返回列表 发新帖
楼主: 小文
[综合讨论] 请教大家关于悬臂风机双面动平衡的做法
发表于 2011-7-7 08:28 | 显示全部楼层
和单面类似
发表于 2011-7-12 09:24 | 显示全部楼层
楼主问题中的“宽大流道和普通叶轮”的概念大概应该是这个意思:
当叶轮的流道的宽度与叶轮直径之比<0.5时,为“普通叶轮”,在这时候,转子的不平衡一般以静平衡居多,即使存在一定的力偶不平衡,对转子的影响也相对较小,在做现场动平衡时一般只需要在叶轮的一个平面上加重去重即可。
当叶轮的流道的宽度与叶轮直径之比>0.5时,为“宽大流道”,在这时候转子如果会产生力偶不平衡的话,只在叶轮的一个平面上加重、去重,就很难解决转子的平衡问题,就需要在叶轮的两个平面上加重、去重。
这样的话,在现场做动平衡就与只在一个面上加重不太一样了。
 楼主| 发表于 2011-7-14 10:17 | 显示全部楼层
回复 17 # 无名的振动 的帖子
能否再详细说明一下具体的过程吗?是否是先做好静平衡,然后再旋转180°加同样重量的配重量?
发表于 2011-7-14 10:45 | 显示全部楼层
When balancing an overhung rotor, one of the two following procedures should be taken:
1 BALANCING OVERHUNG ROTORS BY CLASSIC SINGLE-PLANE STATICCOUPLE METHOD:
Figure 42 helps explain methods of balancing overhung rotors. Classically, Bearing A is most sensitive to static unbalance whereas the bearing farthest from the fan wheel to be balanced (Bearing B) is most sensitive to couple unbalance. Since Plane 1 is closest to the rotor center of gravity (C.G.), static corrections should be made in this plane while measuring the response on Bearing A. On the other hand, measurements should be made on Bearing B when making couple corrections in Plane 2. However, placing a trial weight in Plane 2 will destroy the static balance achieved at Bearing A. Therefore, in order to maintain he static balance at Bearing A, a trial weight placement which will generate a couple must be used. Thus, a trial weight of identical size should be placed in Plane 1 at an angle 180° opposite the trial weight in Plane 2。
Therefore, either the data collector can be used using single-plane balance software or the single-plane graphic technique previously explained can be successfully employed on many overhung rotors, particularly if the ratio of rotor length-to-diameter (L/D) is less than approximately .50 (where L is length of the rotating component on which correction weights will be placed and D is the diameter of this component.
Following below will be a description of this classic single-plane balancing technique for overhung rotors.
a. SET UP DATA COLLECTOR  OR SPECTRUM ANALYZER INSTRUMENT
The data collector, photo-tach and transducer should be set up as previously described under Sections K & L and Figure 40 showing the two-plane balancing procedure. Alternatively, the analyst may wish to employ either a swept-filter analyzer that drives a strobe light, or a spectrum analyzer which will fire a photo-tach for phase measurements.
b. TAKE INITIAL MEASUREMENTS
Take initial measurements of 1X RPM amplitude, frequency and phase before adding any trial weights. Measurements should be taken on both the outboard and inboard bearings in both vertical and horizontal directions. The radial direction measurement having the highest amplitude will normally be employed for initial balancing (however, after correcting unbalance in the radial direction, measurements will have to taken in the other directions to ensure amplitudes in all directions likewise acceptable).
c. DETERMINE IF THE DOMINANT UNBALANCE PROBLEM IS STATIC OR COUPLE UNBALANCE
Looking at the amplitude and phase measurements taken on both bearings in the radial and horizontal directions, determine if the problem is dominated by either static or couple unbalance. If phase differences between the outboard and inboard bearings are between 90° and 180° in both the vertical and horizontal directions, the dominant problem will be couple unbalance. On the other hand, if these differences are both anywhere from 0° to approximately 40°, a static unbalance is dominant. Of course, phase differences ranging from approximately 40° to 140° are truly dynamic balance once again with a combination of static and couple. If the problem appears to be mostly couple unbalance, use couple unbalance procedures outlined below. However, if the problem appears to be predominantly static or dynamic unbalance, employ static balance procedures. For now, we will assume that the problem is mostly static.
d. MAKE A SINGLE-PLANE STATIC BALANCE
Referring to Figure 22, use single-plane techniques taking measurements on bearing A and placing trial and correction weights in Plane1.
e.      DETERMINE IF RESULTANT VIBRATION AMPLITUDES MEET REQUIRED      CRITERIA
After completing the single-plane static balance using Plane 1, repeat vibration measurements on both the outboard and inboard bearings in each direction (including axial) and ensure that amplitudes now meet allowable criteria.
f. IF CONSIDERABLE COUPLE UNBALANCE NOW REMAINS, CONTINUE WITH SINGLE-PLANE BALANCE FROM BEARING B
Overhung rotors often have large cross-effects which means that single-plane balancing from Plane 1 will often cause high vibration on bearing B. Therefore, the analysts will perform another single-plane balance, this time making their measurements from bearing B farthest from the component to be balanced. When they arrive at the single-plane correction weight solution, they should place this weight in Plane 2; and then place an identical size correction weight in Plane 1 180° away from the weight location in Plane 2.
g. DETERMINE IF AMPLITUDES NOW MEET ALL CRITERIA
After completing the single-plane couple correction, the analyst must again make measurements in horizontal, vertical and axial directions on each bearing and determine that all amplitudes now meet allowable criteria. Often, further balancing must be done at this point beginning with another single-plane balance using Bearing A and Plane 1 which might possibly be followed by another couple balance correction.
h. IF ALLOWABLE CRITERIA CANNOT BE MET IN ALL THREE DIRECTIONS OF EACH BEARING, PROCEED TO TWO-PLANE BALANCE PROCEDURE OUTLINED BELOW
Sometimes, this single-plane approach will not successfully reduce amplitudes below allowable criteria in all three direction on each bearing, particularly if the L/D ratio is greater than .5 or if the component to be balanced is located far away from the closest bearing. If this happens, two-plane techniques outlined below will have to be taken.
你好,你这个悬臂转子平衡的资料有完整的吗?能否提供看看,十二分谢谢!  详情 回复 发表于 2017-9-21 08:54
发表于 2011-7-14 11:00 | 显示全部楼层
悬臂转子
悬臂转子
发表于 2011-7-14 11:01 | 显示全部楼层
这是一种做法,自己翻译下吧
发表于 2011-7-14 14:25 | 显示全部楼层
回复 18 # 小文 的帖子
如果先做好静平衡,然后再旋转180°加同样重量的配重量,岂不是和没做一个样吗
 楼主| 发表于 2011-7-14 15:44 | 显示全部楼层
回复 21 # vibfuture 的帖子
太考验人了,不过还是谢谢了~~
发表于 2017-9-21 08:54 | 显示全部楼层
1 BALANCING  ...
GMT+8, 2025-5-14 17:57 , Processed in 0.069018 second(s), 23 queries , Gzip On.
