查看: 1000|回复: 2
[编程技巧] 求助 希望帮忙啊xiexiexiexie
发表于 2012-3-18 16:34 | 显示全部楼层 |阅读模式
界面为右图      程序代码如下   怎么运行不了啊     求助
function playsound(soundtype,frequency,amp,phase)
Fs=41000;  %设置采样频率
x=[0:1/Fs:1];
switch soundtype=input_1
    case 1 %正弦波
        y=amp*sin(2*pi*x*frequency+phase);
    case 2 %方波
        y=amp*sign(sin(2*pi*x*frequency+phase));
    case 3 %三角波
        y=amp*sawtooth(2*pi*x*frequency+phase,0.5);
    otherwise
        errordlg('Illegal wave type','Choose errer');
plot(x,y);  %显示波形
axis([0,0.01,-200,200]);
wavplay(y,Fs,'async'); %播放声音,使用async(异步)模式可以实现发声的混迭
% UIWAIT makes untitled10 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
% --- Outputs from this function are returned to the command line.
function varargout = untitled10_OutputFcn(hObject, eventdata, handles)
% varargout  cell array for returning output args (see VARARGOUT);
% hObject    handle to figure
% eventdata  reserved - to be defined in a future version of MATLAB
% handles    structure with handles and user data (see GUIDATA)
% Get default command line output from handles structure
varargout{1} = handles.output;
handles.frequency=str2double(get(hObject,'String'))
guidata(hObject,handles);
% hObject    handle to frequency (see GCBO)
% Hints: get(hObject,'String') returns contents of frequency as text
%        str2double(get(hObject,'String')) returns contents of frequency as a double
% --- Executes during object creation, after setting all properties.
function frequency_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
handles.amp=str2double(get(hObject,'String'))
% hObject    handle to amp (see GCBO)
% Hints: get(hObject,'String') returns contents of amp as text
%        str2double(get(hObject,'String')) returns contents of amp as a double
function amp_CreateFcn(hObject, eventdata, handles)
handles.phase=str2double(get(hObject,'String'))
% hObject    handle to phase (see GCBO)
% Hints: get(hObject,'String') returns contents of phase as text
%        str2double(get(hObject,'String')) returns contents of phase as a double
function phase_CreateFcn(hObject, eventdata, handles)
% --- Executes on button press in playsound.
playsound(handles.soundtype,handles.frequency,handles.amp,handles.phase);
% hObject    handle to playsound (see GCBO)
% --- Executes on button press in pushbutton2.
set(handles.popupmenu1,'value',1);
set(handles.edit1,'String','400');
set(handles.edit4,'String','180');
set(handles.edit5,'String','0');
handles.soundtype=1;
handles.frequency=400;
handles.amp=180;
handles.phase=0;
% hObject    handle to pushbutton2 (see GCBO)
% --- Executes on button press in pushbutton3.
close
% hObject    handle to pushbutton3 (see GCBO)
% --- Executes on selection change in soundtype.
handles.soundtype=get(hObject,'Value');
% hObject    handle to soundtype (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns soundtype contents as cell array
%        contents{get(hObject,'Value')} returns selected item from soundtype
function soundtype_CreateFcn(hObject, eventdata, handles)
% Hint: popupmenu controls usually have a white background on Windows.
function soundtype_Callback(hObject, eventdata, handles)
function frequency_Callback(hObject, eventdata, handles)
function playsound_Callback(hObject, eventdata, handles)
发表于 2012-3-18 17:45 | 显示全部楼层
回复 1 # 黄忠林 的帖子
lz的错误信息是什么啊
赞成: 5.0
赞成: 5
  发表于 2012-3-19 00:36
发表于 2012-3-19 20:51 | 显示全部楼层
没有错误信息,gui的程序很多内容,找问题要从错误信息提示开始
GMT+8, 2024-9-30 05:24 , Processed in 0.058980 second(s), 22 queries , Gzip On.
