查看: 3589|回复: 2
[Python] Scipy和Numpy中的特征值函数的效率
发表于 2014-2-14 17:26 | 显示全部楼层 |阅读模式
http://forum.vibunion.com/thread-123356-1-1.html 中Rainyboy讨论了Scipy和Numpy里特征值分解函数的适用范围。碰巧我前段时间也看过相关的内容,讲一讲这块的几个函数的性能吧!
照理来说,Scipy和Numpy里的特征值分解都进行了很强的优化,速度和Matlab的特征值分解是一致的,当然和C或者Fortran的速度也是一致的的,因为用得是相同的函数库。是不是这样呢?+
在我的机器上的运算结果是这样的:
In [2]:
size=1000
size
Out[2]:
1000
In [3]:
%%timeit
A=np.random.random((size,size))
100 loops, best of 3: 12 ms per loop
In [4]:
B=np.random.random((size,1))
In [5]:
%%timeit
A.dot(B)
10000 loops, best of 3: 106 μs per loop
In [6]:
%%timeit
A.dot(A)
10 loops, best of 3: 26.9 ms per loop
In [7]:
A=A.dot(A.T)
In [8]:
%timeit np.linalg.eig(A)
1 loops, best of 3: 1.04 s per loop
In [9]:
%timeit np.linalg.eigh(A)
10 loops, best of 3: 159 ms per loop
In [10]:
%timeit np.linalg.eigvals(A)
1 loops, best of 3: 552 ms per loop
In [11]:
%timeit np.linalg.eigvalsh(A)
10 loops, best of 3: 72.5 ms per loop
In [12]:
%timeit sp.linalg.eig(A)
1 loops, best of 3: 994 ms per loop
In [13]:
%timeit sp.linalg.eigh(A)
10 loops, best of 3: 177 ms per loop
In [14]:
%timeit sp.linalg.eigvals(A)
1 loops, best of 3: 553 ms per loop
In [15]:
%timeit sp.linalg.eigvalsh(A)
10 loops, best of 3: 75.3 ms per loop
In [16]:
%timeit sp.linalg.eigvals_banded(A)
1 loops, best of 3: 889 ms per loop
In [17]:
%timeit sp.linalg.eig_banded(A)
1 loops, best of 3: 1.14 s per loop
同样在Matlab里等效的代码:
size=1000;
disp('Random:');
tic; A=rand(size);toc
b=rand(size,1);
disp('Matrix dot Vector:');
tic; A*b; toc
disp('Matrix dot Matrix:');
tic; A*A; toc
A=A*A';
disp('Eig:');
tic;[e,v]=eig(A);toc
disp('Eigvalue:');
tic;e=eig(A);toc
Random:
Elapsed time is 0.012240 seconds.
Matrix dot Vector:
Elapsed time is 0.011468 seconds.
Matrix dot Matrix:
Elapsed time is 0.045180 seconds.
Eig:
Elapsed time is 0.148208 seconds.
Eigvalue:
Elapsed time is 0.065679 seconds.
把size提升到5000,结果是这样的:
Random:
Elapsed time is 0.259863 seconds.
Matrix dot Vector:
Elapsed time is 0.010714 seconds.
Matrix dot Matrix:
Elapsed time is 2.755659 seconds.
Eig:
Elapsed time is 17.550121 seconds.
Eigvalue:
Elapsed time is 12.204438 seconds.
对应的Python的结果是:
size=5000
size
Out[48]:
5000
In [49]:
%%timeit
1 loops, best of 3: 294 ms per loop
In [50]:
In [51]:
%%timeit
A.dot(B)
100 loops, best of 3: 9.58 ms per loop
In [52]:
%%timeit
A.dot(A)
1 loops, best of 3: 2.73 s per loop
In [53]:
A=A.dot(A.T)
In [54]:
1 loops, best of 3: 1min 49s per loop
In [55]:
1 loops, best of 3: 17.3 s per loop
In [56]:
1 loops, best of 3: 45.8 s per loop
In [57]:
1 loops, best of 3: 11.7 s per loop
In [58]:
1 loops, best of 3: 1min 47s per loop
In [59]:
1 loops, best of 3: 20.3 s per loop
In [60]:
1 loops, best of 3: 47.3 s per loop
In:%timeit sp.linalg.eigvalsh(A)1 loops, best of 3: 12.5 s per loop
结论很明显了,我先不总结了,大家先讨论讨论吧。统计一下重要的时间:
SizeMatlabPython
eig eigvalueM dot VM dot Mrandnp.eignp.eighnp.eigvalsnp.eigvalshsp.eigsp.eighM dot VM dot Mrand
1000148.2165.6811.4745.1812.24104015955272.5994177
0.106
26.9
12
500017550.1212204.4410.712755.66259.8611900017300458001170011700020300
9.58
2730
294
PS:排版很困难啊,怎么回事?直接上纯文本吧!
发表于 2014-2-17 20:36 | 显示全部楼层
在使用中确实有这个问题,随着规模的增大,python那几个库函数算得很慢了。
 楼主| 发表于 2014-2-17 21:12 | 显示全部楼层
应该没有这个问题,Matlab可以自动检测矩阵是不是对称的,虽然我不确定它是怎么做到的,但是从计算结果来看Matlab确实使用了矩阵是对称的条件(放一个非对称阵进去,Matlab就会自动用非对称阵的算法,完全不知道是怎么办到的)。Scipy和Numpy里必须显式的告诉特征值函数矩阵是对称的,求解速度才能上来,如果使用对应一般矩阵的算法就会很慢。
GMT+8, 2025-8-8 12:32 , Processed in 0.079523 second(s), 21 queries , Gzip On.
