查看: 2532|回复: 4
[结构分析] 什么是 superelement ??
发表于 2011-4-10 18:05 | 显示全部楼层 |阅读模式
5.2. Flexible Body Types
A multibody simulation supports two types of flexible bodies:
Bodies that are excited by the motion of other bodies (rigid or flexible) but do not themselves undergo large motions
An engine block is an example of this type, where the block is excited dynamically from the crankshaft, pistons, and other moving parts attached or linked to the block. This case is a straightforward application of traditional superelements.
Bodies that are undergoing large motions
A piston rod is an example of a body undergoing large motions; this type also uses superelements but with the additional capability that the superelement can undergo large motions, and large rotations in particular. A large-rotation superelement involves additional considerations.
什么是 superelement ??
发表于 2011-4-10 20:34 | 显示全部楼层
超单元,一种凝聚了多个一般单元的单元,超单元可以像普通单元一样使用
赞成: 5.0
赞成: 5
  发表于 2011-4-11 00:18
 楼主| 发表于 2011-4-11 00:17 | 显示全部楼层
在 WORKBENCH 中如何使用 superelement ?
什么情况下需要使用 superelement ?
发表于 2011-4-11 15:23 | 显示全部楼层
就象分块矩阵一样。把一个矩阵分成几个小矩阵。小矩阵里面又包含更小的矩阵或元素。超元就是把几个单元类型(或超元)组成一个单元
 楼主| 发表于 2011-4-12 12:37 | 显示全部楼层
wangrong631 发表于 2011-4-11 15:23
就象分块矩阵一样。把一个矩阵分成几个小矩阵。小矩阵里面又包含更小的矩阵或元素。超元就是把几个单元类型 ...
在 ANSYS WORKBENCH 中如何使用 superelement ?
GMT+8, 2024-11-18 20:54 , Processed in 0.061561 second(s), 21 queries , Gzip On.
