查看: 3705|回复: 0
裂纹扩展测试的裂纹扩展片-测量裂纹长度
发表于 2011-8-21 16:44 | 显示全部楼层 |阅读模式
测试设备
产品名称: 裂纹扩展片
型号规格: Krak Gage
生产单位: 美国
主要功能: 间接电流电位法测量裂纹长度
上海褒博机电科技有限公司
www.servotesting.com
info@servostering.com
132 9607 7830
裂纹长度测试是疲劳裂纹扩展研究的前提,而基于间接电流电位法测量裂纹长度的裂纹扩展片具有精度高、成本低、操作简单、抗干扰性强和自动记录与处理等优点。
附件为国内一篇关于裂纹扩展片的介绍。
链接为产品资料下载地址。上海褒博-裂纹扩展测量仪Fractomat_e.pdf
FRACTOMAT® MODEL  2010
Part no
Description
2010
TWO-CHANNEL CRACK-LENGTH MEASURING  AND CONTROL
SYSTEM FOR THR “KRAK-GAGE INDERECT  POTENTIAL DROP
TEST METHOD.
Complete Test System Includes:
  - Two Precision (0.01%) 4 ½ Digit PANEL DISPLAYS for Channels A and B.
  - Microprocessor based control with memory for all switchable Functions,  Including Status indicators.
  - Ten Calibrated SCALE RANGES for each channel for KRAK-GAGES®.
  - Two Calibrated LIMIT DETECTORS with relay contact outputs.
  - Two ZERO-CALIBRATION Circuits each with 4 adjustable Precision current  sources.
  - Built-in Integral FRACTOMAT® CALIBRATOR.
  - ANALOG VOLTAGE OUTPUTS on a pair of front panel tip Jacks for each channel.
  - ANALOG AND LIMIT DETECTOR OUTPUTS on a rear panel Connector.
  - POWER INPUT Module on the rear panel including ON/OFF Switch, AC power line  filter and Fuse Drawer. Power input
  Is 110-2240 VAC. (no range selection necessary).
  - INPUT CABLES, CH A & B, 2 each color coded, 10 ft. long.
  - Instruction / Operating Manual in English.
Universal brushed aluminum and  black vinyl enclosure for Benchtop or 19-in. rack mounting (17 in. W, 5 ¼ in.  H, 10 in. DP) Net Weight: 12 lbs. Gross Shipping Weight: 18 lbs.
file:///C:\Users\a\AppData\Local\Temp\msohtmlclip1\01\clip_image001.gif
FRACTOMAT®
Quantity  Discount Schedule
Applies to multiple purchases of  FRACTOMAT®, Model 2010 on Single purchase order.
2 Units
3 Units
4 – 6 Units
7-10 Units
KRAK-GAGE®
Part no
Description
KRAK-GAGE®, STANDARD GAGE, -100°F to 300°F with epoxy-phenolic fiberglass reinforced backing, 50  micron (.002 in.)
thick, constantan alloy, 5 micron  thick, including separate epoxy glass solder terminals (4 each gages).
KG-A05
5 mm, packaged @ 6 gages/ea. per pkg
KG-A10
10 mm, packaged @ 6 gages/ea. per pkg
KG-A15
15 mm, packaged @ 6 gages/ea. per pkg
KG-B20
20 mm, packaged @ 6 gages/ea. per pkg
KG-B25
25 mm, packaged @ 6 gages/ea. per pkg
KG-B30
30 mm, packaged @ 6 gages/ea. per pkg
KG-C40
40 mm, packaged @ 4 gages/ea. per pkg
KH-C50
50 mm, packaged @ 4 gages/ea. per pkg
KG-D100
100 mm, packaged @ 2 gages/ea. per pkg
KG-E200
200 mm, packaged @ 1 gage ea. per pkg
FOR BOLT HOLES,  SERIES –BH
KRAK-GAGE®, SERIES – BH for bolt holes, constantan alloy 5 micron, epoxy phenolic backing,  fiberglass reinforced, 50 micron
  nominal thickness, -100° F to +300°F. Including separate epoxy glass solder  terminals. Furnished with calibration curves. All packaged @ 4 gages ea. Per  pkg.
KG-BH3125-CE
For 0.3125 In. max dia., 12 mm crack length
KG-BH4375
For 0.4375 In. max. dia., 18 mm crack length
KG-BH5616-X08
For 0.5625 In. max dia., 8 mm crack length
KG-BH5616-x15
For 0.5625 In. max. dia., 15 mm crack length
KG-BH5625
For 0.5625 In. max. dia., 22 mm crack length
KGBH7500
For 0.7500 In. max. dia., 28 mm crack length
KG BH10000
For 1.0000 In. max dia., 38 mm crack length
Quantity Discount Schedule:
KRAK-GAGE®
Same Type Gages  on single order:
1-4 Pkgs. – Net
5-9 Pkgs. – Less 10%
10-24 Pkgs. – Less 16%
25 up Pkgs. – Less 20%
ACCESSORIES  & BONDING JIGS
Part No.
Description
353-ND
EPOXY ADHESIVE, TTI 353-ND, Per Bulletin 8010-2r1, Kit of 4 each  pre-weighed mixing pouches of 4 grams net adhesive (16 grams).
TSC-BJ
TEFLON CURING SHEETS, for use with Bonding Jigs. 10 mils thick
  (0.010”). Kit of 4 sheets each, 5” X 8”.
SRP-BJ
SILICONE RUBBER PRESSURE PADS, 1/8” thick with silicone Adhesive backing  on one side, 50 durometer, for use with Bonding Jigs. Kit of 2 pads each  4.25” wide X 9.00” long.
ICA-2005
INPUT CABLE ASSEMBLIES, with color-coded Lemo connectors and 10 ft.  shielded cable. Spare set of 2 each.
IME-2005
SPARE INSTRUCTION MANUAL, for FRACTOMAT® KRAK-GAGE ® 2 in. ring binder,  (English only)
BONDING/CURING JIGS, per Technical Bulletin BJ-581, of Aluminum and  stainless steel, with Silicone Pressure Pads and Teflon Curing Sheets,  Maximum cure pressure 30-35 psi, Maximum bonding temperature 250 F.
BJ-A05
For maximum size – A05 KRAK-GAGE®, 10X10 mm or ½ “ X ½” Impact or Bend  specimens.
BJ-B25
For maximum size – B25 KRAK-GAGE® maximum specimen size 3.00” wide X  1.75” thick.
BJ-B30
For maximum size – B30 KRAK-GAGE®., maximum specimen size
  5.25” wide X 2.00” thick.
BJ-C50
For maximum size – C50 KRAK-GAGE®, maximum specimen size
  6.00” X 3.00” thick.
-CN
or specify - Option –CN for pad size for center-notched specimens for  maximum 2 ea. –B30 KRAK-GAGES®.
裂纹扩展测试的裂纹扩展片技术.pdf
69.62 KB, 下载次数: 5
GMT+8, 2025-5-29 05:03 , Processed in 0.091633 second(s), 24 queries , Gzip On.
