查看: 1549|回复: 2
轴对称边界约束出问题了
发表于 2006-5-2 09:20 | 显示全部楼层 |阅读模式
我建立轴对称模型进行求解,出现如下问题<BR> *** ERROR ***                           CP =      70.578   TIME= 15:51:36<BR> The value of UY at node 1 is 1.355035796E+11.  It is greater than the   <BR> current limit of 1000000.  This generally indicates rigid body motion   <BR> as a result of an unconstrained model.  Verify that your model is       <BR> properly constrained.   <BR>  <BR> node 1    对称轴线上的一点
发表于 2006-5-2 22:25 | 显示全部楼层
UY at node 1 is 1.355035796E+11 &#160;, unconstrained model.Verify that your model is <BR/>properly constrained.  <BR/>查看一下模型约束是否设置。如果模型约束设置无错误的话,则你所建立的模型不是一个整体结构,有缝隙存在<BR/>
 楼主| 发表于 2006-5-13 08:50 | 显示全部楼层
谢谢
GMT+8, 2025-1-30 14:49 , Processed in 0.071534 second(s), 17 queries , Gzip On.
