查看: 2691|回复: 0
信号输入模块 信号输出模块 信号输出/输入I / O模块
发表于 2011-11-15 22:53 | 显示全部楼层 |阅读模式
上海葩星信息科技有限公司专业销售Speedgoat 信号输入模块 信号输出模块  I / O模块
。葩星公司是Speedgoat 长期合作代理商。
这些I / O模块获取模拟信号(输入),并产生模拟输出信号(输出)。各种模块提供输入或输出通道,分辨率,采样模式,转换率,以及由此产生的驱动程序,因此,目标应用程序的延迟时间差异。
不同的模拟I / O模块是:
  I/O module
  Res
Sampling mode
Analog input channels
Analog output channels
Digital channels
  IO101
  16-bit
AD: Sequential
DA:Simultaneous
32 single-ended or16 ifferential
8 single-ended
16 individually electable as input or output
  IO102
  16-bit
AD: Sequential
DA: imultaneous
32 single-ended or 16 ifferential
4 single-ended
8 input and 8 output
  IO103
  16-bit
AD: Sequential
DA: imultaneous
16 single-ended or 8 differential
8 single-ended
  IO104
  16-bit
AD: imultaneous DA: imultaneous
8 single-ended or 8 differential
4 single-ended
  IO105
  16-bit
AD: Sequential
64 single-ended or 32 ifferential
  IO106
  16-bit
AD: imultaneous
64 single-ended or 32    differential
  IO107
  16-bit
  DA: Simultaneous
  16 differential
  IO108
  16-bit
  DA: Simultaneous
  8 differential
  IO109
  24-bit
  AD: Simultaneous
  12 differential
  IO110
  16-bit
  DA: Simultaneous
  32 single-ended
  IO111
  16-bit
  DA: Simultaneous
  16 single-ended
  IO112
  18-bit
  AD: Simultaneous
  4, 8, 16, or 32, differential
  IO113
  18-bit
  DA: Simultaneous
  8 single-ended or
8 differential
公司除销售Speedgoat 音频XLR接口板  XLR音频平衡板  Speedgoat 音频平衡板 Audio XLR Panels外,其他的主要I / O接口有:高速数据传输接口,通用设备通信I / O接口,异步/同步串行I / O接口,QAD的代码模块IO3xx FPGA的I / O模块,并行数字I/ O接口,模拟信号输入输出I / O接口,音频/语音模拟I / O模块.
GMT+8, 2025-8-1 03:15 , Processed in 0.076552 second(s), 19 queries , Gzip On.
