查看: 3599|回复: 7
[FFT] 求教 关于全相位 FFT/apFFT矫正程序的问题
发表于 2012-6-12 11:32 | 显示全部楼层 |阅读模式
下面是我在王兆华老师的FFT/apFFT矫正程序的基础上,写的关于模拟电力谐波的分析程序,由于我信号处理方面的知识很少,所以还有很多不理解的地方,请王老师和各位高手帮我解决一下。
close all;clc;clear all;
N=1024;%现在固定在个数据点数
f11=51.1;
Fs=2500;
n=-N+1:N-1;
apl=[220.5,4.4,10,3,6,1,3,0.8,1.5,0.8,1.1,0.04,0.85,0.1,1,0.04,0.5,0.02,0.3,0.005,0.01];
phol=[10,35,80.5,123,76,146,97,56,30,15,26,12,10,15,25,20,73,85,160,20,42];
%phol=zeros(1,21);%如果相位全选为0,则相位矫正结果全为270
ci=21;
y=zeros(1,2*N-1);
xie_bo=zeros(1,21);
for i=1:ci
     y=y+apl(i)*sin(2*pi*i*f11*n/Fs+phol(i)*pi/180);%各次谐波叠加  i*f11
     xie_bo(i)=i*f11;%计算谐波频率
%先进行传统的FFT
y1 = y(N:2*N-1);
win = hanning(N)';
win1 = win/sum(win);    %窗归一   用于把加权求和的窗进行归一化
y11 = y1.*win1;
y11_fft = fft(y11,N);%做N点的FFT运算
a1 = abs(y11_fft);  %FFT振幅谱
p1 = mod(phase(y11_fft)*180/pi,360);   %FFT相位谱 angle(v)也可以求
%再进行apFFT进行运算
y2 = y(1:2*N-1);    %2N-1个输入数据
win = hanning(N)';
winn = conv(win,win);   %apFFT须要卷积窗
win2 = winn/sum(winn);  %窗归一
y22 = y2.*win2;
y222 = y22(N:end)+[0 y22(1:N-1)];   %构成长N的apFFT输入数据  求和
y2_fft = fft(y222,N);
a2 = abs(y2_fft);   %apFFT振幅谱
p2 = mod(phase(y2_fft)*180/pi,360);
%校正量的计算
ee = mod((p1-p2)/180/(1-1/N),1);    %频率偏离矫正值
aa = (a1.^2)./a2*2; %振幅校正值  为什么要乘以2
subplot(5,1,1);stem(a1,'.');title('FFT amplitude spectrum');ylim([0,1]);xlim([0 N/2]); grid
subplot(5,1,2);stem(a2,'.');title('apFFT amplitude spectrum');ylim([0,110]);xlim([0 N/2]); grid
subplot(5,1,3);stem(p2,'.');title('apFFT phase spectrum');ylim([0,400]);xlim([0 N/2]); grid
subplot(5,1,4);stem(ee,'.');title('frequency correction spectrum');ylim([-1,1]);xlim([0 N/2]); grid
subplot(5,1,5);stem(aa,'.');title('amplitude correction spectrum');ylim([0,420]);xlim([0 N/2]); grid
xie_bo
r=round(xie_bo*N/Fs)%求谱线个数
disp('相位校正值')
p2(r+1)
disp('频率校正值')
(ee(r+1)+floor(xie_bo*N/Fs))*Fs/N  %
disp('振幅校正值')
aa(r+1)
得到的结果如下:
xie_bo =
  1.0e+003 *
  Columns 1 through 9
    0.0511    0.1022    0.1533    0.2044    0.2555    0.3066    0.3577    0.4088    0.4599
  Columns 10 through 18
    0.5110    0.5621    0.6132    0.6643    0.7154    0.7665    0.8176    0.8687    0.9198
  Columns 19 through 21
    0.9709    1.0220    1.0731
r =
  Columns 1 through 16
    21    42    63    84   105   126   147   167   188   209   230   251   272   293   314   335
  Columns 17 through 21
   356   377   398   419   440
相位校正值
ans =
  Columns 1 through 9
  280.0000  305.0000  350.5000   33.0000  346.0000   56.0000    7.0000  326.0000  300.0000
  285.0000  296.0000  282.0000  280.0000  285.0000  295.0000  290.0000  343.0000  355.0000
   70.0000  290.0000  312.0000
频率校正值
ans =
  1.0e+003 *
  Columns 1 through 9
振幅校正值
ans =
  Columns 1 through 9
  220.5000    4.3962    9.9995    2.9997    5.9998    0.9998    2.9999    0.8001    1.5000
    0.8000    1.1000    0.0400    0.8500    0.1000    1.0000    0.0400    0.5000    0.0200
    0.3000    0.0050    0.0100
问题
  • a、程序中关于频率偏移量的计算ee = mod((p1-p2)/180/(1-1/N),1); 应该是按照书中P62页的公式(4-45)得到的,但是我从公式中推导的程序为ee=mod( ( (p1-p2)*pi/180 )*2/(n-1),1 );不知道这个对不对,王老师的表达式又是怎么得来的呢?另外,为什么是对1进行取余数呢,这个与频率分辨率有关系么?请王老、各位高手帮我解答一下,谢谢!
  • b、程序中关于矫正结果的提取都用到了(r+1),这个是为什么呢,不应该是第r跟谱线的频率值,加上矫正量么?请王老、各位高手帮我解答一下,谢谢!
  • c、从我的程序的结果可以看出,相位的矫正结果不对,我的不明白是为什么。如果把21个初始的相位全都定为0,则可到的相位矫正结果全是270,不知道该怎么改正,请王老、各位高手帮我解答一下,谢谢!
发表于 2012-6-12 21:15 | 显示全部楼层
回复 1 # chunmu126 的帖子
a  按照书中P62页的公式(4-45)得到的角频率, 除以2*pi/N得到的频率
     对1进行取余数是使计算频偏 >0, 以适应下面计算频率校正值公式
b   Matlab中数椐从1开始,计算得到的频谱频率从直流0开始
c  将信号sin 改为cos即可, fft中的相位是对cos的
 楼主| 发表于 2012-6-13 14:53 | 显示全部楼层
谢谢王老的的解答,明白了!
 楼主| 发表于 2012-6-14 17:00 | 显示全部楼层
  • 王兆华老师,谢谢您的答疑,我现在对于问题a、中为在求频率偏移量的时候选择用1,来求余数,我还是有疑问,请您帮我解答一下,谢谢!
  • 事情是这样的,因为在实际当中,我不知道采集到的信号它的基频是多少(即程序中的f11=51.749123
    ),所以我想对于基频的频率量先按照50hz来进行矫正,希望得到真正的基频频率大小,然后再进行最终的谐波计算,但是在这个过程中,若取ee = mod((p1-p2)/180/(1-1/N),Fs/N),能够通过50hz矫正得到近似的真正的频率结果51.7491,但是若取ee = mod((p1-p2)/180/(1-1/N),1),就不能得到正确的结果,具体如下:
  • 程序的主体与一楼的一样。
  • 首先声明:xie_bo=zeros(1,21);xie_bo2=zeros(1,21);
    for i=1:21
    y=y+apl(i)*cos(2*pi*i*f11*n/Fs+phol(i)*pi/180);
    xie_bo(i)=i*f11; %模拟采集到的各次谐波的频率
    xie_bo2(i)=i*50;%按照50hz得到的各次谐波频率
  • 若采用
    r=round(xie_bo2*N/Fs)
    xie_bo
    disp('频率校正值')
    (ee(r+1)+floor(xie_bo2*N/Fs))*Fs/N
    无法得到较为准确的基频,结果如下:
    xie_bo =
    Columns 1 through 4
    51.749123
    103.498246
    155.247369
    206.996492
    Columns 5 through 8
    258.745615
    310.494738
    362.243861
    413.992984
    Columns 9 through 12
    频率校正值
    ans =
    Columns 1 through 4
    49.3077113000786
    98.6186179056816
    150.359933774583
    199.67687346012
    Columns 5 through 8
    251.413025795446
    298.265414236582
    350.024879021602
    399.306840999873
  • 但是若采用
    ee = mod((p1-p2)/180/(1-1/N),Fs/N);
    xie_bo
    disp('频率校正值')
    则能够得到较为准确的基频,结果如下:
    xie_bo =
    Columns 1 through 4
    51.749123
    103.498246
    155.247369
    206.996492
    Columns 5 through 8
    258.745615
    310.494738
    362.243861
    413.992984
    频率校正值
    ans =
    Columns 1 through 4
    51.7491175500786
    101.060024155682
    153.878992002122
    203.195931687659
    Columns 5 through 8
    254.932084022985
    300.706820486582
    352.466285271602
    401.748247249873
  • 从实验的结果看,我就无法理解了为什么不是对频率分辨率来取模了,
  • 但是对于本贴一楼的程序来说(即没有xie_bo2的参与),如果选择对频率分辨率Fs/N来取模的话,得到的频率却不对了,所以现在很迷茫,请王老师帮我解答一下!
  • 还有就是如果“对1进行取余数是使计算频偏 >0, 以适应下面计算频率校正值公式”,那么对其他的正数取余数,或对Fs/N取余数后在求绝对值,这三种之间有什么不同呢?烦请王老师帮我解答一下,谢谢!
发表于 2012-6-14 20:34 | 显示全部楼层
回复 4 # chunmu126 的帖子
附录2和附录3的2个程序都是用於理解fft/apfft和 apfft/apfft校正原理的程序, 不是实用程序, 所以
1)采样频率选为N, 即fft的频率分辨率为1Hz/格, 不作频率转换使初学者搞不清楚
2)不用相位差判断语句, 所以出现振幅校正公式中有floor语句
3)不加噪音
4)不加自动搜索振幅峰值语句, rr=round(f1)是为了找出谱峰线的位置(rr+1),
5)加已知余弦信号, 这样可以知道校正是否正确
采样频率选为fs, 加自动搜索振幅峰值和加相位差判断语句的 apfft/apfft 和 fft/apfft 校正程序,
见本论坛zhwang554日志
”自动搜索峰值的 apfft/apfft 和 fft/apfft 校正程序”
http://forum.vibunion.com/home-spa ... -blog-id-18060.html
这个程序可分析实际数据,也可对已知频率(包恬振幅,相位)做估计
rr=round(i*f11)是为了找出谱峰线的位置,
你设置rr=round(i*50), 这样对许多频率成份找出谱峰线的位置就不对了,笫1个基频就不对,实际峰值在rr=round(50.749123)=51,你设置成rr=round(1*50)=50, 频率校正值当然不对了. 不知(基频)频率值, 加自动搜索振幅峰值语句, 找出谱峰线的位置. 不能任意设置rr=round(i*50)
你提出对频率分辨率来取模, xie_bo2参与时(这设置就不对)虽对笫一个频率是对的, 其它谐波都不对, 没有xie_bo2参与(本贴一楼的程序)得到的频率都不对,这有什么研究意义
所以找出谱峰线,对1取模
用相位差判断语句时不取模
对1进行取余数是使计算频偏在 0-1 之间
发表于 2014-10-23 16:08 | 显示全部楼层
采样点数与采样频率有什么关系么?只采一个周期的是不是误差大?
发表于 2014-10-29 23:32 | 显示全部楼层
刚好采一个周期的话就是整周期采样,不用校正了。
一般来讲应该多采几个周期,以减小负频率的干涉。
发表于 2014-11-21 13:31 | 显示全部楼层
整周期采样,但不是同步,仍然在泄漏吧。
我采样8周期,按以上方法,波形的初相位对计算结果影响挻大的,是什么原因?
GMT+8, 2025-8-13 00:08 , Processed in 0.074080 second(s), 17 queries , Gzip On.
