,all,,,,0,0 <BR>VSEL,S,MAT,,2 <BR>VSYMM,X,all,,,,0,0 <BR>VSYMM,y,all,,,,0,0 <BR>ALLSEL,ALL <BR>NUMMRG,ALL,,,,LOW <BR>NUMCMP,ALL <BR>CSYS,0, <BR>CSDELE,11,,1, <BR>WPSTYLE,,,,,,,,0 <BR>EPLOT <BR>    <BR>! ---- 定义接触组合 <BR>esel,s,mat,,1 <BR>nsle <BR>cm,ncase,node <BR>cm,ecase,elem <BR>esel,s,mat,,2 <BR>nsle <BR>cm,nwood,node <BR>cm,ewood,elem <BR>FLST,5,12,5,ORDE,12 <BR>FITEM,5,10 <BR>FITEM,5,-11 <BR>FITEM,5,14 <BR>FITEM,5,48 <BR>FITEM,5,54 <BR>FITEM,5,64 <BR>FITEM,5,67 <BR>FITEM,5,73 <BR>FITEM,5,82 <BR>FITEM,5,86 <BR>FITEM,5,91 <BR>FITEM,5,98 <BR>ASEL,S, , ,P51X <BR>NSLA,R,1 <BR>CM,target,NODE <BR>ALLSEL,ALL <BR>EPLOT <BR><BR>! --- 定义容器加速度及初始速度 <BR>EDVE,VELO,ncase,0,-4.85,0,0,0,0,,,,,, <BR>EDVE,VELO,nwood,0,-4.85,0,0,0,0,,,,,, <BR>*DIM,time,ARRAY,2,1,1, , , <BR>*DIM,accc,ARRAY,2,1,1, , , <BR>*SET,TIME(1,1,1),0 <BR>*SET,TIME(2,1,1),1 <BR>*SET,ACCC(1,1,1),9.8 <BR>*SET,ACCC(2,1,1),9.8 <BR>EDLOAD,ADD,ACLY,0,ncase,TIME,ACCC,0,,,,, <BR>EDLOAD,ADD,ACLY,0,nwood,TIME,ACCC,0,,,,, <BR><BR>! --- 定义木盒的约束 <BR>nsel,s,loc,y,-0.7 <BR>d,all,,0,,,,uy <BR>nsel,s,loc,Y,-0.7 <BR>nsel,r,loc,X,0 <BR>nsel,r,loc,Z,-1 <BR>d,all,ux,0,,,,, <BR>nsel,s,loc,Y,-0.7 <BR>nsel,r,loc,X,0 <BR>nsel,r,loc,Z,1 <BR>d,all,ux,0,,,,, <BR>nsel,s,loc,Y,-0.7 <BR>nsel,r,loc,X,0 <BR>nsel,r,loc,Z,0 <BR>d,all,ux,0,,,,,uz <BR><BR>! --- 在容器与木盒之间定义的面面接触 <BR>edcgen,asts,ncase,target,0,0,0,0,0, , , , ,0,10000000 <BR>edcontact,1.0,,,,,,2,,0 <BR><BR>! --- 为后处理建立单元组合half <BR>NSEL,S,LOC,Z,-0.0001,-1 <BR>ESLN,S <BR>CM,half,ELEM <BR>nsel,all <BR>esel,all <BR><BR>! --- 计算输出设置 <BR>/solu <BR>time,0.0045 !计算时间 <BR>edrst,50 !输出文件数 <BR>edhtime,500 <BR>EDDUMP,1, <BR>EDENERGY,1,1,1,1 <BR>ALLSEL,ALL <BR>eplot <BR><BR>! --- 计算 <BR>FINISH <BR>/SOLU <BR>/STAT,SOLU <BR>SOLVE<BR>
 楼主| 发表于 2006-5-15 16:21 | 显示全部楼层
[em06]
GMT+8, 2025-2-19 14:20 , Processed in 0.106635 second(s), 17 queries , Gzip On.
