查看: 4646|回复: 15
[小波] 小波熵图如何获取
发表于 2014-3-11 08:50 | 显示全部楼层 |阅读模式
本人利用小波变换得到一段信号的小波时频图,直观但是没有确切数字,想通过小波熵图表征信号的变化,求教大侠求小波熵图的程序,多谢~
发表于 2014-3-11 09:39 | 显示全部楼层
  1. function [estimate,nbias,sigma,descriptor]=entropy(x,descriptor,approach,base)
  2. %ENTROPY   Estimates the entropy of stationary signals with
  3. %          independent samples using various approaches.
  4. %   [ESTIMATE,NBIAS,SIGMA,DESCRIPTOR] = ENTROPY(X) or
  5. %   [ESTIMATE,NBIAS,SIGMA,DESCRIPTOR] = ENTROPY(X,DESCRIPTOR) or
  6. %   [ESTIMATE,NBIAS,SIGMA,DESCRIPTOR] = ENTROPY(X,DESCRIPTOR,APPROACH) or
  7. %   [ESTIMATE,NBIAS,SIGMA,DESCRIPTOR] = ENTROPY(X,DESCRIPTOR,APPROACH,BASE)
  8. %
  9. %   ESTIMATE    : The entropy estimate
  10. %   NBIAS       : The N-bias of the estimate
  11. %   SIGMA       : The standard error of the estimate
  12. %   DESCRIPTOR  : The descriptor of the histogram, seel alse ENTROPY
  13. %
  14. %   X           : The time series to be analyzed, a row vector
  15. %   DESCRIPTOR  : Where DESCRIPTOR=[LOWERBOUND,UPPERBOUND,NCELL]
  16. %     LOWERBOUND: Lowerbound of the histogram
  17. %     UPPERBOUND: Upperbound of the histogram
  18. %     NCELL     : The number of cells of the histogram
  19. %   APPROACH    : The method used, one of the following ones:
  20. %     'unbiased': The unbiased estimate (default)
  21. %     'mmse'    : The minimum mean square error estimate
  22. %     'biased'  : The biased estimate
  23. %   BASE        : The base of the logarithm; default e
  24. %
  25. %   See also: http://www.cs.rug.nl/~rudy/matlab/
  26. %   R. Moddemeijer
  27. %   Copyright (c) by R. Moddemeijer
  28. %   Revision:1.1  Date:2001/02/0508:59:36
  29. if nargin <1
  30.    disp('Usage: [ESTIMATE,NBIAS,SIGMA,DESCRIPTOR] = ENTROPY(X)')
  31.    disp('       [ESTIMATE,NBIAS,SIGMA,DESCRIPTOR] = ENTROPY(X,DESCRIPTOR)')
  32.    disp('       [ESTIMATE,NBIAS,SIGMA,DESCRIPTOR] = ENTROPY(X,DESCRIPTOR,APPROACH)')
  33.    disp('       [ESTIMATE,NBIAS,SIGMA,DESCRIPTOR] = ENTROPY(X,DESCRIPTOR,APPROACH,BASE)')
  34.    disp('Where: DESCRIPTOR = [LOWERBOUND,UPPERBOUND,NCELL]')
  35.    return
  36. end
  37. % Some initial tests on the input arguments
  38. [NRowX,NColX]=size(x);
  39. if NRowX~=1
  40.   error('Invalid dimension of X');
  41. end;
  42. if nargin>4
  43.   error('Too many arguments');
  44. end;
  45. if nargin==1
  46.   [h,descriptor]=histogram(x);
  47. end;
  48. if nargin>=2
  49.   [h,descriptor]=histogram(x,descriptor);
  50. end;
  51. if nargin<3
  52.   approach='unbiased';
  53. end;
  54. if nargin<4
  55.   base=exp(1);
  56. end;
  57. lowerbound=descriptor(1);
  58. upperbound=descriptor(2);
  59. ncell=descriptor(3);
  60. estimate=0;
  61. sigma=0;
  62. count=0;
  63. for n=1:ncell
  64.   if h(n)~=0
  65.     logf=log(h(n));
  66.   else
  67.     logf=0;
  68.   end;
  69.   count=count+h(n);
  70.   estimate=estimate-h(n)*logf;
  71.   sigma=sigma+h(n)*logf^2;
  72. end;
  73. % biased estimate
  74. estimate=estimate/count;
  75. sigma   =sqrt( (sigma/count-estimate^2)/(count-1) );
  76. estimate=estimate+log(count)+log((upperbound-lowerbound)/ncell);
  77. nbias   =-(ncell-1)/(2*count);
  78. % conversion to unbiased estimate
  79. if approach(1)=='u'
  80.   estimate=estimate-nbias;
  81.   nbias=0;
  82. end;
  83. % conversion to minimum mse estimate
  84. if approach(1)=='m'
  85.   estimate=estimate-nbias;
  86.   nbias=0;
  87.   lambda=estimate^2/(estimate^2+sigma^2);
  88.   nbias   =(1-lambda)*estimate;
  89.   estimate=lambda*estimate;
  90.   sigma   =lambda*sigma;
  91. end;
  92. % base transformation
  93. estimate=estimate/log(base);
  94. nbias   =nbias   /log(base);
  95. sigma   =sigma   /log(base);
回复 支持 1 反对 0
 楼主| 发表于 2014-3-11 10:21 | 显示全部楼层
你奏是活雷锋啊~我自己先跑跑看,非常感谢啊!
 楼主| 发表于 2014-3-11 14:53 | 显示全部楼层
喔哦,出现问题解决不好了,我定义了entropy函数,然后输入值load‘X.txt’
entropy(X)
提示错误??? Undefined function or method 'histogram' for input arguments of type
'double'.
Error in ==> entropy at 55
请女侠赐教
发表于 2014-3-12 10:54 | 显示全部楼层
缺少函数:
  1. function [result,descriptor]=histogram(x,descriptor)
  2. %HISTOGRAM Computes the frequency histogram of the row vector x.
  3. %   [RESULT,DESCRIPTOR] = HISTOGRAM(X) or
  4. %   [RESULT,DESCRIPTOR] = HISTOGRAM(X,DESCRIPTOR) or
  5. %where
  6. %   DESCRIPTOR = [LOWER,UPPER,NCELL]
  7. %
  8. %   RESULT    : A row vector containing the histogram
  9. %   DESCRIPTOR: The used descriptor
  10. %
  11. %   X         : The row vector be analyzed
  12. %   DESCRIPTOR: The descriptor of the histogram
  13. %     LOWER   : The lowerbound of the histogram
  14. %     UPPER   : The upperbound of the histogram
  15. %     NCELL   : The number of cells of the histogram
  16. %
  17. %   See also: http://www.cs.rug.nl/~rudy/matlab/
  18. %   R. Moddemeijer
  19. %   Copyright (c) by R. Moddemeijer
  20. %   Revision:1.2  Date:2001/02/0509:54:29
  21. if nargin <1
  22.    disp('Usage: RESULT = HISTOGRAM(X)')
  23.    disp('       RESULT = HISTOGRAM(X,DESCRIPTOR)')
  24.    disp('Where: DESCRIPTOR = [LOWER,UPPER,NCELL]')
  25.    return
  26. end
  27. % Some initial tests on the input arguments
  28. [NRowX,NColX]=size(x);
  29. if NRowX~=1
  30.   error('Invalid dimension of X');
  31. end;
  32. if nargin>2
  33.   error('Too many arguments');
  34. end;
  35. if nargin==1
  36.   minx=min(x);
  37.   maxx=max(x);
  38.   delta=(maxx-minx)/(length(x)-1);
  39.   ncell=ceil(sqrt(length(x)));
  40.   descriptor=[minx-delta/2,maxx+delta/2,ncell];
  41. end;
  42. lower=descriptor(1);
  43. upper=descriptor(2);
  44. ncell=descriptor(3);
  45. if ncell<1
  46.   error('Invalid number of cells')
  47. end;
  48. if upper<=lower
  49.   error('Invalid bounds')
  50. end;
  51. result(1:ncell)=0;
  52. y=round( (x-lower)/(upper-lower)*ncell + 1/2 );
  53. for n=1:NColX
  54.   index=y(n);
  55.   if index >= 1 & index<=ncell
  56.     result(index)=result(index)+1;
  57.   end;
  58. end;
 楼主| 发表于 2014-3-19 08:37 | 显示全部楼层
再次感谢啊!不过我不懂编程,看不懂程序,倒是求出来每段数据的熵值了,只是想获得的是以数据点数为横坐标,熵值为纵坐标的图,比如,一维数据有2000个数字,那横坐标就是0~2000,纵坐标为每个点对应的小波熵值,,或者是每n个点求一次熵值,刚接触到数据分析这块,不怎么了解,多有麻烦~
发表于 2014-3-24 14:10 | 显示全部楼层
粤语残片 发表于 2014-3-19 08:37
再次感谢啊!不过我不懂编程,看不懂程序,倒是求出来每段数据的熵值了,只是想获得的是以数据点数为横 ...
不明白你的意思
 楼主| 发表于 2014-3-24 16:05 | 显示全部楼层
 楼主| 发表于 2014-8-29 11:12 | 显示全部楼层
您好,想请教您一个基本的小程序,就是小波熵尺度熵的算法,算法是这样的,求出一段数据多尺度小波系数矩阵,行表示数据个数,列表示尺度序列长度,然后求矩阵一列各小波系数的平方和,而该列各小波系数的平方除以平方和就是该小波系数的概率p,代入公式s=-p*log(p),然后将这一列的s求和即为该列小波熵,依次求出每列小波熵,绘制这段数据的熵图,希望麻烦您给编一下,我自己编的为clc;
clear all;
load 'f320010110yeweibodon.txt';
%t1=f320000929(:,1);
y1=f320010110yeweibodon(:,1);
t1=2:2:954;
%figure(1);
subplot(211);
plot(t1,y1);
%axis([0 1000,0 80]);
%set(gca, 'Fontname', 'Times newman', 'Fontsize', 12)
%xlabel('Time(s)');ylabel('Friction force(kN)');
wavename='shan2-3';
      totalscal=512;                    %尺度序列的长度,即scal的长度
      wcf=centfrq(wavename);            %小波的中心频率
      cparam=2*wcf*totalscal;           %为得到合适的尺度所求出的参数
      a=totalscal:-1:256;
      Scales=cparam./a;                   %得到各个尺度,以使转换得到频率序列为等差序列
%%%%%%%%%%%%%计算小波熵%%%%%%%%%%%%%%%%%
WT=cwt(y1,Scales,wavename); %对数据进行连续小波变换
n=length(Scales);
h=length(y1);
for i=1:h
      for j=1:n;
          E(j)=0;
      E(j)=E(j)+abs(WT(j,i))^2;
      %求第i个节点的范数平方,其实也就是平方和
E_total=sum(E);  %求总能量
for i=1:h
      for j=1:n;
      e(j)=abs(WT(j,i))^2;
      P(j)= e(j)/E_total  ;
      m(j)=-(P(j)*log(P(j)));
      s(i)=sum(m)
%以下计算小波熵,即-sum(pj*lnpj),
%disp('小波熵的值s(j)');
%for i=1:h
  %m(i)=-(P(i)*log(P(i)));
%end
%S_wt=sum(m);
%S_wt
subplot(212);
plot(t1,s);
感觉不对,谢谢了啊~
发表于 2014-11-1 21:13 | 显示全部楼层
额   shannon小波熵是不是指能量熵奥??shan2-3这个是什么意思奥??谢谢
 楼主| 发表于 2014-11-13 17:16 | 显示全部楼层
这个,我也是菜鸟,熵的类型是依据算法来定的,结合小波特性来使用,2-3表示的是带宽和中心频率,其实说具体了我也说不好
发表于 2014-11-14 20:56 | 显示全部楼层
粤语残片 发表于 2014-11-13 17:16
这个,我也是菜鸟,熵的类型是依据算法来定的,结合小波特性来使用,2-3表示的是带宽和中心频率,其实说 ...
谢谢 能不能推荐几本关于小波熵的书 嘿 怎么提取实部奥
回复 支持 0 反对 1
发表于 2014-12-12 11:48 | 显示全部楼层
粤语残片 发表于 2014-8-29 11:12
您好,想请教您一个基本的小程序,就是小波熵尺度熵的算法,算法是这样的,求出一段数据多尺度小波系数矩 ...
for i=1:h    for j=1:n;
      s(i)=sum(m)
楼主,你的尺度熵中循环中  m(j)=-(P(j)*log(P(j)))得到的一个点的在所有尺度上的能量熵,最后得到熵m(j)是各点在所有尺度上的熵和,不是一个尺度上所有点的熵和。我觉得是应该改成 for j=1:n;   for i=1:h
不知道我说的对不对
 楼主| 发表于 2014-12-15 13:53 | 显示全部楼层
恩恩,谢谢你~我也觉得算的有问题
发表于 2014-12-27 21:22 | 显示全部楼层
小波熵的介绍在胡昌华老师书籍里有
GMT+8, 2025-7-31 07:13 , Processed in 0.077113 second(s), 21 queries , Gzip On.
