查看: 8498|回复: 24
分享 - 振动:解析和试验模态分析 - R.J.Allemang编著
发表于 2013-2-10 03:45 | 显示全部楼层 |阅读模式
  下面的讲义是辛辛那提大学 R.J.Allemang编著的试验模态分析方面的入门资料——
  VIBRATIONS: ANALYTICAL AND EXPERIMENTAL MODAL ANALYSIS
  振动:解析和试验模态分析
  是我见过的最好的试验模态分析入门资料之一。作为在论坛的第一帖,特别分享给大家。
  R.J.Allemang是试验模态分析领域的牛人。
  如感兴趣,可以从下面的这个链接看看其简历:
  http://www.sdrl.uc.edu/Members/randy/randall-j-allemang-phd
  VIBRATIONS:
  Dr. Randall J. Allemang, Professor
  Structural Dynamics Research Laboratory
  Department of Mechanical, Industrial and Nuclear Engineering
  University of Cincinnati
  Cincinnati, Ohio 45221-0072
  February 1999
  Approved for public release
  Copyright 1990-1999 UC-SDRL
  All Rights Reserved
  振动:
  解析和试验模态分析
  兰德尔 J. 阿莱芒博士,教授 编著
  结构动力学研究实验室
  机械,工业与核工程系
  辛辛那提大学
  辛辛那提,俄亥俄45221-0072
  1999年1月
  准予公开发行
  版权 1990-1999 UC-SDRL保留所有权利
  下面摘录一点前言 和 简介部分:
  PREFACE前言
  An initial version of the following set of notes was originally prepared by Dave Formenti in 1977 for use in a short course at the University of Cincinnati on the subject of "Experimental Modal Analysis". The notes have since been rewritten several times to standardize the notation and add further clarification and additional topics by several authors including, R. J. Allemang, R. W. Rost, T. J. Severyn, and J. M. Leuridan, for use in other short courses and the dual level Mechanical Vibrations II (20-263-662) course at the University of Cincinnati.
  下面这套笔记最早是在1977年由大卫.佛门兹准备,用于辛辛那提大学的一个以“试验模态分析”为主题的短训班。自此之后,这套讲义历经多次修改,对其中的符号进行了标准化,添加了更进一步的说明和其他主题,作者包括R. J. Allemang,R. W.Rost,T. J. Severyn和J. M. Leuridan,用于其他短训班以及辛辛那提大学的机械振动II(20-263-662)双级课程。
  1. INTRODUCTION简介
  The major point of the text is to show how frequency responsefunction (FRF) measurements are related to the structure’s mode shapes and vibrational frequencies. This overall objective will be accomplished by building a mathematical foundation from the analytical and experimental point of view.
  本讲义的重点,是说明频响函数(FRF)测量结果是如何与结构模态振型和振动频率建立联系的。将从解析和试验的角度,建立数学关系来达成这个总体目标。
  The material is divided into two sections: single degree of freedom, and multiple degree of freedom systems. The single degree of freedomsystem will be used as a means for definingsome standard terminology. The multiple degree of freedom materialis further divided into: undamped, proportionally damped, and non-proportionally damped systems. Throughout the discussion emphasis will be placed on the relationship of frequency response measurements to modal vectors. Furthermore, the following concepts will be presented:
  Modal Frequencies, Eigenvalues, System Poles, Characteristic Roots
  Modal Vectors, Eigenvectors
  Modal Coefficients, Residues
  Real Modal Vectors, Complex Modal Vectors
  Physical Coordinates, Generalized Coordinates
  Principal Coordinates, Modal coordinates
  Modal Mass, Damping, and Stiffness
  Modal A, Modal B
  这个材料分成两部分:单自由度系统和多自由度系统。借助于单自由度系统定义一些标准术语。将多自由度系统进一步分为:无阻尼、比例阻尼和非比例阻尼系统。贯穿始终,将讨论的重点放在频响测量结果与模态向量的关系上。与此同时,介绍了下面一些概念:
  模态频率、特征值、系统极点、特征根
  模态向量、特征向量
  模态系数、留数
  实模态向量、复模态向量
  物理坐标、广义坐标
  主坐标、模态坐标
  模态质量、模态阻尼和模态刚度
  模态A、模态B
  讲义下载地址:
  http://www.sdrl.uc.edu/academic- ... tions-ii-20-293-663
  不单有讲义,还有大量的matlab源码可供参考。
  http://www.sdrl.uc.edu/shareware-freeware/Shareware/VIBS2.zip
  http://www.sdrl.uc.edu/academic- ... /ucme662/index.html
  赞:老美的分享精神真是值得学习!
  补充内容 (2013-2-14 23:24):
  这个讲义的姊妹篇,R.J.Allemang教授编著的《VIBRATIONS:EXPERIMENTAL MODAL ANALYSIS振动:试验模态分析》见日记链接:http://home.vibunion.com/blog-199119-20738.html
《振动:解析与试验模态分析》全书中文翻译链接:http://www.chinaksi.com/resources/library/v2-ema  发表于 2018-5-30 14:37
发表于 2013-2-13 20:00 | 显示全部楼层
谢谢分享!
 楼主| 发表于 2013-2-14 23:26 | 显示全部楼层
VIBRATIONS:EXPERIMENTAL MODAL ANALYSIS 振动:试验模态分析
这个讲义的姊妹篇,R.J.Allemang教授编著的《VIBRATIONS:EXPERIMENTAL MODAL ANALYSIS 振动:试验模态分析》
发表于 2013-2-16 14:16 | 显示全部楼层
高质量共享
发表于 2013-3-12 16:27 | 显示全部楼层
学习了,多谢
发表于 2013-3-19 18:16 | 显示全部楼层
很好的资料
发表于 2013-11-22 12:44 | 显示全部楼层
谢谢分享,学习一下了
发表于 2013-12-3 21:12 | 显示全部楼层
顶一下,谢谢!
发表于 2014-2-22 11:15 | 显示全部楼层
楼主提供的资料太好了。谢谢楼主,感谢分享。
发表于 2014-2-25 09:51 | 显示全部楼层
顶楼主。
发表于 2015-11-22 21:55 | 显示全部楼层
谢谢您的分享!
发表于 2015-11-24 22:28 | 显示全部楼层
好像在网站上已经找不到相关的内容了
回复 支持 1 反对 0
发表于 2016-1-14 18:37 | 显示全部楼层
貌似是没有了,谁有可以分享一下么,841680142@qq.com
发表于 2016-11-11 15:09 | 显示全部楼层
感谢指导
发表于 2016-11-22 13:55 | 显示全部楼层
网站过期了吧
GMT+8, 2025-8-2 14:25 , Processed in 0.076912 second(s), 23 queries , Gzip On.
