查看: 4069|回复: 2
[综合讨论] 关于matlab中phase函数和angle函数的区别
发表于 2013-9-7 15:13 | 显示全部楼层 |阅读模式
我用两种算法计算一个多输入多输出模型的传递函数得到结果(两组复数序列,分别对应两种算法的结果,分别记作H1_ij,Hv_ij,),分别对比两组复数序列实部和虚部,发现都能完全吻合。当用phase函数分别求这两组复数序列的相位时,发现当ij不同时,phase(H1_ij)和phase(Hv_ij)有时同相,有时相位差2pi,而angle(H1_ij)和angle(Hv_ij)则计算出的结果始终完全吻合。因此向各位大侠请教phase函数和angle函数的区别,望不吝赐教,谢谢回复!
发表于 2013-9-17 09:35 | 显示全部楼层
1.若有附加图形可能别人比较容易了解LZ说的问题
2.详看下help, 应该会有说明
3.若想进一步了解并确定, 或许可以直接看下该函数(使用edit)
4.google下, ref: http://stackoverflow.com/questio ... e-command-in-matlab
赞成: 0.0
赞成: 0
3Q!元老提供的第4条中说的太清楚不过了,谢谢!  发表于 2013-9-18 10:09
发表于 2013-9-18 23:02 | 显示全部楼层
想想应该直接贴上好像比较好
Matlab help for phase
PHASE  Computes the phase of a complex vector
    PHI=phase(G)
    G is a complex-valued row vector and PHI is returned as its
    phase (in radians), with an effort made to keep it continuous
    over the pi-borders.Matlab help for angle
ANGLE  Phase angle.
    ANGLE(H) returns the phase angles, in radians, of a matrix with
    complex elements.
    Class support for input X:
       float: double, single
At first, ANGLE command is from MATLAB core, PHASE from system identification toolbox.
ANGLE command always give result in range [-pi, pi].
PHASE command is more complex. If you have two adjacent points in input vector with phase near pi, for example
X=[-1+0.1i -1-0.1i]phase(X) command will give answer greater than pi for the second value (difference between phases values should be less than pi).
At this time angle(X) command will give value near -pi for the second argument (wrap values into range [-pi, pi]). E.g.
phase(X(2)) = angle(X(2)) + 2*pi
赞成: 5.0
赞成: 5
好!  发表于 2013-9-19 20:25
GMT+8, 2025-8-8 14:49 , Processed in 0.100586 second(s), 22 queries , Gzip On.
