查看: 2583|回复: 1
新手求助
发表于 2006-5-9 18:19 | 显示全部楼层 |阅读模式
Simulink编译时出错提示The specified Real-Time Workshop target cannot be used with a variable-step solver. You must configure the solver options for a fixed-step solver with an appropriate integration algorithm (press Open).<BR>和Error executing build command: Error using ==&gt; make_rtw<BR>Error using ==&gt; make_rtw (ConfigForTLC)<BR>The system target file is configured for RT whereas first is configured for NRT<BR>是怎么回事怎么解决
 楼主| 发表于 2006-5-9 18:20 | 显示全部楼层
回复:(clockking)新手求助
编译Demo里面的例子也一样,不知道咋回事求救达人
GMT+8, 2025-2-21 01:04 , Processed in 0.070458 second(s), 18 queries , Gzip On.
