查看: 1990|回复: 1
[Patran专区] 螺栓加载预紧力的问题
发表于 2012-2-9 09:54 | 显示全部楼层 |阅读模式
各位大侠,我用Patran的bolt preload shareware对螺栓加载预紧力时,总提示The over closure MPC independent(retained) terms must all have a common
control node. Either the control node is not the same in all independent
terms or there are duplicate nodes between terms,which is not allowed.Only
the control node can(must)appear in each independent term.这是怎么回事啊?
发表于 2012-3-8 09:51 | 显示全部楼层
加我 QQ  723438929  帮你解决
GMT+8, 2025-7-9 23:28 , Processed in 0.051670 second(s), 18 queries , Gzip On.
