查看: 4207|回复: 9
[电磁场分析] 【转帖】Piezoelectric - 压电材料振动能量采集的有限元分析
发表于 2012-9-11 10:18 | 显示全部楼层 |阅读模式
 楼主| 发表于 2012-9-11 10:20 | 显示全部楼层
  1. !1) Initialisation of elements and material properties
  2. /TITLE, Piezoelectric Vibration Energy Harvester
  3. /UNITS,MKS
  4. accelx=0     !Acceleration in X
  5. accely=0     !Acceleration in Y
  6. accelz=2.5     !Acceleration in Z
  7. /COM,
  8. /COM,   Finite Element Model of a Piezoelectric Energy Harvester
  9. /COM,
  10. /PREP7
  11. /COM,  Define Element Types Used During FEA Analysis
  12. ET,1,SOLID5,0    !8-Node Coupled Field Piezoelectric Element For PZT
  13. ET,2,SOLID45    !8-Node Solid Element For Modelling Tungsten Mass and
  14.       !steel Shim
  15. ET,3,SHELL41    !4-Node Membrane Shell Element (Electrode), Not used in
  16.       !this project
  17. ET,4,TARGE170,0    !3D Target surface for modelling bonding contact
  18.       !between tungsten mass and beam
  19. ET,5,CONTA174    !Coupled field contact surface for modelling contact
  20.       !between tungsten mass and beam
  21. /COM,  Define Element Type Used During Electrical Analysis
  22. ET,6,CIRCU94,0    !Define Resistor
  23. /COM,      !Define Keyopts for Finite Elements
  24. KEYOPT,4,5,1    !Set TARGE 170 to solid-solid constraint
  25. KEYOPT,5,1,0    !UX,UY,UZ
  26. KEYOPT,5,2,2    !Contact algorithm: MPC
  27. KEYOPT,5,4,1    !Contact detection on nodal point
  28. KEYOPT,5,5,0    !No automated contact adjustment
  29. KEYOPT,5,7,0    !No element level time increment control
  30. KEYOPT,5,8,0    !No asymmetric contact selection
  31. KEYOPT,5,9,1    !Exclude both initial geometrical penetration or gap
  32.       !and offset
  33. KEYOPT,5,10,1    !Update contact stiffness each substep based on mean stress
  34.       !of underlying elements
  35. KEYOPT,5,12,5    !Bonded always contact behaviour
  36. /COM,  ZT-SH4 (Navy Type VI) Material Properties
  37. /COM,  iezo Systems Inc.
  38. EMUNIT, MKS    ! Free space permittivity
  39. MP,DENS,1,7500    !Material density
  40. MP,PERX,1,3130    !Relative permittivity MP,PERY,1,3130
  41. MP,PERZ,1,3400
  42. TB,ANEL,1,1,,1    !Flexibility matrix - inverted by Ansys
  43. TBDATA,1,16.5e-12,-4.78e-12,-8.45e-12
  44. TBDATA,7,16.5e-12,-8.45e-12
  45. TBDATA,12,20.7e-12
  46. TBDATA,16,43.5e-12
  47. TBDATA,19,43.5e-12
  48. TBDATA,21,42.6e-12
  49. TB,PIEZ,1    ! Piezoelectric constant matrix
  50. TBDATA,3,-6.622
  51. TBDATA,6,-6.622
  52. TBDATA,9,23.24
  53. TBDATA,11,17.034
  54. TBDATA,13,17.394
  55. MP,MURX,1,0    !False material properties to suppress error messages
  56. MP,KXX,1,0
  57. /COM,  Steel Shim Material Properties
  58. MP,DENS,2,7700    !Density
  59. MP,EX,2,207e9    !Young's Modulus
  60. MP,PRXY,2,0.3    !Poisson's ratio
  61. !MP,RSVX,2,72e-8  !Resistivity (Volt DOF will be coupled later)
  62. /COM,  Tungsten Mass Material Properties
  63. MP,DENS,3,17000    !Density
  64. MP,EX,3,540e9    !Mass deformation will be negligible
  65. MP,PRXY,3,0.28    !Poisson's ratio
  66. /COM,  Nickel Electrode Material Properties, not used in this
  67. /COM,  project
  68. R,1,0.2e-6    !Thickness of top nickel electrode
  69. R,2,0.2e-6    !Thickness of bottom nickel electrode
  70. MP,EX,4,207e9    !Young's Modulus
  71. MP,PRXY,4,0.3    !Poisson's ratio
  72. /COM,  Contact material properties
  73. REAL,3      !Set element real constant attribute pointer
  74. R,3,,,,,,
  75. RMORE,,,,,,
  76. RMORE,,0,,,,
  77. RMORE,0      !Set electrical contact conductance
  78. ALLSEL,ALL,ALL    !Select all entities
  79. /COM,  Define real constants for circuit elements
  80. R,4,180e3    !Define Resistor Properties (Defaults)
  81. !Application of material properties to solid geometry
  82. /COM,  Apply material properties to volumes of imported
  83. /COM,  ro/Engineer Wildfire 2 IGES model
  84. VSEL,S,VOLU,,2,,,0  !Select volume 2 (Bottom Piezo layer)
  85. VSEL,A,VOLU,,3,,,0  !Additionally select volume 3 (Top Piezo layer)
  86. VATT,1,1,1,0    !Apply PZT-5144 material properties
  87. VSEL,S,VOLU,,1,,,0  !Select volume 1(Steel centre shim)
  88. VATT,2,1,2,0    !Apply steel material properties
  89. VSEL,S,VOLU,,4,,,0  !Select volume 4 (Tungsten mass)
  90. VATT,3,1,2,0    !Apply tungsten material properties
  91. /COM,  Set mesh densities
  92. /COM,  ZT thickness density
  93. LSEL,S,LINE,,38,,,0  !Select bottom PZT layer thickness
  94. LSEL,A,LINE,,84,,,0  !Select top PZT layer thickness
  95. LESIZE,ALL,,,3    !Specify 3 divisions mesh density
  96. /COM,  Steel shim thickness density
  97. LSEL,S,LINE,,12,,,0
  98. LESIZE,Al1,,,2    !Specify 2 divisions mesh density
  99. /COM  Beam width density
  100. LSEL,S,LINE,,4,,,0
  101. LSEL,A,LINE,,10,,,0
  102. LSEL,A,LINE,,41,,,0
  103. LESIZE,ALL,,,4    !4 divisions mesh density
  104. /COM,  Beam length density
  105. LSEL,S,LINE,,2,,,0
  106. LSEL,A,LINE,,9,,,O
  107. LSEL,A,LINE,,81,,,0
  108. LESIZE,ALL,,,120  ! 120 divisions mesh density
  109. /COM,  Tungsten mass mesh density
  110. LSEL,S,LINE,,109
  111. LESIZE,ALL,,,3
  112. LSEL,S,LINE,,111,,,0
  113. LESIZE,ALL,,,2
  114. LSEL,S,LINE,,110,,,0
  115. LESIZE,ALL,,,4
  116. /COM,  Mesh all volumes and areas
  117. MSHKEY,1    !Set mapped mesh
  118. ALLSEL,ALL,VOLU   !Select all volumes to be meshed
  119. VMESH,ALL    !Mesh all volumes
  120. !Coupling DOF
  121. !The VOLT DOF is coupled between the dielectric and
  122. !conductive layers in the model. This procedure uses the CP command to couple the
  123. !DOF set of the nodes in the selected region, hence, the procedure must be performed after
  124. !meshing.
  125. /COM,  Couple voltage degree of freedom between layers
  126. ASEL,S,AREA,,41,,,0  !Select top electrode
  127. NSLA,S,1    !Select nodes related to top electrode
  128. NSEL,U,LOC,X,10.7e-3,30e-3
  129. CM,top_electrode,NODE   !Create component from nodes
  130. ASEL,S,AREA,,34,,,0  !Select bottom electrode
  131. NSLA,S,1    !Select nodes related to top electrode
  132. NSEL,U,LOC,X,10.7e-3,30e-3
  133. CM,bottom_electrode,NODE!Create component from nodes
  134. NSEL,S,NODE,,top_electrode
  135. NSEL,A,NODE,,bottom_electrode
  136. CP,I,VOLT,ALL    !Couple voltage degree of freedom for all nodes
  137. *GET,OUT ELECT,NODE,O,NUM,MIN !Get master node on top electrode
  138. VSEL,S,VOLU,,1,,,1  !Select centre shim
  139. NSLV,S,1    !Select nodes associated with volume
  140. CM,centre shim,NODE   !Create component from nodes
  141. CP,NEXT,VOLT,ALL   !Couple voltage degree of freedom for all nodes
  142. *GET,NCENTRE,NODE,O,NUM,MIN !Get master centre electrode node
  143. ALLSEL
  144. !D.1.5 Modelling contact of proof mass
  145. !In this section of the analysis, a target element is defined on the base of the tungsten
  146. !mass and a contactelement is defined on the top surface of the beam as described in ANSYS
  147. !Inc. (2004d).
  148. ASEL,S,AREA,,48,,,0   !Select bottom of tungsten mass
  149. NSLA,S,1    !Select nodes related to top electrode
  150. CM,target_surface,NODE   !Create component from nodes
  151. ALLSEL,ALL,ALL    !Select all entities
  152. /COM,  Define contact pair's
  153. NSEL,S,,,target_surface !Select nodes on base of tungsten mass
  154. TYPE,4      ! Set target element
  155. ESLN,S,0    !Select elements attached to nodes
  156. ESURF,ALL    !Create target elements
  157. ASEL,S,AREA,,41,,,0  !Select top electrode
  158. NSLA,S,1    !Select nodes related to top electrode
  159. TYPE,5      !Set contact element type
  160. ESLN,S,0    !Select elements attached to nodes
  161. ESURF,ALL    !Create contact elements
  162. ALLSEL  !Select all
  163. FINISH
  164. !2) Analysis
  165. !2.1) Static analysis
  166. /COM,  Static analysis to test regime
  167. /SOLU      !Enter solution pre-processor
  168. /COM,  Apply boundary conditions
  169. /COM  Completely rigid fixture, constrained Y for all
  170. NSEL,S,LOC,X,0    !Select nodes at fixture location
  171. D,ALL,UX,0,,,,UY,UZ,   !Constrain all DOF
  172. /COM,  Define Model symmetry
  173. NSEL,S,LOC,Y,0    !Select nodes at model symmetry line
  174. DSYM,SYMM,Y    !Apply symmetry boundary conditions
  175. ALLSELL,ALL,ALL    !Select all entities
  176. /COM,  Apply 5V to top and bottom electrode, OV to shim
  177. D,top_electrode,VOLT,5
  178. D,bottom_electrode,VOLT,5
  179. D,centre_shim,VOLT,0
  180. ALLSELL,ALL,ALL    !Select all entities
  181. ANTYPE,STATIC
  182. SOLVE
  183. FINISH
  184. !2.2) Modal analysis
  185. /COM  Modal analysis for determining resonance response of
  186. /COM,  harvester
  187. /SOLU
  188. /COM,  Delete DOF from static analysis
  189. DDELE,top_electrode,VOLT
  190. DDELE,bottom_electrode,VOLT
  191. ANTYPE,MODAL    !Modal analysis
  192. MODOPT,REDUC,8    !4 modes using reduced method
  193. MXPAND,8    !Expand a114 modes
  194. TOTAL,10,1
  195. ALLSEL
  196. D,NCENTRE,VOLT,0.0   !Ground centre electrode
  197. DMPRAT,0.031    !Constant damping ratio
  198. NSEL,ALL    !Select all nodes
  199. SOLVE      !Solve current load step
  200. FINISH
  201. !2.3) Harmonic analysis without resistor
  202. /COM,  Haitnonic analysis around first resonant frequency
  203. /SOLU
  204. ANTYP,HARM    !Set harmonic analysis
  205. HARFRQ,30,120    !Set frequency range
  206. NSUBST,36    !Set 2.5 Hz increments
  207. KBC,1      !Loads step changed
  208. D,NCENTRE,VOLT,0.0   !Ground centre electrode
  209. DMPRAT,0.031    !Constant damping ratio
  210. ALLSEL
  211. ACEL,accelx,accely,accelz !Set accelerations
  212. SOLVE
  213. FINISH
  214. /POST26
  215. NSOL,9, OUT_ELECT, VOLT,,output_voltage ! Store output power
  216. FINISH
  217. !2.4) Harmonic analysis with resistor
  218. /COM,  Harmonic analysis around first frequency with
  219. /COM,  resistance load
  220. /COM,  Create circuit geometry
  221. /PREP7
  222. N,,0,-5e-3,0,    !Defines node 1 for circuit
  223. N,,5e-3,-5e-3,0,  !Defines node 2 for circuit
  224. /COM,  Create circuit elements on geometry
  225. TYPE,6      !Set circuit element type (Resistor)
  226. REAL,4      !Set circuit element constants (Resistance)
  227. E,5505,5506    !Plot Resistor
  228. /ICSCALE,1,0.1    !Scale circuit elements to correct size
  229. /COM,  Couple voltage degrees of freedom between circuit
  230. /COM,  and FE model. Places resistor between top and bottom
  231. /COM   electrode
  232. NSEL,S,NODE,,5505  !Select input node in circuit
  233. CP,1,VOLT,ALL    !Couple voltage Degree of Freedom on top elect
  234. NSEL,S,NODE,,5506  !Select input node in circuit
  235. CP,4,VOLT,ALL    !Couple voltage Degree of Freedom on centre elect
  236. ALLSELL,ALL,ALL    !Select all entities
  237. FINISH
  238. /COM,  Harmonic analysis with resistor coupled to outer electrodes
  239. /SOLU
  240. ANTYP,HARM    !Set harmonic analysis
  241. /COM  Set constraints on DOF
  242. NSEL,S,LOC,X,0    !Select nodes at fixture location
  243. D,ALL,UX,O,,,,UY,UZ,   !Constrain all DOF
  244. /COM  Define Model symmetry
  245. NSEL,S,LOC,Y,0     !Select nodes at model symmetry line
  246. DSYM,SYMM,Y     !Apply symmetry boundary conditions
  247. ALLSELL,ALL,ALL   !Select all entities
  248. HARFRQ,30,120    !Set frequency range
  249. NSUBST,36    !Set 2.5 Hz increments
  250. KBC,1      !Loads step changed
  251. D,NCENTRE,VOLT,0.0   !Ground centre electrode
  252. DMPRAT,0.031    !Constant damping ratio
  253. ALLSEL
  254. ACEL,accelx,accely,accelz !Set accelerations
  255. SOLVE
  256. FINISH
  257. !2.5) Spectral Analysis
  258. /COM,  Spectral analysis
  259. /SOLU
  260. ALLSEL
  261. DDELE,ALL,ALL    !Delete all previous constraints
  262. ACEL,0,0,0    !Set accelerations to zero (zero gravity)
  263. D,NCENTRE,VOLT,0.0   !Ground centre electrode
  264. NSEL,S,LOC,X,0    !Select nodes at fixture location
  265. D,ALL,UX,0,,,,UY,UZ,   !Constrain all DOF
  266. /COM,  Define Model symmetry
  267. NSEL,S,LOC,Y,0    !Select nodes at model symmetry line
  268. DSYM,SYMM,Y    !Apply symmetry boundary conditions
  269. ALLSELL,ALL,ALL    !Select all entities
  270. /COM,  Modal analysis
  271. /SOLU
  272. ANTYPE,MODAL    ! Mode-frequency analysis
  273. MODOPT,REDUC,,,,4   ! Householder, print first 3 reduced mode shapes
  274. MXPAND,4,    ! Expand first mode shape
  275. TOTAL,10,1
  276. OUTPR,BASIC,1
  277. SOLVE
  278. FINISH
  279. /COM,  Spectrum Analysis
  280. /SOLU
  281. ANTYPE,SPECTR    ! Spectrum analysis
  282. SPOPT,SPRS    ! Single point spectrum
  283. DMPRAT,0.031    !Constant damping ratio
  284. SED,0,0,1    ! Global Z-axis as spectrum direction
  285. SVTYPE,2    ! Seismic acceleration spectrum
  286. MCOMB,SRSS,0.001,
  287. /COM  Define frequency table (from table 4.1)
  288. FREQ,12,31,32,34,35,57,59,67,68 !Frequency points 1-9 (Hz)
  289. FREQ,69,70,72,73  ! Frequency 10-13 (Hz)
  290. /COM,  Define acceleration table to match frequency table (from
  291. /COM,  table 4.1)
  292. SV,0.031,0.167,0.052,0.067,0.067,0.059,0.168,0.054,0.072,0.284
  293. SV,0.031,0.078,0.078,0.068,0.07 ! Acceleration magnitudes (m/s2)
  294. OUTRES,ALL,ALL,    !Output all results to file
  295. ALLSEL
  296. SOLVE
  297. FINISH
  298. /Post26      !Enter post processing
  299. /INPUT,,mcom,,1,0   !Input combined modes results file
  300. FINISH
一秒时间历程的瞬态分析:
 楼主| 发表于 2012-9-11 10:22 | 显示全部楼层
电压:; \ 200552317405184815.gif
 楼主| 发表于 2012-9-11 10:24 | 显示全部楼层
  1. 瞬态分析的独立程序如下:
  2. /PREP7
  3. RESUME,PZT_geo,db,,0,0
  4. !D.1.1 Initialisation of elements and material properties
  5. /UNITS,MKS
  6. /COM,
  7. /COM,   Finite Element Model of a Piezoelectric Energy Harvester
  8. /COM,
  9. /PREP7
  10. /COM,    Define Element Types Used During FEA Analysis
  11. ET,1,SOLID5,0    !8-Node Coupled Field Piezoelectric Element For PZT
  12. ET,2,SOLID45    !8-Node Solid Element For Modelling Tungsten Mass and
  13.       !steel Shim
  14. ET,3,SHELL41    !4-Node Membrane Shell Element (Electrode), Not used in
  15.       !this project
  16. ET,4,TARGE170,0    !3D Target surface for modelling bonding contact
  17.       !between tungsten mass and beam
  18. ET,5,CONTA174    !Coupled field contact surface for modelling contact
  19.       !between tungsten mass and beam
  20. /COM,  Define Element Type Used During Electrical Analysis
  21. ET,6,CIRCU94,0    !Define Resistor
  22. /COM,      !Define Keyopts for Finite Elements
  23. KEYOPT,4,5,1    !Set TARGE 170 to solid-solid constraint
  24. KEYOPT,5,1,0    !UX,UY,UZ
  25. KEYOPT,5,2,2    !Contact algorithm: MPC
  26. KEYOPT,5,4,1    !Contact detection on nodal point
  27. KEYOPT,5,5,0    !No automated contact adjustment
  28. KEYOPT,5,7,0    !No element level time increment control
  29. KEYOPT,5,8,0    !No asymmetric contact selection
  30. KEYOPT,5,9,1    !Exclude both initial geometrical penetration or gap
  31.       !and offset
  32. KEYOPT,5,10,1    !Update contact stiffness each substep based on mean stress
  33.       !of underlying elements
  34. KEYOPT,5,12,5    !Bonded always contact behaviour
  35. /COM  ZT-SH4 (Navy Type VI) Material Properties
  36. /COM,  iezo Systems Inc.
  37. EMUNIT, MKS    ! Free space permittivity
  38. MP,DENS,1,7500    !Material density
  39. MP,PERX,1,3130    !Relative permittivity MP,PERY,1,3130
  40. MP,PERZ,1,3400
  41. TB,ANEL,1,1,,1    !Flexibility matrix - inverted by Ansys
  42. TBDATA,1,16.5e-12,-4.78e-12,-8.45e-12
  43. TBDATA,7,16.5e-12,-8.45e-12
  44. TBDATA,12,20.7e-12
  45. TBDATA,16,43.5e-12
  46. TBDATA,19,43.5e-12
  47. TBDATA,21,42.6e-12
  48. TB,PIEZ,1    ! Piezoelectric constant matrix
  49. TBDATA,3,-6.622
  50. TBDATA,6,-6.622
  51. TBDATA,9,23.24
  52. TBDATA,11,17.034
  53. TBDATA,13,17.394
  54. MP,MURX,1,0    !False material properties to suppress error messages
  55. MP,KXX,1,0
  56. /COM,  Steel Shim Material Properties
  57. MP,DENS,2,7700    !Density
  58. MP,EX,2,207e9    !Young's Modulus
  59. MP,PRXY,2,0.3    !Poisson's ratio
  60. !MP,RSVX,2,72e-8  !Resistivity (Volt DOF will be coupled later)
  61. /COM,  Tungsten Mass Material Properties
  62. MP,DENS,3,17000    !Density
  63. MP,EX,3,540e9    !Mass deformation will be negligible
  64. MP,PRXY,3,0.28    !Poisson's ratio
  65. /COM  Nickel Electrode Material Properties, not used in this
  66. /COM,  project
  67. R,1,0.2e-6    !Thickness of top nickel electrode
  68. R,2,0.2e-6    !Thickness of bottom nickel electrode
  69. MP,EX,4,207e9    !Young's Modulus
  70. MP,PRXY,4,0.3    !Poisson's ratio
  71. /COM,  Contact material properties
  72. REAL,3      !Set element real constant attribute pointer
  73. R,3,,,,,,
  74. RMORE,,,,,,
  75. RMORE,,0,,,,
  76. RMORE,0      !Set electrical contact conductance
  77. ALLSEL,ALL,ALL    !Select all entities
  78. /COM,  Define real constants for circuit elements
  79. R,4,180e3    !Define Resistor Properties (Defaults)
  80. /COM,  Apply material properties to volumes of imported
  81. /COM,  ro/Engineer Wildfire 2 IGES model
  82. VSEL,S,VOLU,,1,,,0  !Select volume 2 (Bottom Piezo layer)
  83. VSEL,A,VOLU,,3,,,0  !Additionally select volume 3 (Top Piezo layer)
  84. VATT,1,1,1,0    !Apply PZT-5144 material properties
  85. VSEL,S,VOLU,,2,,,0  !Select volume 1(Steel centre shim)
  86. VATT,2,1,2,0    !Apply steel material properties
  87. VSEL,S,VOLU,,4,,,0  !Select volume 4 (Tungsten mass)
  88. VATT,3,1,2,0    !Apply tungsten material properties
  89. /COM,  Set mesh densities
  90. /COM,  ZT thickness density
  91. LSEL,S,LINE,,10,,,0  !Select bottom PZT layer thickness
  92. LSEL,A,LINE,,26,,,0  !Select top PZT layer thickness
  93. LESIZE,ALL,,,3    !Specify 3 divisions mesh density
  94. /COM,  Steel shim thickness density
  95. LSEL,S,LINE,,18,,,0
  96. LESIZE,Al1,,,2    !Specify 2 divisions mesh density
  97. /COM  Beam width density
  98. LSEL,S,LINE,,1,,,0
  99. LSEL,A,LINE,,5,,,0
  100. LSEL,A,LINE,,13,,,0
  101. LESIZE,ALL,,,4    !4 divisions mesh density
  102. /COM,  Beam length density
  103. LSEL,S,LINE,,2,,,0
  104. LSEL,A,LINE,,6,,,O
  105. LSEL,A,LINE,,14,,,0
  106. LESIZE,ALL,,,120  ! 120 divisions mesh density
  107. /COM,  Tungsten mass mesh density
  108. LSEL,S,LINE,,38
  109. LESIZE,ALL,,,3
  110. LSEL,S,LINE,,33,,,0
  111. LESIZE,ALL,,,2
  112. LSEL,S,LINE,,34,,,0
  113. LESIZE,ALL,,,4
  114. /COM,  Mesh all volumes and areas
  115. MSHKEY,1    !Set mapped mesh
  116. ALLSEL,ALL,VOLU   !Select all volumes to be meshed
  117. VMESH,ALL    !Mesh all volumes
  118. /COM,  Couple voltage degree of freedom between layers
  119. ASEL,S,AREA,,12,,,0  !Select top electrode
  120. NSLA,S,1    !Select nodes related to top_electrode
  121. NSEL,U,LOC,X,10.7e-3,30e-3
  122. CM,top_electrode,NODE   !Create component from nodes
  123. ASEL,S,AREA,,1,,,0  !Select bottom electrode
  124. NSLA,S,1    !Select nodes related to top_electrode
  125. NSEL,U,LOC,X,10.7e-3,30e-3
  126. CM,bottom_electrode,NODE!Create component from nodes
  127. NSEL,S,NODE,,top_electrode
  128. NSEL,A,NODE,,bottom_electrode
  129. CP,1,VOLT,ALL    !Couple voltage degree of freedom for all nodes
  130. *GET,OUT_ELECT,NODE,0,NUM,MIN !Get master node on top_electrode
  131. VSEL,S, , ,       2
  132. !VSEL,S,VOLU,,2,,,1  !Select centre shim
  133. NSLV,S,1    !Select nodes associated with volume
  134. CM,centre_shim,NODE   !Create component from nodes
  135. CP,NEXT,VOLT,ALL   !Couple voltage degree of freedom for all nodes
  136. *GET,NCENTRE,NODE,0,NUM,MIN !Get master centre electrode node
  137. ALLSEL
  138. ASEL,S,AREA,,17,,,0   !Select bottom of tungsten mass
  139. NSLA,S,1    !Select nodes related to top electrode
  140. CM,target_surface,NODE   !Create component from nodes
  141. ALLSEL,ALL,ALL    !Select all entities
  142. /COM,  Define contact pair's
  143. NSEL,S,,,target_surface !Select nodes on base of tungsten mass
  144. TYPE,4      ! Set target element
  145. ESLN,S,0    !Select elements attached to nodes
  146. ESURF,ALL    !Create target elements
  147. ASEL,S,AREA,,12,,,0  !Select top electrode
  148. NSLA,S,1    !Select nodes related to top electrode
  149. TYPE,5      !Set contact element type
  150. ESLN,S,0    !Select elements attached to nodes
  151. ESURF,ALL    !Create contact elements
  152. ALLSEL  !Select all
  153. FINISH
  154. CSYS,0
  155. /SOLU      !Enter solution pre-processor
  156. NSEL,S,LOC,X,0    !Select nodes at fixture location
  157. D,ALL,UX,0,,,,UY,UZ,   !Constrain all DOF
  158. ALLSELL,ALL,ALL    !Select all entities
  159. !*
  160. NT=100
  161. DT=0.01           !time increment
  162. *dim,ac,,NT
  163. /input,vibration_in,txt
  164. !*
  165. /SOLU
  166. NSUBST,1, , ,1
  167. OUTRES,ALL,1         !output result of each substep
  168. ANTYPE,TRANS         !transient
  169. TINTP,,0.25,0.5,0.5,0.5,0,,,,,,
  170. *do,i,1,NT
  171. ACEL,0,0,ac(i)
  172. TIME,i*DT
  173. solve
  174. *enddo
  175. !*
  176. /POST26
  177. NSOL,2,6069,U,Z,
  178. /GRID,1
  179. PLVAR,2
 楼主| 发表于 2012-9-11 10:25 | 显示全部楼层
震动波
vibration_in.rar
825 Bytes, 下载次数: 11
 楼主| 发表于 2012-9-11 10:27 | 显示全部楼层
部分GUI结果:
发表于 2012-9-12 08:58 | 显示全部楼层
谢谢楼主
发表于 2012-9-16 23:20 | 显示全部楼层
请问这个材料是从学术会议的报告中摘出来的么?
发表于 2014-5-30 10:03 | 显示全部楼层
几何模型建立的程序没有
GMT+8, 2024-12-29 18:17 , Processed in 0.076354 second(s), 24 queries , Gzip On.
