查看: 4917|回复: 12
[C/C++] 快速傅里叶变换(转)
发表于 2012-10-14 00:56 | 显示全部楼层 |阅读模式
[code=Cpp width=600px]
#include  <stdio.h>
#include  <stdlib.h>
#include  <math.h>
#define  PI  3.14159265358979323846
struct  COMPLEX
    float  re;
    float  im;
} cplx , * Hfield , * S , * R , * w;
int  n , m;
int  ln , lm;
void  initiate ();
void  dfft ();
void  rdfft ();
void  showresult ();
void  fft (int l , int k);
int  reverse (int t , int k);
void  W (int l);
int  loop (int l);
void  conjugate ();
void  add (struct  COMPLEX  * x , struct  COMPLEX  * y , struct  COMPLEX  * z);
void  sub (struct  COMPLEX  * x , struct  COMPLEX  * y , struct  COMPLEX  * z);
void  mul (struct  COMPLEX  * x , struct  COMPLEX  * y , struct  COMPLEX  * z);
struct  COMPLEX  * Hread(int i , int j);
void  Hwrite (int i , int j , struct  COMPLEX x);
void  main ()
    initiate ();
    printf("\n原始数据:\n");
    showresult();
    getchar ();
    dfft ();
    printf("\n快速复利叶变换后的结果:\n");
    showresult ();
    getchar ();
    rdfft ();
    printf("\n快速复利叶逆变换后的结果:\n");
    showresult ();
    getchar ();
    free (Hfield);
void  initiate ()
{//程序初始化操作,包括分配内存、读入要处理的数据、进行显示等
    FILE  * df;
    df = fopen ("data.txt" , "r");
    fscanf (df , "%5d" , &n);
    fscanf (df , "%5d" , &m);
    if ((ln = loop (n)) == -1)
        printf (" 列数不是2的整数次幂 ");
        exit (1);
    if ((lm = loop (m)) == -1)
        printf (" 行数不是2的整数次幂 ");
        exit (1);
    Hfield = (struct  COMPLEX *) malloc (n * m * sizeof (cplx));
    if (fread (Hfield , sizeof (cplx) , m * n , df) != (unsigned) (m * n))
        if (feof (df)) printf (" Premature end of file ");
        else printf (" File read error ");
    fclose (df);
void  dfft ()
{//进行二维快速复利叶变换
    int  i , j;
    int  l , k;
    l = n;
    k = ln;
    w = (struct  COMPLEX *) calloc (l , sizeof (cplx));
    R = (struct  COMPLEX *) calloc (l , sizeof (cplx));
    S = (struct  COMPLEX *) calloc (l , sizeof(cplx));
    W (l);
    for ( i = 0 ; i < m ; i++ )
    {//按行进行快速复利叶变换
        for (j = 0 ; j < n ; j++)
            S[j].re = Hread (i , j)->re;
            S[j].im = Hread (i , j)->im;
        fft(l , k);
            Hwrite (i , j , R[j]);
    free (R);
    free (S);
    free (w);
    l = m;
    k = lm;
    S = (struct  COMPLEX *) calloc (l , sizeof (cplx));
    W (l);
    for (i = 0 ; i < n ; i++)
    {//按列进行快速复利叶变换
        for(j = 0 ; j < m ; j++)
            S[j].re = Hread(j , i)->re;
            S[j].im = Hread(j , i)->im;
        fft(l , k);
        for (j = 0 ; j < m ; j++)
            Hwrite (j , i , R[j]);
    free (R);
    free (S);
    free (w);
void  rdfft ()
    conjugate ();
    dfft ();
    conjugate ();
void  showresult ()
    int  i , j;
    for (i = 0 ; i < m ; i++)
        printf ( " \n第%d行\n " , i);
            if (j % 4 == 0) printf (" \n ");
            printf(" (%5.2f,%5.2fi) " , Hread (i , j)->re , Hread (i , j)->im);
    int  i , j , s , nv , t;
    float  c;
    struct  COMPLEX  mp , r;
    nv = l;
    c = (float) l;
    c = pow (c , 0.5);
    for (i = 0 ; i < k ; i++)
        for (t = 0 ; t < l ; t += nv)
            for (j = 0 ; j < nv / 2 ; j++)
                s = (t + j) >> (k - i -1);
                s = reverse(s , k);
                r.re = S[t + j].re;
                r.im = S[t + j].im;
                mul (&w , &S[t + j + nv / 2] , &mp);/////////讲解传递结构指针和结构本身的区别
                add (&r , &mp , &S[t + j]);
                sub (&r , &mp , &S[t + j + nv / 2]);
        nv = nv >> 1;
    for (i = 0 ; i < l ; i++)
        j = reverse(i , k);
        R[j].re = S.re / c;
        R[j].im = S.im / c;
    int  i , x , y;
    y = 0;
        x = t & 1;
        t = t >> 1;
        y = (y << 1) + x;
    return y;
void  W (int l)
    int i;
    float c , a;
    c = (float) l;
    c = 2 * PI / c;
        a = (float) i;
        w.re = (float) cos(a * c);
        w.im = -(float) sin(a * c);
int  loop (int l)
{//检验输入数据是否为2的整数次幂,如果是返回用2进制表示时的位数
    int  i , m;
    if (l != 0)
        for (i = 1 ; i < 32 ; i++)
            m = l >> i;
            if (m == 0)
                break;
        if (l == (1 << (i - 1)))
            return i - 1;
    return -1;
void  conjugate ()
{//求复数矩阵的共轭矩阵
    int  i , j;
            Hread (i , j)->im *= -1;
struct  COMPLEX  * Hread (int i , int j)
{//按读矩阵方式返回Hfield中指定位置的指针
    return (Hfield + i * n + j);
{//按写矩阵方式将复数结构x写到指定的Hfield位置上
    (Hfield + i * n + j)->re = x.re;
    (Hfield + i * n + j)->im = x.im;
{//定义复数加法
    z->re = x->re + y->re;
    z->im = x->im + y->im;
{//定义复数减法
    z->re = x->re - y->re;
    z->im = x->im - y->im;
{//定义复数乘法
       z->re = (x->re) * (y->re) - (x->im) * (y->im);
    z->im = (x->im) * (y->re) + (x->re) * (y->im);
}[/code]
发表于 2012-10-18 16:15 | 显示全部楼层
用C/C++写出来挺不容易,要是使用PYTHON等脚本语言应该会更简单一些。
发表于 2013-7-20 14:09 | 显示全部楼层
完全看不懂。。。。
发表于 2013-11-1 15:09 | 显示全部楼层
膜拜一下
发表于 2013-11-4 15:20 | 显示全部楼层
感谢分享,好强悍
发表于 2013-11-5 20:29 | 显示全部楼层
感谢分享
发表于 2013-11-7 09:10 | 显示全部楼层
这个好,终于在这里找到了
发表于 2013-12-15 21:08 | 显示全部楼层
感谢分享 !但是看不大懂啊
发表于 2014-2-25 00:53 | 显示全部楼层
不要尝试写FFT,实现一个经典算法非常容易,但是做一个真正的快速FT是很困难的,去看看fftpack和fftw之争就知道这个问题完全不是几行代码可以搞定的事情。这些成熟稳定的算法还是用现成库实在。说到数值分析,现在好些学校还在讲什么LU分解,最速下降法,哎,真的有用吗?
上完一个学期的数值分析,天天在讨论收敛性,收敛速率,SOR最佳因子。结果ANSYS用的是预处理共轭梯度法,感觉完全被骗了一样。
发表于 2014-2-25 08:49 | 显示全部楼层
mayaview 发表于 2014-2-25 00:53
不要尝试写FFT,实现一个经典算法非常容易,但是做一个真正的快速FT是很困难的,去看看fftpack和fftw之争 ...
你可以不去学习,但是作为一个国家,都不去学习,那么你永远只能跟在人家屁股后面,Ansys一年赚取国人多少银子,再说说仪器,每个领域所有高端仪器都是老外的,真准备子子孙孙也这样了?对了,中国发展北斗做什么,不是有GPS吗?
发表于 2014-2-25 09:46 | 显示全部楼层
impulse 发表于 2014-2-25 08:49
你可以不去学习,但是作为一个国家,都不去学习,那么你永远只能跟在人家屁股后面,Ansys一年赚取国人多 ...
完全不是一个概念啊,你觉得单凭写个这样的C语言的FFT就能超过FFTW?像这样重复的造轮子,啥时候都赶不上现在的国外水平,还别说超过人家了。设备和北斗里或许多少都还有点前人没做过的东西吧,这种仅仅是实现一下经典算法的代码无非就是重复造轮子,而且还是质量很差的轮子。
发表于 2014-2-25 10:20 | 显示全部楼层
再好的工匠做的第一个轮子就能装在空客上?你可以指出这段代码哪些地方有不足,但是不能打击这种精神,创新也是要有基础的,有继承的。
发表于 2014-2-25 12:07 | 显示全部楼层
impulse 发表于 2014-2-25 10:20
再好的工匠做的第一个轮子就能装在空客上?你可以指出这段代码哪些地方有不足,但是不能打击这种精神,创新 ...
这是转帖,谢谢!而且我已经提供了两个更好的库可供参考,那两个库都是开源的。做过点FFT的都应该知道(如果只是在Matlab里面用fft命令的就算了吧)FFT实现的经典算法基本是不可以拿来实际运用,了解了解基本算法还行,真正要用需要大量的优化和特殊情况的处理,不是这样的代码可以解决的。
GMT+8, 2025-6-13 17:49 , Processed in 0.089889 second(s), 19 queries , Gzip On.
