查看: 2710|回复: 1
[ADAMS专区] ADAMS VIBRATION設定問題
发表于 2012-1-9 15:55 | 显示全部楼层 |阅读模式
各位好:
           不管我的INPUT CHANNEL和OUTPUT CHANNEL的點設在哪裡都會出現以下錯誤,想請問要如何設定INPUT和OUTPUT
ERROR:
Static equilibrium analysis has not been successful.
  The maximum number of iterations 25, has been reached.
  For the last attempted iteration:
  The equation with the largest error was model_1.PART33 Comp = 1 Error = 373.612760
  The variable receiving the largest increment was model_1.JOINT_1 Comp = 1 Delta = 455.656534.
ERROR:   Lockup detected.
发表于 2012-4-17 12:40 | 显示全部楼层
这应该是你的模型不能静平衡吧, 我之前仿真也是这样
还是从模型方面找问题吧
GMT+8, 2025-7-9 23:43 , Processed in 0.080430 second(s), 18 queries , Gzip On.
