查看: 1631|回复: 1
[求助]ANSYS显示一阶模态所有节点位移时如何改变说明文字的间隔?
发表于 2006-4-17 12:38 | 显示全部楼层 |阅读模式
ANSYS模态分析后,显示一阶模态所有节点位移时如何改变说明文字的间隔?<br>(或者把说有说明文字都去掉,我只需要数据) <br>ANSYS默认是大约每隔33个节点便会出现说明文字。 <br>例如: <br>***** POST1 NODAL DEGREE OF FREEDOM LISTING *****                             <br><br><br>LOAD STEP=     1  SUBSTEP=     3                                             <br><br>  FREQ=    102.71      LOAD CASE=   0                                         <br><br><br>THE FOLLOWING DEGREE OF FREEDOM RESULTS ARE IN GLOBAL COORDINATES            <br><br><br>   NODE      UZ     <br>   1777   16.969     <br>   1778   16.969     <br>   1779   13.046     <br>   1780   13.046     <br>   1781   9.3529     <br>   1782   9.3529     <br>   1783   5.9975     <br>   1784   5.9975     <br>   1785   3.1227     <br>   1786   3.1227     <br>   1787  0.96909     <br>   1788  0.96909     <br>   1789   37.524     <br>   1790   37.524     <br>   1791   33.427     <br>   1792   33.427     <br>   1793   29.281     <br>   1794   29.281     <br>   1795   25.117     <br>   1796   25.117     <br>   1797   20.976     <br>   1798   20.976     <br>   1799   16.914     <br>   1800   16.914     <br>   1801   13.000     <br>   1802   13.000     <br>   1803   9.3160     <br>   1804   9.3160     <br>   1805   5.9711     <br>   1806   5.9711     <br>   1807   3.1073     <br>   1808   3.1073     <br>   1809  0.96344     <br>   1810  0.96344     <br>   1811   37.445     <br>   1812   37.445     <br>   1813   33.342     <br><br>***** POST1 NODAL DEGREE OF FREEDOM LISTING *****                            <br><br><br>LOAD STEP=     1  SUBSTEP=     3                                             <br><br>  FREQ=    102.71      LOAD CASE=   0                                         <br><br><br>THE FOLLOWING DEGREE OF FREEDOM RESULTS ARE IN GLOBAL COORDINATES            <br><br><br>   NODE      UZ     <br>   1814   33.342     <br>   1815   29.194     <br>   1816   29.194     <br>   1817   25.029     <br>   1818   25.029     <br>   1819   20.892     <br>   1820   20.892     <br>   1821   16.837     <br>   1822   16.837     <br>   1823   12.933     <br>   1824   12.933     <br>   1825   9.2627     <br>   1826   9.2627     <br>   1827   5.9330     <br>   1828   5.9330     <br>   1829   3.0850     <br>   1830   3.0850     <br>   1831  0.95603     <br>   1832  0.95603     <br>   1833   37.321     <br>   1834   37.321     <br>   1835   33.225     <br>   1836   33.225     <br>   1837   29.079     <br>   1838   29.079     <br>   1839   24.921     <br>   1840   24.921     <br>   1841   20.794     <br>   1842   20.794     <br>   1843   16.754     <br>   1844   16.754     <br>   1845   12.865     <br>   1846   12.865     <br>   1847   9.2114     <br>   1848   9.2114     <br>   1849   5.8981     <br>   1850   5.8981     <br><br>***** POST1 NODAL DEGREE OF FREEDOM LISTING *****                            <br><br><br>LOAD STEP=     1  SUBSTEP=     3                                             <br><br>  FREQ=    102.71      LOAD CASE=   0                                         <br><br><br>THE FOLLOWING DEGREE OF FREEDOM RESULTS ARE IN GLOBAL COORDINATES <br><br>为了对数据处理,想改变说明文字出现的间隔节点数,请教达人如何改变设置!!! <br>多谢^_^ <br><br>[em01]
[此贴子已经被yejet于2006-4-17 14:16:09编辑过]
发表于 2006-4-17 13:23 | 显示全部楼层
<P>可以用*get命令把你想要的结果保存到一个数组里面,然后利用*CFWRITE或*VWRITE命令写入到指定文件.下面是使用*VWRITE实现该过程的一个实例:</P>
<P>/post1<br>set,,,,,10.0<br>*get,ntemp01,node,2,temp ! 时间等于10时的节点2的温度值 <br>*get,ntemp02,node,9,temp ! 时间等于10时的节点9的温度值<br>*get,ntemp03,node,7,temp ! 时间等于10时的节点7的温度值</P>
<P>*vwrite,ntemp01,ntemp02,ntemp03<br>(T1,'N2 TEMP=',F5.1,', N9 TEMP=',F5.1,', N7 TEMP=',F5.1)<br>/output,nodetemp,dat</P>
<P>其中,命令/output可以用于确定输出方向,即输出到ansys的输出窗口(OUTPUT WINDOW)中,或者指定的文件中。上面将温度值输出到nodetemp.dat文件中,内容如下:</P>
<P>N2 TEMP= 19.2, N9 TEMP= 19.8, N7 TEMP= 20.8</P>
[此贴子已经被作者于2006-4-17 13:30:54编辑过]
GMT+8, 2025-1-16 16:03 , Processed in 0.094526 second(s), 17 queries , Gzip On.
