查看: 2083|回复: 1
[综合讨论] 关于ansys warning
发表于 2013-9-5 15:05 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =       8.237   TIME= 20:49:51
For material 1, the value of permittivity (PERX) is less than 1.0, and
will be interpreted as absolute permittivity (i.e., as input) by the
elements of type 5.
*** WARNING ***                         CP =       8.362   TIME= 20:49:53
The modal analysis has non-zero displacements defined, which will cause
a load vector to be generated.  The load vector may be used by the
mode superposition analyses.  This feature is not documented.
在做模态分析时出现的警告,不懂哪里有问题,请教诸位帮忙解答,万分感谢!
发表于 2013-10-23 17:04 | 显示全部楼层
我的也出现过,感觉好像是建模太复杂了,超出了ansys的计算范围 反正当时我设置算3阶,但是由于模型太复杂,算了一晚上也没有出来,都算到10几阶了
GMT+8, 2025-7-29 02:50 , Processed in 0.076932 second(s), 18 queries , Gzip On.
