查看: 2166|回复: 4
[Workbench] [求助]如何在workbench中调用CFD??
发表于 2006-4-18 10:25 | 显示全部楼层 |阅读模式
我在CFX中建立了网格,而且电脑也安装了CFX-5.7.1,为什么在project的界面里面看不到ADVANCED CFD这个选项呢???
If you have installed CFX-5.7.1 so that you can run CFX-5 in ANSYS Workbench, then the first time you create a volume mesh within a project, a new Advanced CFD entry will appear on your Project Page, which will contain the CFX-Pre Mesh File. Every subsequent CFX-Pre Mesh File that you create will appear under this entry. Each of these entries can be used to start CFX-5 in ANSYS Workbench; see the CFX-5 User Documentation for details. When you start CFX-Pre in ANSYS Workbench, using one of these CFX-Pre Mesh Files, then CFX-Pre automatically saves its simulation setup using this file and the simulation file .cfx with the same base name. If you later regenerate the volume mesh, you must choose a different name for your new CFX-Pre Mesh File to avoid overwriting data placed in the existing CFX-Pre Mesh File by CFX-Pre.
发表于 2006-4-19 07:56 | 显示全部楼层
回复:(incredible)[求助]如何在workbench中调用CFD...
If you have installed  CFX-5.7.1 so that you can run CFX-5 in ANSYS Workbench, then the first time you create a volume mesh within a project, a new Advanced CFDentry will appear on your Project Page, which will contain the CFX-PreMesh File. Every subsequent CFX-Pre Mesh File that you create willappear under this entry. Each of these entries can be used to startCFX-5 in ANSYS Workbench; see the CFX-5 User Documentation for details.When you start CFX-Pre in ANSYS Workbench, using one of these CFX-PreMesh Files, then CFX-Pre automatically saves its simulation setup usingthis file and the simulation file .cfx with the same basename. If you later regenerate the volume mesh, you must choose adifferent name for your new CFX-Pre Mesh File to avoid overwriting dataplaced in the existing CFX-Pre Mesh File by CFX-Pre.
注意红色标记这一举
 楼主| 发表于 2006-4-19 22:00 | 显示全部楼层
是的,我创建了 volume mesh。但是仍然不能出现 advance CFD的选项。是否我对 create a volume mesh within a project这句话理解错误?
 楼主| 发表于 2006-4-21 08:56 | 显示全部楼层
是不是 在安装CFX5.7.1 和安装workbench的顺序上有要求?
发表于 2006-10-24 23:52 | 显示全部楼层
怎么还没有好的解决办法?
[ 本帖最后由 xuruikl 于 2007-8-6 20:32 编辑 ]
GMT+8, 2025-8-2 12:37 , Processed in 0.074603 second(s), 19 queries , Gzip On.
