查看: 3658|回复: 2
[1stopt] 1stopt的初值设定
发表于 2011-6-10 17:03 | 显示全部楼层 |阅读模式
       最近在解一组方程,可是用1stopt程序运行后,结果很奇怪,各参数甚至不在设定的初始范围内,请问是为什么呢?使用的是1stop1.5PJ版,会是版本的问题么?以下是程序内容,能否请大家帮忙看一下呢:
Parameter   x(1:5) , x(11:17) , x23 , x(29:31), x(35:37), x(40:42) ;
            Y(1:6) ;
            x6[0,1] , x7[0,1] ,x8[0,1] ,x9[0,1] ,x10=500e-6[0,1] ;
            x18[0,1]  ,x19[0,1] ,x20[0,1] ,x21[0,1] ,x22=500e-6[0,1] ;
            x24[0,1] , x25[0,1] , x26[0,1] , x27[0,1] , x28[0,1] ;
            x32[0,1] ,x33[0,1] ,x34[0,1] ;
            x38=3500[2000,5000] ,x39=3500[2000,5000],x43[0,1] , x44[0,1];
Constant      P=68 , Ramb=1000e-06,
              Rsurf=100e-06 , Tamb=2550,  TCZ=4000 ,  T=298.15,
              rod=0.089, bet=0.02,   la=0.6,    hsCO=-3950 ,
              hsCO2=-8950 , hsH2=0 ,  sH2O=-13443.9,
              hsAl2O= -1954.3 , hsAl= 12005.2,   hsAlxOx = -2848.6,
             CpsCO=1.04, CpsCO2=0.84, CpsH2=14.43 , CpsH2O=1.87 , CpsAl2O=0.62,
              CpsAl=0.79,
              CpsAlxOx = 0.63,
              CpCO=1.39,  CpCO2=1.53, CpH2=17.6 , CpH2O=2.98 , CpAl=0.77,
              CpAlxOx=0.95,    hAl2O3TCZ= -10447 , hAlTsurf = 2765.2,
              aco=-4260.076, aco2=-9200.45, ah2=-4302.3, ah2o=-14001.44,
              aalxox=-3036.43, aal2o=-2139.15,aal=11775.62, aalo=1812.5,
              hAl2O3Tsurf=-11153.2, CpAl2O=0.83, CpAlO=0.9;
Function    x1*(1/x10-1/Ramb)/(4*pi*rod*(1-bet)) = Ln ((x1*0.18-x2)/(x1*x6-x2));     // 1
             x1*(1/x10-1/Ramb)/(4*pi*rod*(1-bet)) = Ln ((x1*0.174-x3)/(x1*x7-x3));       // 2
             x1*(1/x10-1/Ramb)/(4*pi*rod*(1-bet)) = Ln ((x1*0.008-x4)/(x1*x8-x4));       // 3
             x1*(1/x10-1/Ramb)/(4*pi*rod*(1-bet)) = Ln ((x1*0.27-x5)/(x1*x9-x5));         // 4
             x11*(1/x22-1/x10)/(4*pi*rod*(1-bet)) = Ln ((x11*x6-x12)/(x11*x18-x12));    // 5
             x11*(1/x22-1/x10)/(4*pi*rod*(1-bet)) = Ln ((x11*x7-x13)/(-x13));                  // 6
             x11*(1/x22-1/x10)/(4*pi*rod*(1-bet)) = Ln ((x11*x8-x14)/(x11*x19-x14));    // 7
             x11*(1/x22-1/x10)/(4*pi*rod*(1-bet)) = Ln ((x11*x9-x15)/(-x15));                  // 8
             x11*(1/x22-1/x10)/(4*pi*rod*(1-bet)) = Ln (-x16/(x11*x20-x16));                   // 9
             x11*(1/x22-1/x10)/(4*pi*rod*(1-bet)) = Ln (-x17/(x11*x21-x17));                   //10
             x23*(1/Rsurf-1/x22)/(4*pi*rod*(1-bet)) = Ln (x18/x24);                                   // 11
             x23*(1/Rsurf-1/x22)/(4*pi*rod*(1-bet)) = Ln (x19/x25);                                   // 12
           x23*(1/Rsurf-1/x22)/(4*pi*rod*(1-bet)) = Ln ((x23*x20-x29)/(x23*x26-x29)); // 13
           x23*(1/Rsurf-1/x22)/(4*pi*rod*(1-bet)) = Ln ((x23*x21-x30)/(x23*x27-x30)); // 14
             x23*(1/Rsurf-1/x22)/(4*pi*rod*(1-bet)) = Ln (-x31/(x23*x28-x31));                // 15
             x1=x2+x3+x4+x5;                                 // 16
             x11=x12+x13+x14+x15+x16+x17;      // 17
             x23=x29+x30+x31;                                // 18
             1=x6+x7+x8+x9+x32;                           // 19
             1=x18+x19+x20+x21+x33;                    // 20
             1=x24+x25+x26+x27+x28+x34;            // 21
             Y1=x2*CpCO+x3*CpCO2+x4*CpH2+x5*CpH2O;                                                         // 44
             Y3=x12*CpCO+x13*CpCO2+x14*CpH2+x15*CpH2O+x16*CpAlxOx+x17*CpAl2O;    // 45
             Y5=x29*CpAlO+x30*CpAl2O+x31*CpAl;        // 46
             Y2=x2*aco+x3*aco2+x4*ah2+x5*ah2o;        // 47
             Y4=x12*aco+x13*aco2+x14*ah2+x15*ah2o+x16*aalxox+x17*aal2o;                        // 48
             Y6=x29*aalo+x30*aal2o+x31*aal;        // 49
             Y1*(1/x10-1/Ramb)/(4*pi*(1-bet)*la) = Ln ((Y1*Tamb+Y2-x35)/(Y1*TCZ+Y2-x35));     // 22
             Y3*(1/x22-1/x10)/(4*pi*(1-bet)*la) = Ln ((Y3*TCZ+Y4-x36)/(Y3*x38+Y4-x36));           // 23
             Y5*(1/Rsurf-1/x22)/(4*pi*(1-bet)*la) = Ln ((Y5*x38+Y6-x37)/(Y5*x39+Y6-x37));         // 24
             x37=0.593*(x29*hAl2O3Tsurf)+x31*hAlTsurf;                           // 25
             x36=x37;        // 26
             x35=x36-x40*hAl2O3TCZ;                                                         // 27
             x2/28.011 = -x3/44.011;                                                            // 28
             x4/2.016 = -x5/18.016;                                                              // 29
             (x13-x3)/44.011 = (x2-x12)/28.011;                                         // 30
             (x15-x5)/18.016 = (x4-x14)/2.016;                                            // 31
             x16/86+x17/35=(x13-x3)/44.011 +(x15-x5)/18.016;               // 32
             x40=(102/70)*x17+(102/86)*x16;                                           // 33
             x30=-(70/172)*x29;        // 34
             x41=-1.6e-4;        //  50
             x41=-x31;        // 35
             x42=(-102/172)*x29;        // 36
             x31/27=(x16-x29)/43;        // 37
             x30=x17;        // 38
             x31/27 = -x13/44.011-x15/18.016 ;                                            // 39
             x43/(x43+x44) = 0.122+0.000577*(x38-3500);                        // 40
             -x29=(3653*(Rsurf^2)*P*(1-bet)*x26/43)/((x39^0.5)*(x24/28.011+x25/2.016+x26/43+x27/70+x28/27+x34/33.28));          // 41
             P*(x28/27)/(x24/28.011+x25/2.016+x26/43+x27/70+x28/27+x34/33.28)= exp(12.43-34680/x39);    // 42
             x43+x44=x20;        // 43
发表于 2011-6-10 22:43 | 显示全部楼层
  1. Parameter   x(1:5) , x(11:17) , x23 , x(29:31), x(35:37), x(40:42) ;
  2.             Y(1:6) ;
  3.             x6[0,1] , x7[0,1] ,x8[0,1] ,x9[0,1] ,x10=500e-6[0,1] ;
  4.             x18[0,1]  ,x19[0,1] ,x20[0,1] ,x21[0,1] ,x22=500e-6[0,1] ;
  5.             x24[0,1] , x25[0,1] , x26[0,1] , x27[0,1] , x28[0,1] ;
  6.             x32[0,1] ,x33[0,1] ,x34[0,1] ;
  7.             x38=3500[2000,5000] ,x39=3500[2000,5000],x43[0,1] , x44[0,1];
改为:
  1. Parameter   x(1:5) , x(11:17) , x23 , x(29:31), x(35:37), x(40:42),
  2.             Y(1:6) ,
  3.             x6[0,1] , x7[0,1] ,x8[0,1] ,x9[0,1] ,x10=500e-6[0,1] ,
  4.             x18[0,1]  ,x19[0,1] ,x20[0,1] ,x21[0,1] ,x22=500e-6[0,1],
  5.             x24[0,1] , x25[0,1] , x26[0,1] , x27[0,1] , x28[0,1] ,
  6.             x32[0,1] ,x33[0,1] ,x34[0,1] ,
 楼主| 发表于 2011-6-13 10:30 | 显示全部楼层
回复 2 # dingd 的帖子
谢谢dingd主任!
GMT+8, 2025-8-11 03:43 , Processed in 0.069072 second(s), 17 queries , Gzip On.
