查看: 935|回复: 0
[结构分析] U 是什么意思? U 是什么意思?
发表于 2011-4-25 22:21 | 显示全部楼层 |阅读模式
Target Normal, Couple U to ROT:
(Default) Represents most common type of surface body contact. Constraints are constructed to couple the translational and rotational DOFs. In most types of surface body contact, an offset will exist. Due to this offset there will be a moment created. To get the correct moment, the rotation/displacement DOF's must be coupled together. If the program cannot detect any contact in the target normal direction, it will then search anywhere inside the pinball for contact.
U 是什么意思???
GMT+8, 2025-1-26 02:14 , Processed in 0.078809 second(s), 17 queries , Gzip On.
