查看: 1904|回复: 1
[稳定性与分岔] 我解方程为什么说这个样子?很奇怪。纠结中,大家看看程序啊。
发表于 2011-9-8 10:12 | 显示全部楼层 |阅读模式
我的M函数文件是
function xdot=dianci1(t,x)
   global w
m=19.6;g=9.8;la=0.116;lb=0.144;l=la+lb;
Jox=0.393;Joy=0.393;Joz=0.023;
ca=0.0004;cb=0.0004;
Ioxa=4;Ioya=4;Ioxb=4;Ioyb=4;
ra=0.0442;Da=0.08;Ara=pi*Da*ra;
rb=0.0442;Db=0.08;Arb=pi*Db*rb;
axy=0.16;
Nra=57;Nrb=57;miu0=4e-7*pi;
K=1;%K=7800;
KP=3.8;KI=200;KD=0.01;
m1=lb*m/l;m2=la*m/l;
e1=0;e2=0;
ixa=K*(KP*x(1)+KI*x(2)+KD*x(1));
iya=K*(KP*x(3)+KI*x(4)+KD*x(3));
ixb=K*(KP*x(5)+KI*x(6)+KD*x(5));
iyb=K*(KP*x(7)+KI*x(8)+KD*x(7));
%u(k)=kp*x(1)+kd*x(2)+ki*x(3);   %PID Controller;
%x(1)=error(k);                        %Calculating P
%x(2)=(error(k)-error_1)/ts;           %Calculating D
%x(3)=x(3)+error(k)*ts;                %Calculating I
%xi(k)=x(3);
fra=miu0*Nra^2*Ara*(Ioxa+ixa)^2/(4*(ca+x(1))^2);
fla=miu0*Nra^2*Ara*(Ioxa-ixa)^2/(4*(ca-x(1))^2);
fta=miu0*Nra^2*Ara*(Ioya+iya)^2/(4*(ca+x(3))^2);
fba=miu0*Nra^2*Ara*(Ioya-iya)^2/(4*(ca-x(3))^2);
frb=miu0*Nrb^2*Arb*(Ioxb+ixb)^2/(4*(cb+x(5))^2);
flb=miu0*Nrb^2*Arb*(Ioxb-ixb)^2/(4*(cb-x(5))^2);
ftb=miu0*Nrb^2*Arb*(Ioyb+iyb)^2/(4*(cb+x(7))^2);
fbb=miu0*Nrb^2*Arb*(Ioyb-iyb)^2/(4*(cb-x(7))^2);
Fxa=fra-fla+axy*(x(1)/ca)*(fta+fba);
Fya=fta-fba+axy*(x(3)/ca)*(fra+fla);
Fxb=frb-flb+axy*(x(5)/cb)*(ftb+fbb);
Fyb=ftb-fbb+axy*(x(7)/cb)*(frb+flb);
fx=m1*e1*w^2*cos(w*t)+m2*e2*w^2*cos(w*t);
fy=-m1*e1*w^2*sin(w*t)+m2*e2*w^2*sin(w*t);
A=-Fxa-Fxb+fx;
B=-Fya-Fyb+m*g+fy;
C=Fxa*la-Fxb*lb-Joz/l*w*x(2)+Joz*w/l*x(4);
D=Fya*la-Fyb*lb+Joz/l*w*x(6)+Joz*w/l*x(8);
xdot=[x(2);
     (Joy*A*l-C*l*la*m)/(Joy*la*m+Joy*lb*m);
      x(4);
       (Joy*A*l+ C*l*lb*m)/(Joy*la*m+Joy*lb*m);
      x(6);
      (Jox*B*l-D*l*la*m)/(Jox*la*m+Jox*lb*m);
      x(8);
      (Jox*B*l+D*l*lb*m)/(Jox*la*m+Jox*lb*m)];
在matlab中运行程序
clc;
clear;
%global w
w=100;
x0=[0,0,0,0,0,0,0,0];
for n=1:60
     [t,x]=ode45('dianci1',[0 10],x0);
x0=x(end,:);
hold on
plot(x(:,1),x(:,2));
但是结果怎么会出错
错误是
??? Error using ==> odearguments at 116
DIANCI1 returns a vector of length 4, but the length of initial conditions vector is 8.
The vector returned by DIANCI1 and the initial conditions vector must have the same number
of elements.
Error in ==> ode45 at 173
[neq, tspan, ntspan, next, t0, tfinal, tdir, y0, f0, odeArgs, odeFcn, ...
Error in ==> jiedianci at 7
我很纠结。我的方程是8个,为什么说是返回4个?
这个我该怎么调式,才能出结果?
希望大家给点建议。
谢谢了。
发表于 2011-9-15 10:45 | 显示全部楼层
是不是“%global w ”没有设为全局变量,没有传递到函数中?
GMT+8, 2025-2-20 16:58 , Processed in 0.067667 second(s), 17 queries , Gzip On.
