查看: 2579|回复: 0
[Patran专区] 求助!Use Edit/Surface/Edge Match to close the gaps
发表于 2013-12-7 20:31 | 显示全部楼层 |阅读模式
A Gap exists between two of the faces in the Body.  This may be due to edges not matching directly or a missing face.  Edges are highlighted. Use Edit/Surface/Edge Match to close the gaps, then use Create/Solid/Brep to create the solid.
自学Patran2010与Nastran2010有限元分析从入门到精通,第82页,iges导入的文件,生成实体的时候提示有空隙,无法生成,求问怎么解决!!!
GMT+8, 2025-6-22 07:34 , Processed in 0.107342 second(s), 22 queries , Gzip On.
