查看: 3182|回复: 0
[综合讨论] S function疑问,sizes.NumSampleTimes疑问
发表于 2011-6-17 15:37 | 显示全部楼层 |阅读模式
function [sys,x0,str,ts] = zhu(t,x,u,flag)
switch flag
  case 0
    [sys,x0,str,ts]=mdlInitializeSizes;
  case 3
    sys=mdlOutputs(t,x,u);
  case {1,2,4,9}
    sys=[];
  otherwise
    error(['Unhandled flag = ',num2str(flag)]);
function [sys,x0,str,ts]=mdlInitializeSizes
sizes = simsizes;
sizes.NumContStates  = 0;
sizes.NumDiscStates  = 0;
sizes.NumOutputs     = 1;
sizes.NumInputs      = 1;
sizes.DirFeedthrough = 1;
sizes.NumSampleTimes = 0;   % at least one sample time is needed
sys = simsizes(sizes);
% initialize the initial conditions
x0  = [];
% str is always an empty matrix
str = [];
% initialize the array of sample times
ts  = [0 0];
% end mdlInitializeSizes
% mdlOutputs
% Return the block outputs.
function sys=mdlOutputs(t,x,u)
sys = 0.25*pi*0.0171*8*10^6*(0.027/(0.027-0.25*pi*0.0171*u))^1.2;
% end mdlOutputs
为什么我将sizes.NumSampleTimes =1;改为sizes.NumSampleTimes = 0;就会报错Sample times (TS) matrix returned by M-File S-function 'zhu' in 'untitled/S-Function' must be empty,请各位高手指点一二
GMT+8, 2025-7-15 07:47 , Processed in 0.074446 second(s), 18 queries , Gzip On.
