查看: 2148|回复: 1
[前后处理] 关于MDAMP命令求教
发表于 2013-1-27 15:00 | 显示全部楼层 |阅读模式
求教各位大神,ansys里面设置模态阻尼比的命令MDAMP到底怎么用呢?帮助文件看了半天也没看明白,比如说我要设置1~10阶阻尼比为0.01,11~20为0.02,应该怎么写呢?跪求!
MDAMP
MDAMP, STLOC, V1,   V2,  V3, V4, V5, V6
Defines    the damping ratios as a function of mode.
TLOC     Starting location in table for entering data. For example,     if STLOC   = 1, data input in the V1   field applies to the first constant in the table. If STLOC= 7, data input in the V1 field applies to the seventh constant in the table, etc. Defaults to the last location filled + 1.
V1,  V2,V3, . . . , V6 Data assigned to six locations starting with STLOC.If a value is already in this location, it will be redefined. Blank values for V2  to V6  leave the corresponding previous value unchanged.
 楼主| 发表于 2013-1-28 11:19 | 显示全部楼层
终于搞懂了,原来第一个参数是指定从哪一阶模态开始算起,后面的六个参数是接下来6阶模态的阻尼比,不过这个命令很搞笑啊 ,一次只能指定6阶阻尼比?还有,ansys论坛软软没有升学论坛活跃啊,那边讨论氛围浓烈很多啊
GMT+8, 2025-1-7 21:34 , Processed in 0.056131 second(s), 17 queries , Gzip On.
