查看: 3129|回复: 0
[结构分析] [转帖]Ansys排水管道计算
发表于 2006-4-22 08:05 | 显示全部楼层 |阅读模式
埋设在地下的排水管道
rpc管道混凝土管道用solid45单元模拟,link8模拟纵向钢筋和箍筋,直接建立单元,采用复制的方式直接生成实体。让link单元和solid单元共用节点,(nummrg和numcmp命令)这样就省去了耦合和添加约束方程,预应力采用施加初始应变的方式。约束采用简直方式。计算以后在支座处有比较名显的应力集中现象。
  1. /prep7
  2. et,1,solid45
  3. mp,ex,1,4.5e10
  4. mp,prxy,1,0.25
  5. et,2,link8
  6. mp,ex,2,2.0e11
  7. mp,prxy,2,0.3
  8. R,1,137.4e-6, ,
  9. csys,1
  10. n,1,0.52
  11. n,2,0.56
  12. n,3,0.6
  13. NGEN,2,3,1,3,1,0,18,0,1,
  14. NGEN,2,6,1,6,1,0,0,0.05,1,
  15. type,1
  16. mat,1
  17. e,1,2,5,4,7,8,11,10
  18. e,2,3,6,5,8,9,12,11
  19. eplot
  20. egen,20,12,1,2,1,,,,,,,18,,
  21. nummrg,all
  22. numcmp,all
  23. egen,100,120,1,40,1,,,,,,,,0.05
  24. nummrg,all
  25. numcmp,all
  26. type,2
  27. mat,2
  28. *dim,nOne,array,21
  29. *do,i,1,16
  30. *do,j,1,21
  31. nsel,s,loc,x,0.56
  32. nsel,r,loc,z,0.25+0.3*(i-1)
  33. nsel,r,loc,y,18*(j-1)
  34. *get,nOne(j),node,,num,max
  35. *enddo
  36. *do,j,1,20
  37. e,nOne(j),nOne(j+1)
  38. *enddo
  39. *enddo
  40. *dim,nTwo,array,101
  41. *do,i,1,10
  42. *do,j,1,101
  43. nsel,s,loc,x,0.56
  44. nsel,r,loc,y,36*(i-1)
  45. nsel,r,loc,z,0.05*(j-1)
  46. *get,nTwo(j),node,,num,max
  47. *enddo
  48. *do,j,1,100
  49. e,nTwo(j),nTwo(j+1)
  50. *enddo
  51. *enddo
  52. alls
  53. nummrg,all
  54. numcmp,all
  55. ESEL,S,TYPE,,2
  56. BFE,all,TEMP,1,-375, , ,
  57. /view,1,1,1,1
  58. /replot
  59. save
GMT+8, 2025-1-16 16:11 , Processed in 0.102564 second(s), 17 queries , Gzip On.
